Acer V5 touch Labtop طلب تسعير
سؤال لاهل الخبرة لابتوب ايسر تاتش 15.6 بوصة
موديل acer V5-571P-6604 جديد (Refurbished) بدون اي خدش وارد الخارج (الامارات) مش محتاجه و عاوز ابيعه يعمل كام.
General
Operating System Windows 8 64-bit Edition
Processor / Chipset
- CPU 3rd Gen Core i5,
Intel 3 i5-3317U / 1.7 GHz - Max Turbo Speed 2.6 GHz
- Number of Cores Dual-Core
- Cache L3 cache - 3 MB
- 64-bit Computing Yes
- Chipset Mobile Intel HM77 Express
- Features Intel Turbo Boost Technology 2.0,
Hyper-Threading Technology
Memory
- RAM 6 GB ,Technology DDR3 SDRAM
- Form Factor SO DIMM 204-pin
- Slots Qty 2
- Empty Slots 0
Storage
- Hard Drive 500 GB HDD / 5400 rpm
- Interface Serial ATA-300
- Optical Drive DVD±RW (±R DL) / DVD-RAM - Fixed
Display
- Type 15.6 in
- LCD Backlight Technology LED backlight
- Touchscreen Yes
- Max Resolution 1366 x 768 ( HD )
- Widescreen Yes
- Image Aspect Ratio 16:9
- Features HDCP,
CineCrystal
Audio & Video
- Graphics Processor Intel HD Graphics 4000
- Memory Allocation Technology Shared video memory (UMA)
- Camera Yes
- Sound Microphone
- Compliant Standards Dolby Advanced Audio v2
Communications
- Wireless Bluetooth 4.0 HS,
802.11n - Wireless Controller Broadcom 43228
- Network Interface Gigabit Ethernet
Battery
- Technology 4-cell Lithium ion
- Capacity 2500 mAh
- Run Time 5 hour(s)
AC Adapter
- Voltage Required AC 120/230 V ( 50/60 Hz )
- Output 65 Watt
Connections & Expansion
- Expansion Bays None
- Interfaces 2 x USB 2.0,
HDMI,
LAN/VGA combo,
USB 3.0 - Memory Card Reader Card reader ( SD Memory Card ),
( MultiMediaCard )
Miscellaneous
Dimensions & Weight
- Width 13.5 in
- Depth 9.6 in
- Height 1 in
- Weight 4.6 lbs
