النتائج 1 إلى 3 من 3
الموضوع: Crash Test Suzuki Swift
    الصورة الرمزية Nader
    رقم العضوية : 57
    الاقامة : مدينة نصر
    السيارة: هيونداي فيرنا
    السيارة[2]: هيونداي فيرنا
    دراجة بخارية: -
    الحالة : Nader غير متواجد حالياً
    افتراضي Crash Test Suzuki Swift - Facebook Twitter whatsapp انشر الموضوع فى :
    [youtube]http://www.youtube.com/watch?v=McLN-5DcDJk[/youtube]
    (4 Stars Adults)
    (3 Stars For Children)
    (2 Stars For Pedestrian protection)
    Front And Side Crash
    Frontal impact
    64 km/h (40 mph) impact into deformable barrier. Simulates typical offset impact into another car.
    Side impact
    50 km/h (30 mph) impact by mobile deformable barrier. Simulates an impact from another car.
    Adult occupant protection
    Frontal impact driver
    Frontal impact passenger
    Side impact driver
    Child occupant protection
    1.5 year old Child Britax Roemer Duo Plus
    1.5 year Facing forward
    3 year old Child Britax Roemer Duo Plus
    3 year Facing forward
    Safety equipment
    Front seatbelt pretensioners
    Front seatbelt load limiters
    Driver frontal airbag
    Front passenger frontal airbag
    Side body airbags
    Side head airbags
    ISOfix rear
    Car details
    Hand of drive LHD
    Tested model Suzuki Swift 1.3 GLA
    Body type super-mini
    Year of publication 2005
    Kerb weight 1010
    VIN from which rating applies to all Swifts
    Comments
    The Swift put in a sound all-round performance. The body proved to be extremely strong, suffering minimal deformation in the frontal impact and providing good protection for adults throughout. But protection for child occupants was mixed: it proved fairly good for the older child but less so for the younger. Its ability to safeguard pedestrians and other vulnerable road users was judged to be reasonably good overall.
    Front impact
    The body suffered minimal deformation and the single-stage frontal airbags, belt pre-tensioners and load limiters worked well, helping to control and limit occupants’ forward movement. However, the load recorded by the driver’s chest instrumentation was just high enough to rate as ‘marginal’ protection. Loads recorded for the driver’s right lower leg were quite high and contact with hard, unforgiving structures around the steering column and behind the fascia posed a risk of knee injury for the driver and passenger. Foam padding protected their feet, while the footwell suffered little damage.
    Side impact
    An impressive protection system included seat mounted thorax airbags and a head curtain airbag which also protected those sat in the rear. In this test, some loads transferred in an unrealistic manner up the driver dummy’s spine, slightly reducing the forces recorded at its chest, so a maximum score was not achieved.
    Child-protection
    A four language, permanent text label warned against placing a child in a rear-facing restraint opposite an active airbag but was fitted only to one side of the sun visors. The recommended restraints used for both children were Britax Romer Duo Plus, fitted forward facing using the ISOFIX anchorages and top tethers. They provided mixed protection. High loads were recorded on the younger child’s head in the frontal test while the older child experienced a fairly high chest load. However, the restraints contained both children well.
    The bumper protected well as did the areas where a child’s head would strike. That for adult heads was less effective. The bonnet’s leading edge gave some protection: overall a good effort by Suzuki.
    الصورة الرمزية fahd_628
    رقم العضوية : 475
    الاقامة : الأسكندرية
    السيارة: I30 & Megane estate
    السيارة[2]: E36 Coupe 328i
    دراجة بخارية: .
    الحالة : fahd_628 غير متواجد حالياً
    شكرااااااااااااااا ليك يا نادر :)
    الحمد لله
    [sor2]http://farm3.static.flickr.com/2639/3939929853_4547d6e150.jpg[/sor2]
    الصورة الرمزية محمد البحيري
    رقم العضوية : 1177
    الاقامة : القاهره
    الحالة : محمد البحيري غير متواجد حالياً
    الف شكر ياباشا
    محمد البحيري
    ge3aidy سابقا
  1. My Car Suzuki Swift GLX
    بواسطة deltaacademy في المنتدى ألـــــــبوم سيـــارات الأعضــــاء
    مشاركات: 21
    آخر مشاركة: 30-10-2012, 02:45 PM
  2. My Suzuki Swift GLX
    آخر مشاركة: 20-04-2012, 01:11 PM
  3. gen.2 vs suzuki swift ....
    بواسطة hegazy_matrix في المنتدى قســـــــــم المقارنــــات
    مشاركات: 7
    آخر مشاركة: 04-09-2011, 06:52 AM
  4. Suzuki Celerio Crash Test ::3 stars
    بواسطة 3ateef في المنتدى سـوزوكى
    آخر مشاركة: 21-04-2010, 02:44 AM
  5. mazda 323 vs suzuki swift
    بواسطة moh_haredy7 في المنتدى قســـــــــم المقارنــــات
    آخر مشاركة: 30-08-2009, 07:15 PM
