دي صور الـ CROSSOVER الجديده من سوبارو و هيه عربيه 7 راكب. العربيه نزلت اليابان من شهر يونيو اللي فات.. و لسه منزلتش خارج اليابان. اسيبكو مع الصور
http://www7.0zz0.com/thumbs/2008/10/02/01/367586628.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/248873862.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/602607932.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/791483810.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/716395819.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/497588041.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/619825698.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/989936967.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/742595961.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/514770708.jpg
http://www7.0zz0.com/thumbs/2008/10/02/01/967991131.jpg
و دي مواصفات العربيه:
• Overall length: 4,740mm, Overall width: 1,775mm, Overall height: 1,660mm, Wheelbase: 2,750mm
• 2.0i, 2.0i-L, 2.0i-S: 2.0-liter DOHC 16-valve, Horizontally-Opposed, 4-cylinder, gasoline engine
Max. output (net): 109kW(148PS)/6,000rpm
Max. torque (net): 191N.m(19.5kg.m)/3,200rpm
SPORTSHIFT E-4AT
AWD system: Active Torque Split AWD system
215/50R17 Tires with aluminum alloy wheels (2.0i-S)
205/60R16 Tires with aluminum alloy wheels (2.0i-L)
205/60R16 Tires with full wheel caps (2.0i)
• 2.0GT:
2.0-liter DOHC 16-valve, intercooled, turbocharged, Horizontally-Opposed, 4-cylinder, gasoline engine
Max. output (net): 165kW(225PS)/5,600rpm
Max. torque (net): 326N.m(33.2kg.m)/4,400rpm
SPORTSHIFT E-5AT
AWD system: Variable Torque Distribution system
