Welcome on board Nagy :D
As for your question conerning the the car:
24V 4.5 litre (1FZ-FE) 12V 4.2 litre Diesel (1HZ)
Dimensions
Overall length (mm) 4720 4720
Overall width (mm) 1770 1770
Overall height (mm) 1955 1955
Wheelbase (mm) 2730 2730
Weight
Kerb weight Gasoline (kg.) / Diesel (kg) 2080-2365 2115-2430
Gross vehicle weight (kg) 3000 3000
Chassis
Suspension Front/Rear Rigid axle, Coil springs/Rigid axle, Semi-elliptic leaf springs Rigid axle, Coil springs/Rigid axle, Semi-elliptic leaf springs
Brakes Front/Rear Ventilated discs/Drums Ventilated discs/Drums
Min. turning radius (tyres) m. 6.3 6.3
Fuel tank capacity litres 90 90
Tyres 7.50R16-8PRLT 7.50R16-8PRLT
Transmission
Transmission 5-speed manual 5-speed manual
Engine
Types 24V 4.5 litre 1FZ-FE 12V 4.2 litre Diesel 1HZ
Piston displacement cc 4477 4146
Max. output (SAE net) kW/rpm 162/4600 96/3800
Max. torque (SAE net) Nm/rpm 384/3600 285/2200
Fuel system Electronic fuel injection Distribution type fuel injection
Ther are more than one size for it and there are a packup one also
