في كتاب الصيانات عندي عربيه مازدا 2008 مكتوب الموصي به للفتيس atf-mv و الموصي به للباور atf-miii
فياتري ايه الانواع اللي فيها المواصفات دي ... انا بصيت علي موبيل و شيل و كاسترول مافيهومش المواصفات دي
Valvoline max life .. This is multivehicle oil .. Equivlant to mazda MV oil
Olso liquimoli 1200. Works fine . The 1st i had used it and the litre by 85 pounds. And you need only 3 litres .. Not more according to all oils web sites
Thanks man but 3 litres without filter being changed & what abt hte power steering oil
3litres with or without the filter
according to our manual the power steering in mazda 3 is dextron II which is a conventional oil not fully synthetic so you can use mobile ATF 220 or 320 .. no matter
