v3 sport
رقم العضوية : 44546
الاقامة : Egypt
السيارة: كورولا 1995
السيارة[2]: fiat 125
الشركة الصينية ساوث ايست صاحبة لايونسيل فى مصر و مصنعة الشارك و غيرها من منتجات متسوبيشي .
东南汽车官网
Soueast - Wikipedia, the free encyclopedia
بتقدم فى السوق المصري لانسر كرستالة 2015 او
southeast v3
Southeast Motor to Unveil V3 Lingyue in Shanghai
السعر 77,700
محرك مايفك تكنولوجيا ياباني بتعديل و صناعة صينية
سعته 1.5
109 حصان
134nm/3000rpm
استهلاكه 4.3l/100km at 60kmph
V3 is available in 5 trim levels. Basic, Standard, Luxury, Flagship and a Flagship Sunroof model
Available in manual transmission and a recently launched CVT version
The wireless entry, and wireless ignition system is usually only found on cars twice the price.
V3 also has a DVD/Navigation system, and a CD player with MP3 connection. Safety features such as ABS+EBD and Driver/ Passenger Airbags are there as standard equipment.
The price of V3 is set below the actual Lancer hence making it quite a competitive and successful option in its own class. And yes, 'V' stands for 'Victory'..
AIRBAGS
There are duel i-SRS intelligent airbags in the front cabin of the car. When there is accident, they will pump out within 0.035~0.06 seconds, which will provide sound and timely protection to the driver as well as the passengers.
Four-door anti-impact steel beams
On the foundation of traditional doors’ structure, there adds steel beams in the middle of V3’s doors in order to strengthen the side structures of the car, which will boost the anti-impact capability and make the passengers safe when side impact happens.
Four-wheel disk braking+ABS+EBD
The braking system of V3 is consisted of ventilating disk in the front and solid disk in the rear, which makes the heat caused by braking diffuse quickly, ensuring the excellent braking performance.
When you are braking in an instant moment, ABS+EBD will provide intermittent braking effect with high efficiency. Not only it will prevent the danger from side sliding and out of control, but also will it provide most accurate braking control and short braking distance.
High density body in the type of Mitsubishi shock absorber
Using CAE to design the body structure of V3 in order to improve the strength, which could, effectively, break the impacting force down and provide the driver and the passengers protections without fail.
In addition, we adopt new methods of melding, which will enhance the joints strength between different components. Therefore, the body structure could be strengthened completely
V3 has passed the front impacting test in the speed of 50km/h, which is in compliance with the American standards of front & rear impacting tests in the speed of 50km/h. Moreover, V3 wins the AA judgment of Japanese front impacting test in the speed of 55km/h.
HIFI CD audio system with MP3 port
Setting the MP3 data port, together with professional audio equipment, you could enjoy the music any where and any time.
Humanized Interior Decorations Humanized Layout, comfortable ergonomics, gracious feelings of the quality build the best atmosphere of interior decorations.
Intelligent Keyless Ignition System
You just need to rotate the ignition key and then your car will be started accordingly. The leading action technology will make everything within your controls.
Trunk Lip opened by remote control
You just need to press the remote control lightly and then the trunk lip will be opened easily. Colorful life is extended from here.
mainly specifications and equipments for V3
و لكن كعادة الصيني تم استدعاء فى الصين كل السيارات انتاج من 2009 الى 2011 لعيب تصنيع فى فرامل اليد .
هدف تصنيع العربية دي امكانيات و تكنولوجيا الياباني بنصف الثمن .
رقم العضوية : 44546
الاقامة : Egypt
v3 sport
رقم العضوية : 157318
الاقامة : Stuttgart-Hamburg
السيارة: E63 AMG / Audi R8 / Audi A6
السيارة[2]: peugeot 508 2015 Highline
دراجة بخارية: Honda NC700X
في رأيي المتواضع ديه مش أحسن العربيات الصيني في مصر و الBYD f3 أحسن منها 100 مرة و ال L3 كمان
رقم العضوية : 44546
الاقامة : Egypt
رقم العضوية : 78189
الاقامة : 6 october
السيارة: Nissan Sunny 2013
السيارة[2]: Lanos 2008
مجهود جميل يا أستاذ مف، يا ترى حد يعرف الفئات و الأسعار؟
رقم العضوية : 29288
الاقامة : المنصورة
السيارة: Speranza A516
السيارة[2]: اكسيل
رقم العضوية : 44546
الاقامة : Egypt
رقم العضوية : 44546
الاقامة : Egypt
eng.mark
الصيني فى مصر من وجهة نظري :
1- ايمجراند
2- byd f3
من وجهة نظري الايمجراند بتتفوق فى استهلاك الوقود و الامان و الكماليات على ما اعتقد
رقم العضوية : 44546
الاقامة : Egypt
من اجمل التعليقات هشام مرزوق
بترجمة باسم نجيبالمشاركة الأصلية كتبت بواسطة [COLOR=Blue
http://www.nilemotors.net/Nile/45639...t-crystal.htmlالمشاركة الأصلية كتبت بواسطة [COLOR=Blue
شكرا للمجهودات الرائعة
