what you are saying about the heat is different from what i am talking about are you sure that the Air Cycle switch is ON it should be yellow otherwise you are allowing air from outside to enter through the A/C and it will be hot air as it comes from somewhere close to the engine and you say the air is coming from down as well so may be you set the A/C mode to give air at the front and at your legs check on that .
for the first service 1000 km nothing is done except changing the oil may be the oil that was previously in the vehicle better quality than the one you have now ,nothing much is done in this service.
Drive the car manually and enjoy the quick response of your beast. :)
Content Relevant URLs by
vBSEO 3.6.0 PL2
