رقم العضوية : 57
الاقامة : مدينة نصر
السيارة: هيونداي فيرنا
السيارة[2]: هيونداي فيرنا
دراجة بخارية: -
[youtube]http://www.youtube.com/watch?v=sYsBqCkSOUc[/youtube]
Frontal impact
64 km/h (40 mph) impact into deformable barrier. Simulates typical offset impact into another car.
4 Stars for Adults
Adult occupant protection
Frontal impact driver
Frontal impact passenger
Side impact driver
Safety equipment
Front seatbelt pretensioners
Front seatbelt load limiters
Driver frontal airbag
Front passenger frontal airbag
Side body airbags
Car details
Hand of drive LHD
Tested model BMW Z4 2.5
Body type Two-seater roadster
Year of publication 2004
Kerb weight 1335
Comments
The Z4 is a very strong scoring four-star car. It suffered very little damage to its cabin, the driver’s door remaining straight and substantially undamaged after the impact. The car was tested in the frontal crash with its roof down to give ‘worst-case’ results. Similarly, for the side impact, the top was left up to check for any adverse interaction with the driver’s head. Because the car has only two seats, it was tested without child restraints. However, it is possible to fit a restraint to the passenger’s seat so, the fitting and labelling requirements were checked. Protection for pedestrians proved to be fair.
Front impact
The restraint system is based on a dual stage non-tethered airbag for the driver and for the passenger. Each has a belt pre-tensioner that, combined with load limiters worked well at keeping forces on occupants’ chests low. Late in the impact, the driver’s head moved towards the outside of the airbag, making a glancing contact with the screen pillar. The car’s body proved itself to be very strong, showing minimal deformation of the body structure around the sill and screen pillar and suffering only minor intrusion into the footwell. However, the knee impact areas for the driver were unforgiving, with hard structures abounding.
Side impact
The protection system is very impressive and includes a thorax airbag that worked well. The driver’s head contacted the roof rail, but not hard enough to cause concern.
Child-protection
As two adult dummies were fitted no room remained for a child restraint. It is possible to fit one to the passenger’s seat. However, the only warning of the dangers associated with doing so was a text label on the windscreen, which was non-permanent and poorly worded.
Pedestrian protection
Levels of protection were fair. The bonnet’s leading edge did not require testing as its shape and low height meant that it would not be aggressive. Some areas of its top gave protection. But its sides, wings and the bumper, proved particularly unfriendly.
رقم العضوية : 475
الاقامة : الأسكندرية
السيارة: I30 & Megane estate
السيارة[2]: E36 Coupe 328i
دراجة بخارية: .
تمااااااام يا نادر شكرا ليك
