رقم العضوية : 26967
الاقامة : Fifth Settlement
السيارة: Sandero 2014
السيارة[2]: Elentra Coupe 2013
انا لاحظت صوت تخبيط من الشمال تحت وصوت طأة مع المطبات الصغيره و افتكرت العفشة ولم رحتلهم قالوا لي علبة الباور محتاجه تغيير وفعلا اتصلوا بي النهارده وقالوا تعالى نغيرهلك
رقم العضوية : 19543
الاقامة : ismailia/Egypt
السيارة: لايوجد حاليا
السيارة[2]: نوبيرا 2007
رقم العضوية : 228
الاقامة : Helwan
السيارة: Picanto
السيارة[2]: Escort
Electronic power ,,no oil
رقم العضوية : 19543
رقم العضوية : 228
الاقامة : Helwan
السيارة: Picanto
السيارة[2]: Escort
Electric power steering (EPS or EPAS) is designed to use an electric motor to reduce effort by providing assist to the driver of a vehicle. Most EPS systems have variable assist, which allows for more assistance as the speed of a vehicle decreases and less assistance from the system during high-speed situations. This functionality requires a delicate balance of power and control that has only been available to manufacturers in recent years. The EPS system has replaced the hydraulic steering system (HPS or HPAS) in many passenger cars recently: EPS is so far limited to passenger cars, as a higher voltage electrical system is necessary to operate EPS in larger vehicles.
Unlike HPS systems, EPS systems do not require a hydraulic pump, which is belted into the engine. Rather the EPS system's electric motor is powered by the vehicle's alternator which is belted into the engine. The efficiency advantage of an EPS system is derived from the fact that it is activated only when needed. Thus, a vehicle equipped with EPS may achieve an estimated improvement in fuel economy of 3% compared to the same vehicle with conventional HPS.[citation needed] However, any fuel economy benefit of EPS over HPS can be negated in situations where a vehicle is not driven on straight-aways very often, or where a vehicle's wheels are out of alignment
(http://en.wikipedia.org/wiki/Electric_Power_Steering)
رقم العضوية : 15742
النوع : انثى
الاقامة : Nasr City
السيارة: Kia Carens 2011
السيارة[2]: Kia Cerato 2013
دراجة بخارية: NA
هو الصوت اختفى من زمان على فكرة ، اعتقد انه كان عشان التليين مش اكتر ، دلوقتى انا داخلة على 2000 كيلو
Everything's not lost..
رقم العضوية : 13220
الاقامة : Giza
السيارة: كفاية واحدة والحمد لله
السيارة[2]: fiat 127 / model 1985
طب الحمد لله يلا هانت فاضل 3000
رقم العضوية : 19543
رقم العضوية : 228
الاقامة : Helwan
السيارة: Picanto
السيارة[2]: Escort
رقم العضوية : 19543
