(اهداء) الجزء الرابع- الدليل الشامل لرموز أخطاء جميع فئات bmw ومعانيها
الجزء الرابع :
17110037 Radiator including module carrier Loose
17110048 Radiator including module carrier Leaking
17110072 Radiator including module carrier Poorly bled
171100XX Radiator including module carrier
17110114 Radiator cap Occasional malfunction
17110115 Radiator cap Permanent malfunction
17110123 Radiator cap Incorrect / not fitted
17110148 Radiator cap Leaking
171101XX Radiator cap
17110237 Radiator compensating tank Loose
17110248 Radiator compensating tank Leaking
171102XX Radiator compensating tank
17110401 Fan surround Cracked / broken / torn off
17110437 Fan surround Loose
17110439 Fan surround Unpleasant noises
171104XX Fan surround
17110759 Radiator coolant level Too low / deep / slight
17110760 Radiator coolant level Too high
171107XX Radiator coolant level
17111112 Electric fan Permanent failure
17111137 Electric fan Loose
17111179 Electric fan incorrect connection /contact
17111199 Electric fan Fault code stored in diagnosis fault code memory (no warning lamp)
171111XX Electric fan
17111214 Thermostat for oil-to-coolant heat exchanger (automatic transmission) Occasional malfunction
17111215 Thermostat for oil-to-coolant heat exchanger (automatic transmission) Permanent malfunction
17111279 Thermostat for oil-to-coolant heat exchanger (automatic transmission) incorrect connection /contact
171112XX Thermostat for oil-to-coolant heat exchanger (automatic transmission)
1711XXXX Radiator with mount
17122001 Coolant hose, thin (inside diameter approx. 8 mm) Cracked / broken / torn off
17122030 Coolant hose, thin (inside diameter approx. 8 mm) Blistering
17122069 Coolant hose, thin (inside diameter approx. 8 mm) Worn / sheared through
171220XX Coolant hose, thin (inside diameter approx. 8 mm)
17122101 Coolant hose, medium (inside diameter approx. 16 mm) Cracked / broken / torn off
17122130 Coolant hose, medium (inside diameter approx. 16 mm) Blistering
17122169 Coolant hose, medium (inside diameter approx. 16 mm) Worn / sheared through
171221XX Coolant hose, medium (inside diameter approx. 16 mm)
17122201 Coolant hose, thick (inside diameter approx. 32 mm) Cracked / broken / torn off
17122230 Coolant hose, thick (inside diameter approx. 32 mm) Blistering
17122269 Coolant hose, thick (inside diameter approx. 32 mm) Worn / sheared through
171222XX Coolant hose, thick (inside diameter approx. 32 mm)
17122313 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Broken
17122337 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Loose
17122341 Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm) Poorly adapted/fitted
171223XX Quick-release coupling, coolant hose, thin (inside diameter approx. 8 mm)
17122413 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Broken
17122437 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Loose
17122441 Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm) Poorly adapted/fitted
171224XX Quick-release coupling, coolant hose, medium (inside diameter approx. 16 mm)
17122513 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Broken
17122537 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Loose
17122541 Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm) Poorly adapted/fitted
171225XX Quick-release coupling, coolant hose, thick (inside diameter approx. 32 mm)
17122613 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Broken
17122637 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Loose
17122641 Hose clip, coolant hose, thin (inside diameter approx. 8 mm) Poorly adapted/fitted
171226XX Hose clip, coolant hose, thin (inside diameter approx. 8 mm)
17122713 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Broken
17122737 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Loose
17122741 Hose clip, coolant hose, medium (inside diameter approx. 16 mm) Poorly adapted/fitted
171227XX Hose clip, coolant hose, medium (inside diameter approx. 16 mm)
17122813 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Broken
17122837 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Loose
17122841 Hose clip, coolant hose, thick (inside diameter approx. 32 mm) Poorly adapted/fitted
171228XX Hose clip, coolant hose, thick (inside diameter approx. 32 mm)
1712XXXX Coolant lines/coolant hoses
17210039 Engine oil cooler Unpleasant noises
17210048 Engine oil cooler Leaking
172100XX Engine oil cooler
17210148 Heat exchanger, automatic transmission fluid - coolant Leaking
172101XX Heat exchanger, automatic transmission fluid - coolant
17210539 Oil cooler for automatic transmission Unpleasant noises
17210548 Oil cooler for automatic transmission Leaking
172105XX Oil cooler for automatic transmission
1721XXXX Oil cooler
17220037 Engine oil cooler lines/connections, engine end Loose
17220039 Engine oil cooler lines/connections, engine end Unpleasant noises
17220048 Engine oil cooler lines/connections, engine end Leaking
172200XX Engine oil cooler lines/connections, engine end
17220137 Engine oil cooler lines/connections, oil cooler end Loose
17220139 Engine oil cooler lines/connections, oil cooler end Unpleasant noises
17220148 Engine oil cooler lines/connections, oil cooler end Leaking
172201XX Engine oil cooler lines/connections, oil cooler end
17221139 Oil cooler lines/hoses for transmission fluid, transmission side Unpleasant noises
17221148 Oil cooler lines/hoses for transmission fluid, transmission side Leaking
172211XX Oil cooler lines/hoses for transmission fluid, transmission side
17221239 Oil cooler lines/hoses for transmission fluid on radiator side Unpleasant noises
17221248 Oil cooler lines/hoses for transmission fluid on radiator side Leaking
172212XX Oil cooler lines/hoses for transmission fluid on radiator side
17229023 E53 M54 Retrofit autom. gearbox oil cooler lines with chafe guard (with independ. heating retrofit)
1722XXXX Oil cooler lines
17310112 Radiator shutter Permanent failure
17310113 Radiator shutter Broken
17310115 Radiator shutter Permanent malfunction
173101XX Radiator shutter
1731XXXX Radiator shutter
17320112 Changeover valve, radiator shutter Permanent failure
17320129 Changeover valve, radiator shutter Sticking/jammed
17320179 Changeover valve, radiator shutter incorrect connection /contact
17320184 Changeover valve, radiator shutter incorrect electrical resistance
173201XX Changeover valve, radiator shutter
17320248 Vacuum hose, radiator shutter Leaking
17320276 Vacuum hose, radiator shutter dirty / blocked
173202XX Vacuum hose, radiator shutter
1732XXXX Radiator shutter actuation
17510137 Charge air intercooler Loose
17510148 Charge air intercooler Leaking
17510176 Charge air intercooler dirty / blocked
175101XX Charge air intercooler
17510232 Charge air pipes/hoses Deformed / distorted / bent
17510237 Charge air pipes/hoses Loose
17510248 Charge air pipes/hoses Leaking
17510276 Charge air pipes/hoses dirty / blocked
175102XX Charge air pipes/hoses
1751XXXX Charge air intercooler with mount
17XXXXXX Cooling
18110032 Exhaust system, general Deformed / distorted / bent
18110039 Exhaust system, general Unpleasant noises
181100XX Exhaust system, general
18110101 Front exhaust pipe (jacket pipe) Cracked / broken / torn off
18110137 Front exhaust pipe (jacket pipe) Loose
18110148 Front exhaust pipe (jacket pipe) Leaking
181101XX Front exhaust pipe (jacket pipe)
18110248 Exhaust pipe flange gasket Leaking
181102XX Exhaust pipe flange gasket
18110501 Vibration absorber, exhaust pipe Cracked / broken / torn off
18110537 Vibration absorber, exhaust pipe Loose
181105XX Vibration absorber, exhaust pipe
18110601 Intermediate pipe (between manifold and catalytic converter) Cracked / broken / torn off
18110604 Intermediate pipe (between manifold and catalytic converter) Screw connection torn
18110637 Intermediate pipe (between manifold and catalytic converter) Loose
18110639 Intermediate pipe (between manifold and catalytic converter) Unpleasant noises
18110648 Intermediate pipe (between manifold and catalytic converter) Leaking
181106XX Intermediate pipe (between manifold and catalytic converter)
1811XXXX Exhaust line
18120001 Front silencer Cracked / broken / torn off
18120039 Front silencer Unpleasant noises
18120048 Front silencer Leaking
18120075 Front silencer corroded
181200XX Front silencer
18120101 End silencer (with tailpipes) Cracked / broken / torn off
18120139 End silencer (with tailpipes) Unpleasant noises
18120148 End silencer (with tailpipes) Leaking
18120175 End silencer (with tailpipes) corroded
181201XX End silencer (with tailpipes)
18120201 Intermediate silencer Cracked / broken / torn off
18120239 Intermediate silencer Unpleasant noises
18120248 Intermediate silencer Leaking
18120275 Intermediate silencer corroded
181202XX Intermediate silencer
18120339 Rear silencer, exhaust flap Unpleasant noises
18120383 Rear silencer, exhaust flap incorrect or no switching action
181203XX Rear silencer, exhaust flap
1812XXXX Silencer
18210001 Front exhaust mount (bracket) Cracked / broken / torn off
18210037 Front exhaust mount (bracket) Loose
182100XX Front exhaust mount (bracket)
18210101 Rear exhaust mount (bracket) Cracked / broken / torn off
18210137 Rear exhaust mount (bracket) Loose
182101XX Rear exhaust mount (bracket)
18210401 Centre exhaust mount (bracket) Cracked / broken / torn off
18210437 Centre exhaust mount (bracket) Loose
182104XX Centre exhaust mount (bracket)
18210501 Front exhaust mount, rubber element Cracked / broken / torn off
18210537 Front exhaust mount, rubber element Loose
182105XX Front exhaust mount, rubber element
18210601 Centre exhaust mount, rubber element Cracked / broken / torn off
18210637 Centre exhaust mount, rubber element Loose
182106XX Centre exhaust mount, rubber element
18210701 Rear exhaust mount, rubber element Cracked / broken / torn off
18210737 Rear exhaust mount, rubber element Loose
182107XX Rear exhaust mount, rubber element
1821XXXX Exhaust mounting components
18320101 (Main) catalytic converter Cracked / broken / torn off
18320114 (Main) catalytic converter Occasional malfunction
18320115 (Main) catalytic converter Permanent malfunction
18320139 (Main) catalytic converter Unpleasant noises
18320148 (Main) catalytic converter Leaking
18320196 (Main) catalytic converter Fault code in diagnosis memory (warn. lamp on)
18320199 (Main) catalytic converter Fault code stored in diagnosis fault code memory (no warning lamp)
183201XX (Main) catalytic converter
18320201 Primary catalytic converter Cracked / broken / torn off
18320214 Primary catalytic converter Occasional malfunction
18320215 Primary catalytic converter Permanent malfunction
18320239 Primary catalytic converter Unpleasant noises
18320248 Primary catalytic converter Leaking
18320296 Primary catalytic converter Fault code in diagnosis memory (warn. lamp on)
18320299 Primary catalytic converter Fault code stored in diagnosis fault code memory (no warning lamp)
183202XX Primary catalytic converter
1832XXXX Catalytic converter with mount
18XXXXXX Exhaust system
21210052 Complete clutch Not opening
21210055 Complete clutch Stick-slip
21210058 Complete clutch Slipping
212100XX Complete clutch
21210113 Complete clutch disc Broken
21210121 Complete clutch disc Worn
212101XX Complete clutch disc
21210339 Dual mass flywheel (ZMS) Unpleasant noises
21210348 Dual mass flywheel (ZMS) Leaking
212103XX Dual mass flywheel (ZMS)
21210413 Clutch pressure plate Broken
212104XX Clutch pressure plate
21219039 E36/7 E39 E46 E52 E53 Cracking sound during clutch operation
2121XXXX Clutch with drive plate
21510013 Clutch release Broken
21510025 Clutch release Rough running
21510039 Clutch release Unpleasant noises
215100XX Clutch release
21510134 Clutch release lever Stiff to move
215101XX Clutch release lever
2151XXXX Clutch release mechanism with lever
21520115 Clutch master cylinder Permanent malfunction
21520139 Clutch master cylinder Unpleasant noises
21520148 Clutch master cylinder Leaking
215201XX Clutch master cylinder
21520215 Clutch slave cylinder Permanent malfunction
21520239 Clutch slave cylinder Unpleasant noises
21520248 Clutch slave cylinder Leaking
215202XX Clutch slave cylinder
21520348 Clutch pipes and hoses Leaking
215203XX Clutch pipes and hoses
2152XXXX Clutch actuation (hydraulics)
21549053 E46 S54 Vehicle - no clutch engagement
21XXXXXX Clutch
22110001 Engine mounting bracket Cracked / broken / torn off
22110037 Engine mounting bracket Loose
221100XX Engine mounting bracket
22110101 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Cracked / broken / to
22110137 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Loose
22110139 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Unpleasant noises
22110148 Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL) Leaking
221101XX Rubber mounts, hydraulic bearings, damping-controlled hydraulic bearing (DSHL)
22110283 DSHL bearing incorrect or no switching action
221102XX DSHL bearing
22110401 DSHL vacuum hoses / lines / hose connection Cracked / broken / torn off
22110437 DSHL vacuum hoses / lines / hose connection Loose
22110448 DSHL vacuum hoses / lines / hose connection Leaking
22110476 DSHL vacuum hoses / lines / hose connection dirty / blocked
221104XX DSHL vacuum hoses / lines / hose connection
22110583 DSHL electric changeover valve incorrect or no switching action
22110584 DSHL electric changeover valve incorrect electrical resistance
221105XX DSHL electric changeover valve
22110601 Heat baffle plate for engine mount Cracked / broken / torn off
22110637 Heat baffle plate for engine mount Loose
22110639 Heat baffle plate for engine mount Unpleasant noises
221106XX Heat baffle plate for engine mount
22110701 Stop pad, engine Cracked / broken / torn off
22110737 Stop pad, engine Loose
22110739 Stop pad, engine Unpleasant noises
221107XX Stop pad, engine
22110801 Heat shield for engine mounting bracket Cracked / broken / torn off
22110837 Heat shield for engine mounting bracket Loose
22110839 Heat shield for engine mounting bracket Unpleasant noises
221108XX Heat shield for engine mounting bracket
22110901 Engine mounting bracket Cracked / broken / torn off
22110937 Engine mounting bracket Loose
221109XX Engine mounting bracket
22111001 Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount) Cracked / broken / t
22111037 Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount) Loose
22111039 Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount) Unpleasant noises
221110XX Engine - stabilizer link, top (engine mounting bracket / stabilizer link mount)
22111101 Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket) Cracked / broken / t
22111137 Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket) Loose
22111139 Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket) Unpleasant noises
221111XX Engine - stabilizer link, bottom (front axle carrier / stabilizer link bracket)
22111201 Bracket for engine - stabilizer link, bottom (engine / stabilizer link, bottom) Cracked / broken / t
22111237 Bracket for engine - stabilizer link, bottom (engine / stabilizer link, bottom) Loose
221112XX Bracket for engine - stabilizer link, bottom (engine / stabilizer link, bottom)
22111301 Mount for engine - stabilizer link, top (body / stabilizer link, top) Cracked / broken / torn off
22111337 Mount for engine - stabilizer link, top (body / stabilizer link, top) Loose
22111339 Mount for engine - stabilizer link, top (body / stabilizer link, top) Unpleasant noises
221113XX Mount for engine - stabilizer link, top (body / stabilizer link, top)
2211XXXX Engine mount
22310001 Manual transmission mount, cross member Cracked / broken / torn off
22310037 Manual transmission mount, cross member Loose
223100XX Manual transmission mount, cross member
22310101 Manual transmission mount, rubber/hydraulic mount Cracked / broken / torn off
22310137 Manual transmission mount, rubber/hydraulic mount Loose
22310139 Manual transmission mount, rubber/hydraulic mount Unpleasant noises
22310148 Manual transmission mount, rubber/hydraulic mount Leaking
223101XX Manual transmission mount, rubber/hydraulic mount
22310201 Vibration absorber (manual transmission) Cracked / broken / torn off
22310237 Vibration absorber (manual transmission) Loose
22310239 Vibration absorber (manual transmission) Unpleasant noises
223102XX Vibration absorber (manual transmission)
22310301 Manual gearbox mounting, gearbox mounting bracket Cracked / broken / torn off
22310337 Manual gearbox mounting, gearbox mounting bracket Loose
223103XX Manual gearbox mounting, gearbox mounting bracket
22310401 Stop pad, manual gearbox Cracked / broken / torn off
22310437 Stop pad, manual gearbox Loose
22310439 Stop pad, manual gearbox Unpleasant noises
223104XX Stop pad, manual gearbox
2231XXXX Transmission mount, manual transmission
22320001 Automatic transmission mount, cross member Cracked / broken / torn off
22320037 Automatic transmission mount, cross member Loose
223200XX Automatic transmission mount, cross member
22320101 Automatic transmission mount, rubber/hydraulic mount Cracked / broken / torn off
22320137 Automatic transmission mount, rubber/hydraulic mount Loose
22320139 Automatic transmission mount, rubber/hydraulic mount Unpleasant noises
22320148 Automatic transmission mount, rubber/hydraulic mount Leaking
223201XX Automatic transmission mount, rubber/hydraulic mount
22320201 Vibration absorber (automatic transmission) Cracked / broken / torn off
22320237 Vibration absorber (automatic transmission) Loose
223202XX Vibration absorber (automatic transmission)
22320301 Heat shield for transmission cross member Cracked / broken / torn off
22320337 Heat shield for transmission cross member Loose
22320339 Heat shield for transmission cross member Unpleasant noises
223203XX Heat shield for transmission cross member
22320401 Stop pad, automatic gearbox Cracked / broken / torn off
22320439 Stop pad, automatic gearbox Unpleasant noises
223204XX Stop pad, automatic gearbox
22320501 Automatic gearbox mounting, gearbox mounting bracket Cracked / broken / torn off
22320537 Automatic gearbox mounting, gearbox mounting bracket Loose
223205XX Automatic gearbox mounting, gearbox mounting bracket
22329039 E38/730iA Transmission cross member
2232XXXX Transmission mount, automatic transmission
22XXXXXX Engine and transmission mounts
23000039 Manual transmission in neutral position Unpleasant noises
230000XX Manual transmission in neutral position
23000108 Manual transmission in 1st gear Jumps out
23000134 Manual transmission in 1st gear Stiff to move
23000139 Manual transmission in 1st gear Unpleasant noises
23000188 Manual transmission in 1st gear failing to synchronize
230001XX Manual transmission in 1st gear
23000208 Manual transmission in 2nd gear Jumps out
23000234 Manual transmission in 2nd gear Stiff to move
23000239 Manual transmission in 2nd gear Unpleasant noises
23000288 Manual transmission in 2nd gear failing to synchronize
230002XX Manual transmission in 2nd gear
23000308 Manual transmission in 3rd gear Jumps out
23000334 Manual transmission in 3rd gear Stiff to move
23000339 Manual transmission in 3rd gear Unpleasant noises
23000388 Manual transmission in 3rd gear failing to synchronize
230003XX Manual transmission in 3rd gear
23000408 Manual transmission in 4th gear Jumps out
23000434 Manual transmission in 4th gear Stiff to move
23000439 Manual transmission in 4th gear Unpleasant noises
23000488 Manual transmission in 4th gear failing to synchronize
230004XX Manual transmission in 4th gear
23000508 Manual transmission in 5th gear Jumps out
23000534 Manual transmission in 5th gear Stiff to move
23000539 Manual transmission in 5th gear Unpleasant noises
23000588 Manual transmission in 5th gear failing to synchronize
230005XX Manual transmission in 5th gear
23000608 Manual transmission in reverse Jumps out
23000634 Manual transmission in reverse Stiff to move
23000639 Manual transmission in reverse Unpleasant noises
23000688 Manual transmission in reverse failing to synchronize
230006XX Manual transmission in reverse
23000808 Manual transmission in 6th gear Jumps out
23000834 Manual transmission in 6th gear Stiff to move
23000839 Manual transmission in 6th gear Unpleasant noises
23000888 Manual transmission in 6th gear failing to synchronize
230008XX Manual transmission in 6th gear
23005039 Sequential M-transmission (SMG) upshift characteristics Unpleasant noises
23005061 Sequential M-transmission (SMG) upshift characteristics Too rough
23005083 Sequential M-transmission (SMG) upshift characteristics incorrect or no switching action
230050XX Sequential M-transmission (SMG) upshift characteristics
23005139 SMG downshift characteristics Unpleasant noises
23005161 SMG downshift characteristics Too rough
23005183 SMG downshift characteristics incorrect or no switching action
230051XX SMG downshift characteristics
23005227 SMG gear engagement (from 0) Locked/jammed
23005239 SMG gear engagement (from 0) Unpleasant noises
23005261 SMG gear engagement (from 0) Too rough
230052XX SMG gear engagement (from 0)
23005360 SMG cut-in delay (from 0) Too high
230053XX SMG cut-in delay (from 0)
23005583 SMG emergency mode program incorrect or no switching action
230055XX SMG emergency mode program
23005666 SMG forward power transmission No effect
230056XX SMG forward power transmission
23005766 SMG reverse power transmission No effect
230057XX SMG reverse power transmission
23005814 SMG shifting in neutral position Occasional malfunction
230058XX SMG shifting in neutral position
23005952 SMG clutch Not opening
230059XX SMG clutch
23009134 E39 M62 S62 D-transmission 3rd gear difficult to disengage
23009334 E39 E46 M47/TU M57 Gearbox (F-gearbox) - difficulty in shifting
23009434 E36/7 E38 E39 E46 E53 C-gearbox - difficulty in shifting
2300XXXX Manual gearbox (symptom defect codes)
23110048 Manual transmission assy Leaking
231100XX Manual transmission assy
23110148 Gearbox cover (MINI) Leaking
231101XX Gearbox cover (MINI)
23110354 Guide sleeve with flange Scratches, score marks
231103XX Guide sleeve with flange
23110648 Manual transmission drain plug Leaking
231106XX Manual transmission drain plug
23110848 Breather manual transmission casing Leaking
231108XX Breather manual transmission casing
23110948 Manual transmission casing parting joint Leaking
231109XX Manual transmission casing parting joint
23111048 Manual transmission rotary shaft seal, clutch end Leaking
231110XX Manual transmission rotary shaft seal, clutch end
23111148 Manual transmission rotary shaft seal, output flange Leaking
231111XX Manual transmission rotary shaft seal, output flange
23111248 Manual transmission rotary shaft seal, selector shaft Leaking
231112XX Manual transmission rotary shaft seal, selector shaft
2311XXXX Housing with cover
23140014 Reversing light switch Occasional malfunction
23140015 Reversing light switch Permanent malfunction
23140048 Reversing light switch Leaking
231400XX Reversing light switch
2314XXXX Electrical attachments
23211337 Output flange Loose
232113XX Output flange
2321XXXX Transmission shafts
23XXXXXX Manual transmission
24000048 Automatic transmission, complete Leaking
240000XX Automatic transmission, complete
24000139 Automatic transmission, forward gears, vehicle in motion Unpleasant noises
240001XX Automatic transmission, forward gears, vehicle in motion
24000639 Automatic transmission, reverse gear, vehicle in motion Unpleasant noises
240006XX Automatic transmission, reverse gear, vehicle in motion
24000739 Automatic transmission, forward gears, vehicle stationary Unpleasant noises
240007XX Automatic transmission, forward gears, vehicle stationary
24000839 Automatic transmission, reverse gear, vehicle stationary Unpleasant noises
240008XX Automatic transmission, reverse gear, vehicle stationary
24001739 Automatic transmission shift characteristics, upshifts Unpleasant noises
24001758 Automatic transmission shift characteristics, upshifts Slipping
24001761 Automatic transmission shift characteristics, upshifts Too rough
240017XX Automatic transmission shift characteristics, upshifts
24001839 Automatic transmission shift characteristics, downshifts Unpleasant noises
24001858 Automatic transmission shift characteristics, downshifts Slipping
24001861 Automatic transmission shift characteristics, downshifts Too rough
240018XX Automatic transmission shift characteristics, downshifts
24001939 Automatic transmission, selecting gear (from N or P) Unpleasant noises
24001961 Automatic transmission, selecting gear (from N or P) Too rough
240019XX Automatic transmission, selecting gear (from N or P)
24002060 Automatic transmission engagement delay (from N or P) Too high
240020XX Automatic transmission engagement delay (from N or P)
24002159 Automatic transmission shift frequency Too low / deep / slight
24002160 Automatic transmission shift frequency Too high
240021XX Automatic transmission shift frequency
24002239 Automatic transmission in normal/park setting (N/P) Unpleasant noises
240022XX Automatic transmission in normal/park setting (N/P)
24002383 Automatic transmission in emergency shift program incorrect or no switching action
240023XX Automatic transmission in emergency shift program
24002466 Automatic transmission, power transmission forward No effect
240024XX Automatic transmission, power transmission forward
24002566 Automatic transmission, power transmission back No effect
240025XX Automatic transmission, power transmission back
24002738 Start-off gearshift, automatic transmission Shaking
24002761 Start-off gearshift, automatic transmission Too rough
240027XX Start-off gearshift, automatic transmission
24009058 E36 E39 M44 M52 Fault code 111 (check engine lights or clutch slips)
24009061 E36 M52 B20 (Jatco transmission) harsh 1st-2nd gearshift during warm-up phase
24009111 E36 E39 E46 E53 M52 M54 (GM5) Position switch, fault code 60
24009161 E38 E39 M62 M57 Poor gearshift comfort (3rd - 2nd gearshift)
24009261 E36/7 E39 E46 E53 M54 M57 (GM5) Gearshift comfort
24009279 E38 E39 E53 M62 Automatic transmission fault code 34
24009396 E39 E46 M52 (GM5) Solenoid valve, converter lock-up clutch (fault code 48)
24009414 E38 E39 M57 M62 (5HP24) Harsh 3rd-4th/4th-3rd gearshift - emergency program
24009548 E38 E39 E53 M62 Leak at threaded connection of converter housing
24009839 E36/7 (with A4S 310R) Gearing/whistling noise
2400XXXX Automatic gearbox / ECVT (symptom defect codes)
24100014 Gearbox position switch Occasional malfunction
24100015 Gearbox position switch Permanent malfunction
241000XX Gearbox position switch
2410XXXX Gearbox casing with add-on parts
24309012 E36/7 E39 E46 E53 (GM5) No or harsh gearshift (control unit fault)
24339048 E36 E39 Sealing cap working piston leaking
24400261 Automatic transmission, converter clutch engagement (closing/opening) Too rough
244002XX Automatic transmission, converter clutch engagement (closing/opening)
24409057 E39 E46 M57 A Vibrations in speed range of 100 to 130 km/h
2440XXXX Torque converter
24530165 Automatic transmission parking lock Does not lock into position
245301XX Automatic transmission parking lock
24530252 Automatic gearbox parking lock - emergency release Not opening
24530253 Automatic gearbox parking lock - emergency release Not closing
245302XX Automatic gearbox parking lock - emergency release
2453XXXX Parking lock
24609161 E53 M54 (GM5) Poor gearshift quality (2nd - 3rd)
24619083 E39 E46 E53 M54 US GM5 - No 1st - 2nd upshift after uphill driving
