بييييييييييييييييييع
Sony is not having the best luck when it comes to really nailing the quality control for its smartphones. A couple months back we shared with you an issue cropping up with the Xperia Z1 Compact, where light was apparently bleeding through the phone’s body from its flash to the camera sensor, washing out pics in the process. Sony’s latest and greatest Xperia model is the new Z2, and once again new owners are sharing their dissatisfaction with unexpected hardware problems.
First up, we have another build quality issue. Some owners report the presence of gaps between the edge of the phone’s glass face and the metal frame, raising concerns that the handset’s waterproofing may be compromised. This isn’t the first time that issues like this have been noticed with Xperia models, but based on the frequency of reports, it may be a more widespread problem with the Z2.
Then [OVERLINE]there’s an overheating issue with the Z2[/OVERLINE], one that can occur when shooting 4K resolution video for an extended period of time. Sometimes the phone gets so hot that software becomes glitchy, leading to apps crashing.
Sony has responded to both sets of allegations. As for the gap issue, the company says that it’s currently looking into things, and that anyone who’s worried that waterproofing may be compromised can take their Z2 to a service center to have the handset tested. In regards to the 4K overheating, Sony says that for the “best experience,” users should “shoot 4K video in short bursts of no longer than a few minutes at a time.” That’s not the most satisfying response, and it would be great to hear that a fix was in the works, but this may simply be a case of pushing the hardware too close to its limits.
Sony Xperia Z2 owners complaining of hardware problems | Pocketnow
مفيش حل لمشكله السخونيه يا معلم
دا عاوزله مروحه بروسيسور فعلا
معايا الاس ثري النسخه الامريكي بروسيسور 1.5 ورامات 2 جيجا
وبيسخن ولا البانتيوم 2 في زمانه
تلعب يسخن
تشحن يسخن
تتكلم يسخن
اديته لبوس منفعش
غيرت رومات منفعش برضه
الحل انك تتكلم ببلوتوث علشان متمسكهوش وتحس بسخونيته
الموبايل معايا وبلعب عليه اسفالت8 ومبيسخنش زي مبتحكي
وكمان حاططله ميموري 32 والثري جي شغال اغلب الوقت ومفيش سخونيه زي مبتحكي
مع العلم انا تارسه برامج ومبيفارقش ايدي الحمدلله
رايي لو هينفع يروح الضمان ماشي مش هينفع تعامل بيه كده
وبالمناسبة
سوفتوير سوني افضل الف مره من سامسونج وانا كنت سوني وحولت سامسونج وكرهت نفسي والحمد لله رجعت للسوني
تحياتي
Sent from my mobile using Forum Runner
للاسف هية دية مشاكل سونى السخونية , بس انها توصل للحرارة دية ياكريم باشا كتير اوى يعنى اكتر موبايل سامسونج فية مشكلة فى السخونية بيوصل ل 42 درجة , دة اخرة
لكن 50 درجة دية احمد ربنا ان التليفون مانفجرش
اكيد فية مشكلة فى الهاتف , او فى السوفت , عموما نزل نسخة جديدة ( دة الحل الوحيد ) ممكن يكون فية مشكلة فى الكيرنل )
وحاول تنزل برنامج cpu-z وشوف البروسيسر قارى كام ونسبة استهلاكة كام
كان معايا الارك اس ومكنش بيسخن زي الاس 2
مش عارف منين الكل بيقول ان سوني عيبها السخونه...
تحياتي
رأيي يا أستاذ كريم:
أولاً تغيير برنامج "DU Battery Doctor" إلى "Battery Doctor (Battery Saver)". لأني جربته ولاقيته بيستنزف البطارية بشكل كبير أوي. البرنامج على الرابط ده:
https://play.google.com/store/apps/d...tterydoctor_en
وبعد كده اشحن البطارية وشوف هل فيه فرق في الاستهلاك وفرق في الاستخدام ولا لأ
دي مشكلة فيه للاسف بتحصل مع واحد صاحبي
جابوا قبل كدة وحطه في المية وباظ راح بدله بواحد تاني والموبيل بيسخن جامد فعلاً
انا عندي في النوكيا لوميا 1020 بشحن الموبيل ومشغل اغاني وبلعب mass effect في نفس الوقت والسخونية تقريباً مبتبقاش ملحوظة
معلش ياجماعة يعنى مهو مش معقول تكون سامسونج رقم 1 عالميا فى المبيعات من فراغ
سامسونج فعلا مش بيعديها حاجة وخلينا نتكلم على أجهزة الفلاج شيب بلاش الأجهزة الرخيصة عشان تعبانة فعلا
حتى الـ lg g3 الجهاز الجبار واحد صاحبى اشتراه ومكملش اسبوع معاه ورجعه الضمان ولايص معاهم معرفش هيوصل لإيه (مع انه فى الكويت مش هنا )
الجهاز بيسخن برده وبيعمل ريستارت لوحده وعمله أبديت لأخر فيرجن وبرده نفس الكلام وأكتشف بعد كده
انها مشكلة عامة وناس كتير بتشتكى ومفيش حلول !!!
المهم انا رأيى زى بقية الشباب تبيعه
وهنصحك بنفس النصيحة اللى قولتهالك قبل كده :) تستنى النوت 4 وده هيعلنوا عنه فى المؤتمر القادم يوم 3-9-2014 يعنى اسبوعين بالظبط
وبعدها بكام يوم هتلاقيه فى الأسواق
هو الموبايل ده مش ضد المية
لما يسخن اعمله كمدات مية ساقعة هتلاقية فل والحرارة هتنزل و ادعيله وانت بتصلي
