يا شابا عايز اعرف انا عربيتى فيها Immobilizer ولا لاء
لانسر بومه 2008 اوتو 1300cc ....المفتاح فيها سنتر لوك
كل اللانسر البومة والشارك فيه ايموبليزر
ولو حابب نجرب فك بطارية الريموت وشيل الشريحة وحاول تدور بالمفتاح مش هتدور
هتلاقي عند الكونتاكت حاجة نحاسة مدورة كدة عند المكان الي بتحط فية المفتاح هتلاقي حاجة كدة نحاس مدورة
An immobiliser or immobilizer is an electronic security device fitted to an automobile that prevents the engine from running unless the correct key (or other token) is present. This prevents the car from being "hot wired" after entry has been achieved
An immobilizer is an electronic device that arms automatically when your vehicle is switched off and prevents unauthorized starting of the vehicle.
An immobilizer meeting the National Standard of Canada (CAN/ULC-S338-98) cuts three vital circuits: the starter, the ignition and the fuel. This makes it impossible for thieves to start your vehicle without the key.
Having your car stolen is not only emotionally upsetting, but also very time-consuming and expensive. Unfortunately, car theft is all too common and costs Canadians $1 billion per year.
There are human costs, too. Innocent Canadians are put at risk when a thief steals a vehicle. Each year, 40 people lose their lives and 65 more are injured as a direct result of car theft.
More information about immobilizers
Other security devices, such as steering wheel locks, alarms, tracking systems and parts marking, can be combined with an immobilizer to provide additional layers of protection.
- Immobilizers are integrated into the vehicle’s circuitry and engine-management system. They automatically interrupt the power to multiple electronic circuits, usually the starter motor, ignition and fuel pump circuits, when the specially coded key is removed from the ignition switch, or the vehicle is shut off.
- Only if the correctly coded key (or other coded element) is used and recognized by the system will the circuits be enabled, allowing the car to start. Immobilizer keys typically have a transponder or resistor embedded in the head to communicate the code to the engine-management system.
- If the correct code is not recognized, or someone attempts to start the vehicle by some other means – such as hotwiring or breaking the ignition lock cylinder – the system will remain armed and prevent the car from starting.
- An engine immobilizer should always be at the core of any car theft deterrent system. It is the most effective means of preventing drive-away theft.
How the Immobilizer Works - YouTube
وباختصار بالعربى شريحة الكترونية فى المفتاح بترسل كود للكمبيوتر بتاع العربية عند بداية التشغيل -لو الكود غلط او مش موجود العربية مش هتدور وده علشان العربية مبيبقاش ليها غير مفتاحها الاصلى اللى بيجمع بين كود الاسنان وكود الشفرة
immobilizer
منع الحركة
لمنع الحركة أو مانع الحركة هو جهاز الأمن الإلكترونية المجهزة لسيارة يمنع المحرك من التشغيل إلا إذا كان المفتاح الصحيح ( أو رمزية أخرى ) موجود . هذا يمنع السيارة من يجري " السلكية الساخنة" بعد أن تم تحقيق دخول
لمنع الحركة هو جهاز إلكتروني أن الأسلحة تلقائيا عند تشغيل سيارتك قبالة و يمنع غير المصرح به لل انطلاق السيارة.
لمنع الحركة تلبية المعيار الوطني لكندا ( CAN/ULC-S338-98 ) يقطع ثلاث دوائر حيوية : المبدئ ، و الاشتعال و الوقود.
وهذا يجعل من المستحيل على اللصوص لبدء السيارة دون مفتاح .
وجود السيارة المسروقة ليست مزعجة للغاية تستغرق وقتا طويلا ومكلفة فقط عاطفيا ، ولكن أيضا . للأسف ، سرقة السيارات أمر شائع جدا
وتكلف الكنديين 1000000000 $ سنويا.
هناك تكاليف الإنسان أيضا. يتم وضع الكنديون الأبرياء للخطر عندما يسرق اللص السيارة. كل عام، 40 شخصا يفقدون حياتهم و جرح 65 أكثر كنتيجة مباشرة ل سرقة السيارات.
مزيد من المعلومات حول منع الحركة
تتكامل منع الحركة في الدوائر و المحرك لإدارة نظام السيارة. انهم يقطع تلقائيا القدرة على الدوائر الإلكترونية متعددة ، وعادة ما بدء المحرك ، الإشعال ودوائر مضخة الوقود، عند إزالة مفتاح مشفرة خصيصا من مفتاح الإشعال، أو يتم إيقاف السيارة خارج .
وليس هذا فقط إذا تم استخدام مفتاح ترميز بشكل صحيح (أو غيرها من عنصر ترميز ) ومعترف بها من قبل نظام تفعيل الدوائر ، مما يسمح لل سيارة أن تبدأ . لديك مفاتيح لمنع الحركة عادة مستجيب أو المقاوم جزءا لا يتجزأ من الرأس إلى التواصل رمز ل نظام إدارة المحرك .
إذا لم يتم التعرف على الرمز الصحيح ، أو يحاول شخص ما لبدء تشغيل السيارة من قبل بعض وسائل أخرى - مثل hotwiring أو كسر قفل الإشعال اسطوانة - النظام سيبقى المسلحة و منع السيارات من بدء التشغيل.
ينبغي أن يكون منع الحركة المحرك دائما في صميم أي نظام سرقة السيارات رادع . ذلك هو الوسيلة الأكثر فعالية ل منع سرقة بالسيارة.
الأجهزة الأمنية الأخرى ، مثل تأمين عجلة القيادة ، وأجهزة الإنذار ، وأنظمة تتبع وقطع وسم، يمكن الجمع مع منع الحركة لتوفير طبقات إضافية من الحماية .
فيها
ممكن كذا حاجه
طلع نسخة على مفتاحك بحوالي 5 جنيه وجرب تدور مش هتدور
فك مفتاحك هتلاقي مربع اسود زي الفحمه كده وحجمها صغير
وزي ما الاخوة قالولك بردو
تحياتي
هو مفيش عندك علامه الايمبولايزر فى العداد ....
