Any body knows where the head light sensor is located.
if you are asking about the sensor which turns off the high-beam when you are facing a traffic , it is located at the back of the interior mirror .
if you are asking about some other sensor please specify ?!
There is an option that turns the head light on when it is dark or very cloudy. Sometiomes it is sunny and clear and the head light is turned on and I thought that the sensor is probably binded somehow because of dirt or other reason so I want to check that myself
you can find it also at the back of the interior mirror (rearview mirror) and you can see it from outside just at the topmost point of the windshield (he point where the mirror is fixed to the windshield ) , so cleaning the glass at this point would help , otherwise you have nothing to do with this sensor.
if the problem still existed after cleaning this spot, ask the dealer to do a calibration to the threshold point for this sensor, it is so easy and would take almost no time
(so less money ;) ) .
thank you very much
Mr. Farahat
