الجزء الثامن :
51472237 Convertible top compartment trim Loose
514722XX Convertible top compartment trim
51472337 Footwell stowage net (Z3/Z4) Loose
514723XX Footwell stowage net (Z3/Z4)
51479140 E39/2 E46/3 Roller cover tolerances in mounting mechanism - noise
5147XXXX Floor, luggage compartment, engine compartment trim
51480001 Noise-insulation on engine hood Cracked / broken / torn off
51480037 Noise-insulation on engine hood Loose
51480041 Noise-insulation on engine hood Poorly adapted/fitted
514800XX Noise-insulation on engine hood
51480101 Noise insulation (face wall, engine compartment) Cracked / broken / torn off
51480137 Noise insulation (face wall, engine compartment) Loose
514801XX Noise insulation (face wall, engine compartment)
51480237 Noise insulation (face wall, footwell) Loose
514802XX Noise insulation (face wall, footwell)
51480441 Sound insulation, door (film) Poorly adapted/fitted
514804XX Sound insulation, door (film)
5148XXXX Insulation trim panels
51490232 Boot sill cover Deformed / distorted / bent
514902XX Boot sill cover
5149XXXX Rear lid trim panel
51710001 Front door seals Cracked / broken / torn off
51710037 Front door seals Loose
51710039 Front door seals Unpleasant noises
51710041 Front door seals Poorly adapted/fitted
51710075 Front door seals corroded
517100XX Front door seals
51710101 Rear door seals Cracked / broken / torn off
51710137 Rear door seals Loose
51710139 Rear door seals Unpleasant noises
51710141 Rear door seals Poorly adapted/fitted
51710175 Rear door seals corroded
517101XX Rear door seals
51710201 Engine hood seals Cracked / broken / torn off
51710237 Engine hood seals Loose
517102XX Engine hood seals
51710301 Rear lid seals Cracked / broken / torn off
51710337 Rear lid seals Loose
51710341 Rear lid seals Poorly adapted/fitted
51710350 Rear lid seals Water ingress / condensate
517103XX Rear lid seals
51710701 Front spoiler Cracked / broken / torn off
51710732 Front spoiler Deformed / distorted / bent
51710737 Front spoiler Loose
51710741 Front spoiler Poorly adapted/fitted
51710767 Front spoiler Discoloured
517107XX Front spoiler
51710801 Rear spoiler Cracked / broken / torn off
51710832 Rear spoiler Deformed / distorted / bent
51710837 Rear spoiler Loose
51710841 Rear spoiler Poorly adapted/fitted
51710868 Rear spoiler Peels off / detaches itself
517108XX Rear spoiler
51710937 Finisher on wheel aperture Loose
51710941 Finisher on wheel aperture Poorly adapted/fitted
517109XX Finisher on wheel aperture
51711101 Roof frame gasket (E36/E53) Cracked / broken / torn off
51711132 Roof frame gasket (E36/E53) Deformed / distorted / bent
51711137 Roof frame gasket (E36/E53) Loose
51711139 Roof frame gasket (E36/E53) Unpleasant noises
517111XX Roof frame gasket (E36/E53)
51711437 Soft-top cover flap seal Loose
51711441 Soft-top cover flap seal Poorly adapted/fitted
51711448 Soft-top cover flap seal Leaking
517114XX Soft-top cover flap seal
51711501 Sill strip Cracked / broken / torn off
51711537 Sill strip Loose
51711541 Sill strip Poorly adapted/fitted
517115XX Sill strip
51711613 Jacking point Broken
51711637 Jacking point Loose
517116XX Jacking point
51711737 Lifting platform support Loose
517117XX Lifting platform support
51711813 Wheelhouse inner trim Broken
51711837 Wheelhouse inner trim Loose
517118XX Wheelhouse inner trim
51711901 Underbody panelling, fuel tank Cracked / broken / torn off
51711937 Underbody panelling, fuel tank Loose
517119XX Underbody panelling, fuel tank
51712237 Cover for towing eyes Loose
517122XX Cover for towing eyes
51712313 Body vibration damper Broken
51712337 Body vibration damper Loose
517123XX Body vibration damper
51712441 Seals, outer panel sections Poorly adapted/fitted
517124XX Seals, outer panel sections
51712639 Steering column support tube Unpleasant noises
517126XX Steering column support tube
51712713 Hinge cover, rear lid (Z3 coupé Broken
51712737 Hinge cover, rear lid (Z3 coupé Loose
517127XX Hinge cover, rear lid (Z3 coupé
51712813 Water channel finisher, rear lid (Z3 coupé Broken
51712837 Water channel finisher, rear lid (Z3 coupé Loose
517128XX Water channel finisher, rear lid (Z3 coupé
51712937 Entrance footboard, side (X5) Loose
51712941 Entrance footboard, side (X5) Poorly adapted/fitted
517129XX Entrance footboard, side (X5)
51713137 Scuttle cover, windscreen Loose
51713141 Scuttle cover, windscreen Poorly adapted/fitted
517131XX Scuttle cover, windscreen
51719485 E39 S62 Outside temperature indicator incorrect - engine compartment cover
51719537 E46/2 Door edge protector loose
5171XXXX Seals, loose sections of body
51720001 Edge protector (door aperture) Cracked / broken / torn off
51720037 Edge protector (door aperture) Loose
51720041 Edge protector (door aperture) Poorly adapted/fitted
51720069 Edge protector (door aperture) Worn / sheared through
517200XX Edge protector (door aperture)
51720301 Cover for hardtop locating point (cabriolet) Cracked / broken / torn off
51720337 Cover for hardtop locating point (cabriolet) Loose
517203XX Cover for hardtop locating point (cabriolet)
5172XXXX Piping and edge protection
51860101 Front seat cushion covering, fabric Cracked / broken / torn off
51860103 Front seat cushion covering, fabric Ripped
51860122 Front seat cushion covering, fabric Manufacturing fault
51860167 Front seat cushion covering, fabric Discoloured
51860169 Front seat cushion covering, fabric Worn / sheared through
518601XX Front seat cushion covering, fabric
51860201 Front seat backrest covering, fabric Cracked / broken / torn off
51860203 Front seat backrest covering, fabric Ripped
51860222 Front seat backrest covering, fabric Manufacturing fault
51860267 Front seat backrest covering, fabric Discoloured
51860269 Front seat backrest covering, fabric Worn / sheared through
518602XX Front seat backrest covering, fabric
51860301 Thigh support covering, fabric Cracked / broken / torn off
51860303 Thigh support covering, fabric Ripped
51860322 Thigh support covering, fabric Manufacturing fault
51860367 Thigh support covering, fabric Discoloured
51860369 Thigh support covering, fabric Worn / sheared through
518603XX Thigh support covering, fabric
51861001 Head restraint covering, fabric Cracked / broken / torn off
51861003 Head restraint covering, fabric Ripped
51861022 Head restraint covering, fabric Manufacturing fault
51861067 Head restraint covering, fabric Discoloured
51861069 Head restraint covering, fabric Worn / sheared through
518610XX Head restraint covering, fabric
51862001 Rear seat cushion covering, fabric Cracked / broken / torn off
51862003 Rear seat cushion covering, fabric Ripped
51862022 Rear seat cushion covering, fabric Manufacturing fault
51862067 Rear seat cushion covering, fabric Discoloured
51862069 Rear seat cushion covering, fabric Worn / sheared through
518620XX Rear seat cushion covering, fabric
51862101 Rear seat backrest covering, fabric Cracked / broken / torn off
51862103 Rear seat backrest covering, fabric Ripped
51862122 Rear seat backrest covering, fabric Manufacturing fault
51862167 Rear seat backrest covering, fabric Discoloured
51862169 Rear seat backrest covering, fabric Worn / sheared through
518621XX Rear seat backrest covering, fabric
51862201 Rear armrest covering, fabric Cracked / broken / torn off
51862203 Rear armrest covering, fabric Ripped
51862222 Rear armrest covering, fabric Manufacturing fault
51862267 Rear armrest covering, fabric Discoloured
51862269 Rear armrest covering, fabric Worn / sheared through
518622XX Rear armrest covering, fabric
5186XXXX Fabric covering material
51870101 Font seat cushion covering, imitation leather Cracked / broken / torn off
51870103 Font seat cushion covering, imitation leather Ripped
51870122 Font seat cushion covering, imitation leather Manufacturing fault
51870167 Font seat cushion covering, imitation leather Discoloured
51870169 Font seat cushion covering, imitation leather Worn / sheared through
518701XX Font seat cushion covering, imitation leather
51870201 Front seat backrest covering, imitation leather Cracked / broken / torn off
51870203 Front seat backrest covering, imitation leather Ripped
51870222 Front seat backrest covering, imitation leather Manufacturing fault
51870267 Front seat backrest covering, imitation leather Discoloured
51870269 Front seat backrest covering, imitation leather Worn / sheared through
518702XX Front seat backrest covering, imitation leather
51870301 Thigh support covering, imitation leather Cracked / broken / torn off
51870303 Thigh support covering, imitation leather Ripped
51870322 Thigh support covering, imitation leather Manufacturing fault
51870367 Thigh support covering, imitation leather Discoloured
51870369 Thigh support covering, imitation leather Worn / sheared through
518703XX Thigh support covering, imitation leather
51870401 Front armrest covering, imitation leather Cracked / broken / torn off
51870403 Front armrest covering, imitation leather Ripped
51870422 Front armrest covering, imitation leather Manufacturing fault
51870467 Front armrest covering, imitation leather Discoloured
51870469 Front armrest covering, imitation leather Worn / sheared through
518704XX Front armrest covering, imitation leather
51871001 Head restraint covering, imitation leather Cracked / broken / torn off
51871003 Head restraint covering, imitation leather Ripped
51871022 Head restraint covering, imitation leather Manufacturing fault
51871067 Head restraint covering, imitation leather Discoloured
51871069 Head restraint covering, imitation leather Worn / sheared through
518710XX Head restraint covering, imitation leather
51872001 Rear seat cushion covering, imitation leather Cracked / broken / torn off
51872003 Rear seat cushion covering, imitation leather Ripped
51872022 Rear seat cushion covering, imitation leather Manufacturing fault
51872067 Rear seat cushion covering, imitation leather Discoloured
51872069 Rear seat cushion covering, imitation leather Worn / sheared through
518720XX Rear seat cushion covering, imitation leather
51872101 Rear seat backrest covering, imitation leather Cracked / broken / torn off
51872103 Rear seat backrest covering, imitation leather Ripped
51872122 Rear seat backrest covering, imitation leather Manufacturing fault
51872167 Rear seat backrest covering, imitation leather Discoloured
51872169 Rear seat backrest covering, imitation leather Worn / sheared through
518721XX Rear seat backrest covering, imitation leather
51872201 Rear armrest covering, imitation leather Cracked / broken / torn off
51872203 Rear armrest covering, imitation leather Ripped
51872222 Rear armrest covering, imitation leather Manufacturing fault
51872267 Rear armrest covering, imitation leather Discoloured
51872269 Rear armrest covering, imitation leather Worn / sheared through
518722XX Rear armrest covering, imitation leather
51873101 Soft-top cover flap covering, imitation leather Cracked / broken / torn off
51873103 Soft-top cover flap covering, imitation leather Ripped
51873122 Soft-top cover flap covering, imitation leather Manufacturing fault
51873130 Soft-top cover flap covering, imitation leather Blistering
51873167 Soft-top cover flap covering, imitation leather Discoloured
51873169 Soft-top cover flap covering, imitation leather Worn / sheared through
518731XX Soft-top cover flap covering, imitation leather
5187XXXX Imitation leather covering material
51880101 Front seat cushion covering, leather Cracked / broken / torn off
51880103 Front seat cushion covering, leather Ripped
51880122 Front seat cushion covering, leather Manufacturing fault
51880136 Front seat cushion covering, leather Dented/wavy
51880167 Front seat cushion covering, leather Discoloured
51880169 Front seat cushion covering, leather Worn / sheared through
518801XX Front seat cushion covering, leather
51880201 Front seat backrest covering, leather Cracked / broken / torn off
51880203 Front seat backrest covering, leather Ripped
51880222 Front seat backrest covering, leather Manufacturing fault
51880267 Front seat backrest covering, leather Discoloured
51880269 Front seat backrest covering, leather Worn / sheared through
518802XX Front seat backrest covering, leather
51880301 Front armrest covering, leather Cracked / broken / torn off
51880303 Front armrest covering, leather Ripped
51880322 Front armrest covering, leather Manufacturing fault
51880367 Front armrest covering, leather Discoloured
51880369 Front armrest covering, leather Worn / sheared through
518803XX Front armrest covering, leather
51880401 Thigh support covering, leather Cracked / broken / torn off
51880403 Thigh support covering, leather Ripped
51880422 Thigh support covering, leather Manufacturing fault
51880467 Thigh support covering, leather Discoloured
51880469 Thigh support covering, leather Worn / sheared through
518804XX Thigh support covering, leather
51880501 Heat restraint covering, leather Cracked / broken / torn off
51880503 Heat restraint covering, leather Ripped
51880522 Heat restraint covering, leather Manufacturing fault
51880567 Heat restraint covering, leather Discoloured
51880569 Heat restraint covering, leather Worn / sheared through
518805XX Heat restraint covering, leather
51880601 Convertible top compartment lid cover, leather Cracked / broken / torn off
51880603 Convertible top compartment lid cover, leather Ripped
51880622 Convertible top compartment lid cover, leather Manufacturing fault
51880630 Convertible top compartment lid cover, leather Blistering
51880667 Convertible top compartment lid cover, leather Discoloured
51880669 Convertible top compartment lid cover, leather Worn / sheared through
518806XX Convertible top compartment lid cover, leather
51882101 Rear seat cushion covering, leather Cracked / broken / torn off
51882103 Rear seat cushion covering, leather Ripped
51882122 Rear seat cushion covering, leather Manufacturing fault
51882136 Rear seat cushion covering, leather Dented/wavy
51882167 Rear seat cushion covering, leather Discoloured
51882169 Rear seat cushion covering, leather Worn / sheared through
518821XX Rear seat cushion covering, leather
51882201 Rear seat backrest covering, leather Cracked / broken / torn off
51882203 Rear seat backrest covering, leather Ripped
51882222 Rear seat backrest covering, leather Manufacturing fault
51882267 Rear seat backrest covering, leather Discoloured
51882269 Rear seat backrest covering, leather Worn / sheared through
518822XX Rear seat backrest covering, leather
51882301 Rear armrest covering, leather Cracked / broken / torn off
51882303 Rear armrest covering, leather Ripped
51882322 Rear armrest covering, leather Manufacturing fault
51882367 Rear armrest covering, leather Discoloured
51882369 Rear armrest covering, leather Worn / sheared through
518823XX Rear armrest covering, leather
51883101 Front door trim material, imitation leather/fabric Cracked / broken / torn off
51883103 Front door trim material, imitation leather/fabric Ripped
51883122 Front door trim material, imitation leather/fabric Manufacturing fault
51883167 Front door trim material, imitation leather/fabric Discoloured
51883169 Front door trim material, imitation leather/fabric Worn / sheared through
518831XX Front door trim material, imitation leather/fabric
51883201 Rear door trim material, imitation leather/fabric Cracked / broken / torn off
51883203 Rear door trim material, imitation leather/fabric Ripped
51883222 Rear door trim material, imitation leather/fabric Manufacturing fault
51883267 Rear door trim material, imitation leather/fabric Discoloured
51883269 Rear door trim material, imitation leather/fabric Worn / sheared through
518832XX Rear door trim material, imitation leather/fabric
51883301 Rear side panel trim material, imitation leather/fabric Cracked / broken / torn off
51883303 Rear side panel trim material, imitation leather/fabric Ripped
51883322 Rear side panel trim material, imitation leather/fabric Manufacturing fault
51883367 Rear side panel trim material, imitation leather/fabric Discoloured
51883369 Rear side panel trim material, imitation leather/fabric Worn / sheared through
518833XX Rear side panel trim material, imitation leather/fabric
51884101 Front door trim material, leather Cracked / broken / torn off
51884103 Front door trim material, leather Ripped
51884122 Front door trim material, leather Manufacturing fault
51884167 Front door trim material, leather Discoloured
51884169 Front door trim material, leather Worn / sheared through
518841XX Front door trim material, leather
51884201 Rear door trim material, leather Cracked / broken / torn off
51884203 Rear door trim material, leather Ripped
51884222 Rear door trim material, leather Manufacturing fault
51884267 Rear door trim material, leather Discoloured
51884269 Rear door trim material, leather Worn / sheared through
518842XX Rear door trim material, leather
51884301 Rear side panel trim material, leather Cracked / broken / torn off
51884303 Rear side panel trim material, leather Ripped
51884322 Rear side panel trim material, leather Manufacturing fault
51884367 Rear side panel trim material, leather Discoloured
51884369 Rear side panel trim material, leather Worn / sheared through
518843XX Rear side panel trim material, leather
5188XXXX Leather covering material
51910101 Paintwork, door and roof pillars Cracked / broken / torn off
51910130 Paintwork, door and roof pillars Blistering
51910154 Paintwork, door and roof pillars Scratches, score marks
51910168 Paintwork, door and roof pillars Peels off / detaches itself
51910190 Paintwork, door and roof pillars dirt inclusions
51910191 Paintwork, door and roof pillars colour differences
51910192 Paintwork, door and roof pillars paint run
51910193 Paintwork, door and roof pillars too thin
51910195 Paintwork, door and roof pillars cloudy paint surface
519101XX Paintwork, door and roof pillars
51910201 Paintwork, roof Cracked / broken / torn off
51910230 Paintwork, roof Blistering
51910254 Paintwork, roof Scratches, score marks
51910268 Paintwork, roof Peels off / detaches itself
51910290 Paintwork, roof dirt inclusions
51910291 Paintwork, roof colour differences
51910292 Paintwork, roof paint run
51910293 Paintwork, roof too thin
51910295 Paintwork, roof cloudy paint surface
519102XX Paintwork, roof
51910301 Paintwork, sunroof (SHD) Cracked / broken / torn off
51910330 Paintwork, sunroof (SHD) Blistering
51910354 Paintwork, sunroof (SHD) Scratches, score marks
51910368 Paintwork, sunroof (SHD) Peels off / detaches itself
51910390 Paintwork, sunroof (SHD) dirt inclusions
51910391 Paintwork, sunroof (SHD) colour differences
51910392 Paintwork, sunroof (SHD) paint run
51910393 Paintwork, sunroof (SHD) too thin
51910395 Paintwork, sunroof (SHD) cloudy paint surface
519103XX Paintwork, sunroof (SHD)
51910401 Paintwork, engine hood Cracked / broken / torn off
51910430 Paintwork, engine hood Blistering
51910454 Paintwork, engine hood Scratches, score marks
51910468 Paintwork, engine hood Peels off / detaches itself
51910490 Paintwork, engine hood dirt inclusions
51910491 Paintwork, engine hood colour differences
51910492 Paintwork, engine hood paint run
51910493 Paintwork, engine hood too thin
51910495 Paintwork, engine hood cloudy paint surface
519104XX Paintwork, engine hood
51910501 Paintwork, front trim Cracked / broken / torn off
51910530 Paintwork, front trim Blistering
51910554 Paintwork, front trim Scratches, score marks
51910568 Paintwork, front trim Peels off / detaches itself
51910590 Paintwork, front trim dirt inclusions
51910591 Paintwork, front trim colour differences
51910592 Paintwork, front trim paint run
51910593 Paintwork, front trim too thin
51910595 Paintwork, front trim cloudy paint surface
519105XX Paintwork, front trim
51910601 Paintwork, rear lid Cracked / broken / torn off
51910630 Paintwork, rear lid Blistering
51910654 Paintwork, rear lid Scratches, score marks
51910668 Paintwork, rear lid Peels off / detaches itself
51910690 Paintwork, rear lid dirt inclusions
51910691 Paintwork, rear lid colour differences
51910692 Paintwork, rear lid paint run
51910693 Paintwork, rear lid too thin
51910695 Paintwork, rear lid cloudy paint surface
519106XX Paintwork, rear lid
51910701 Paintwork, tail panel Cracked / broken / torn off
51910730 Paintwork, tail panel Blistering
51910754 Paintwork, tail panel Scratches, score marks
51910768 Paintwork, tail panel Peels off / detaches itself
51910790 Paintwork, tail panel dirt inclusions
51910791 Paintwork, tail panel colour differences
51910792 Paintwork, tail panel paint run
51910793 Paintwork, tail panel too thin
51910795 Paintwork, tail panel cloudy paint surface
519107XX Paintwork, tail panel
51910801 Paintwork, side panels/body mouldings, front Cracked / broken / torn off
51910830 Paintwork, side panels/body mouldings, front Blistering
51910854 Paintwork, side panels/body mouldings, front Scratches, score marks
51910868 Paintwork, side panels/body mouldings, front Peels off / detaches itself
51910890 Paintwork, side panels/body mouldings, front dirt inclusions
51910891 Paintwork, side panels/body mouldings, front colour differences
51910892 Paintwork, side panels/body mouldings, front paint run
51910893 Paintwork, side panels/body mouldings, front too thin
51910895 Paintwork, side panels/body mouldings, front cloudy paint surface
519108XX Paintwork, side panels/body mouldings, front
51910901 Paintwork, side panels/body mouldings, rear Cracked / broken / torn off
51910930 Paintwork, side panels/body mouldings, rear Blistering
51910954 Paintwork, side panels/body mouldings, rear Scratches, score marks
51910968 Paintwork, side panels/body mouldings, rear Peels off / detaches itself
51910990 Paintwork, side panels/body mouldings, rear dirt inclusions
51910991 Paintwork, side panels/body mouldings, rear colour differences
51910992 Paintwork, side panels/body mouldings, rear paint run
51910993 Paintwork, side panels/body mouldings, rear too thin
51910995 Paintwork, side panels/body mouldings, rear cloudy paint surface
519109XX Paintwork, side panels/body mouldings, rear
51911001 Paintwork, doors/body mouldings, front Cracked / broken / torn off
51911030 Paintwork, doors/body mouldings, front Blistering
51911054 Paintwork, doors/body mouldings, front Scratches, score marks
51911068 Paintwork, doors/body mouldings, front Peels off / detaches itself
51911090 Paintwork, doors/body mouldings, front dirt inclusions
51911091 Paintwork, doors/body mouldings, front colour differences
51911092 Paintwork, doors/body mouldings, front paint run
51911093 Paintwork, doors/body mouldings, front too thin
51911095 Paintwork, doors/body mouldings, front cloudy paint surface
519110XX Paintwork, doors/body mouldings, front
51911101 Paintwork, doors/body mouldings, rear Cracked / broken / torn off
51911130 Paintwork, doors/body mouldings, rear Blistering
51911154 Paintwork, doors/body mouldings, rear Scratches, score marks
51911168 Paintwork, doors/body mouldings, rear Peels off / detaches itself
51911190 Paintwork, doors/body mouldings, rear dirt inclusions
51911191 Paintwork, doors/body mouldings, rear colour differences
51911192 Paintwork, doors/body mouldings, rear paint run
51911193 Paintwork, doors/body mouldings, rear too thin
51911195 Paintwork, doors/body mouldings, rear cloudy paint surface
519111XX Paintwork, doors/body mouldings, rear
51911201 Paintwork, tank flap Cracked / broken / torn off
51911230 Paintwork, tank flap Blistering
51911254 Paintwork, tank flap Scratches, score marks
51911268 Paintwork, tank flap Peels off / detaches itself
51911290 Paintwork, tank flap dirt inclusions
51911291 Paintwork, tank flap colour differences
51911292 Paintwork, tank flap paint run
51911293 Paintwork, tank flap too thin
51911295 Paintwork, tank flap cloudy paint surface
519112XX Paintwork, tank flap
51911368 Paintwork, floor plan Peels off / detaches itself
519113XX Paintwork, floor plan
51911401 Paintwork, steel disc wheel/aluminium wheel Cracked / broken / torn off
51911430 Paintwork, steel disc wheel/aluminium wheel Blistering
51911454 Paintwork, steel disc wheel/aluminium wheel Scratches, score marks
51911468 Paintwork, steel disc wheel/aluminium wheel Peels off / detaches itself
51911475 Paintwork, steel disc wheel/aluminium wheel corroded
51911490 Paintwork, steel disc wheel/aluminium wheel dirt inclusions
51911492 Paintwork, steel disc wheel/aluminium wheel paint run
51911493 Paintwork, steel disc wheel/aluminium wheel too thin
519114XX Paintwork, steel disc wheel/aluminium wheel
51911501 Paintwork, hinges Cracked / broken / torn off
51911530 Paintwork, hinges Blistering
51911554 Paintwork, hinges Scratches, score marks
51911568 Paintwork, hinges Peels off / detaches itself
51911590 Paintwork, hinges dirt inclusions
51911592 Paintwork, hinges paint run
51911593 Paintwork, hinges too thin
51911595 Paintwork, hinges cloudy paint surface
519115XX Paintwork, hinges
51911701 Paintwork, door sill Cracked / broken / torn off
51911730 Paintwork, door sill Blistering
51911754 Paintwork, door sill Scratches, score marks
51911768 Paintwork, door sill Peels off / detaches itself
51911790 Paintwork, door sill dirt inclusions
51911791 Paintwork, door sill colour differences
51911792 Paintwork, door sill paint run
51911793 Paintwork, door sill too thin
51911795 Paintwork, door sill cloudy paint surface
519117XX Paintwork, door sill
51912001 Paintwork, complete body****l Cracked / broken / torn off
51912030 Paintwork, complete body****l Blistering
51912054 Paintwork, complete body****l Scratches, score marks
51912068 Paintwork, complete body****l Peels off / detaches itself
51912090 Paintwork, complete body****l dirt inclusions
51912091 Paintwork, complete body****l colour differences
51912092 Paintwork, complete body****l paint run
51912093 Paintwork, complete body****l too thin
51912095 Paintwork, complete body****l cloudy paint surface
519120XX Paintwork, complete body****l
51912201 Paintwork, door handles Cracked / broken / torn off
51912230 Paintwork, door handles Blistering
51912254 Paintwork, door handles Scratches, score marks
51912268 Paintwork, door handles Peels off / detaches itself
51912290 Paintwork, door handles dirt inclusions
51912291 Paintwork, door handles colour differences
51912292 Paintwork, door handles paint run
51912293 Paintwork, door handles too thin
51912295 Paintwork, door handles cloudy paint surface
519122XX Paintwork, door handles
51912401 Paintwork, air inlet grille, heating Cracked / broken / torn off
51912430 Paintwork, air inlet grille, heating Blistering
51912454 Paintwork, air inlet grille, heating Scratches, score marks
51912468 Paintwork, air inlet grille, heating Peels off / detaches itself
51912490 Paintwork, air inlet grille, heating dirt inclusions
51912491 Paintwork, air inlet grille, heating colour differences
51912492 Paintwork, air inlet grille, heating paint run
51912493 Paintwork, air inlet grille, heating too thin
51912495 Paintwork, air inlet grille, heating cloudy paint surface
519124XX Paintwork, air inlet grille, heating
51912501 Paintwork, front windscreen panel Cracked / broken / torn off
51912530 Paintwork, front windscreen panel Blistering
51912554 Paintwork, front windscreen panel Scratches, score marks
51912568 Paintwork, front windscreen panel Peels off / detaches itself
51912590 Paintwork, front windscreen panel dirt inclusions
51912591 Paintwork, front windscreen panel colour differences
51912592 Paintwork, front windscreen panel paint run
51912593 Paintwork, front windscreen panel too thin
51912595 Paintwork, front windscreen panel cloudy paint surface
519125XX Paintwork, front windscreen panel
51912601 Paintwork, rear window **** panel Cracked / broken / torn off
51912630 Paintwork, rear window **** panel Blistering
51912654 Paintwork, rear window **** panel Scratches, score marks
51912668 Paintwork, rear window **** panel Peels off / detaches itself
51912690 Paintwork, rear window **** panel dirt inclusions
51912691 Paintwork, rear window **** panel colour differences
51912692 Paintwork, rear window **** panel paint run
51912693 Paintwork, rear window **** panel too thin
51912695 Paintwork, rear window **** panel cloudy paint surface
519126XX Paintwork, rear window **** panel
51912701 Paintwork, rear spoiler/wing Cracked / broken / torn off
51912730 Paintwork, rear spoiler/wing Blistering
51912754 Paintwork, rear spoiler/wing Scratches, score marks
51912768 Paintwork, rear spoiler/wing Peels off / detaches itself
51912790 Paintwork, rear spoiler/wing dirt inclusions
51912791 Paintwork, rear spoiler/wing colour differences
51912792 Paintwork, rear spoiler/wing paint run
51912793 Paintwork, rear spoiler/wing too thin
51912795 Paintwork, rear spoiler/wing cloudy paint surface
519127XX Paintwork, rear spoiler/wing
51912801 Paintwork, rear apron Cracked / broken / torn off
51912830 Paintwork, rear apron Blistering
51912854 Paintwork, rear apron Scratches, score marks
51912868 Paintwork, rear apron Peels off / detaches itself
51912890 Paintwork, rear apron dirt inclusions
51912891 Paintwork, rear apron colour differences
51912892 Paintwork, rear apron paint run
51912893 Paintwork, rear apron too thin
51912895 Paintwork, rear apron cloudy paint surface
519128XX Paintwork, rear apron
51912901 Paintwork, door sill strips Cracked / broken / torn off
51912930 Paintwork, door sill strips Blistering
51912954 Paintwork, door sill strips Scratches, score marks
51912968 Paintwork, door sill strips Peels off / detaches itself
51912990 Paintwork, door sill strips dirt inclusions
51912991 Paintwork, door sill strips colour differences
51912992 Paintwork, door sill strips paint run
51912993 Paintwork, door sill strips too thin
51912995 Paintwork, door sill strips cloudy paint surface
519129XX Paintwork, door sill strips
51913101 Paintwork, front bumper Cracked / broken / torn off
51913130 Paintwork, front bumper Blistering
51913154 Paintwork, front bumper Scratches, score marks
51913168 Paintwork, front bumper Peels off / detaches itself
51913190 Paintwork, front bumper dirt inclusions
51913191 Paintwork, front bumper colour differences
51913192 Paintwork, front bumper paint run
51913193 Paintwork, front bumper too thin
51913195 Paintwork, front bumper cloudy paint surface
519131XX Paintwork, front bumper
51913201 Paintwork, rear bumper Cracked / broken / torn off
51913230 Paintwork, rear bumper Blistering
51913254 Paintwork, rear bumper Scratches, score marks
51913268 Paintwork, rear bumper Peels off / detaches itself
51913290 Paintwork, rear bumper dirt inclusions
51913291 Paintwork, rear bumper colour differences
51913292 Paintwork, rear bumper paint run
51913293 Paintwork, rear bumper too thin
51913295 Paintwork, rear bumper cloudy paint surface
519132XX Paintwork, rear bumper
51913301 Paintwork, light alloy wheels Cracked / broken / torn off
51913330 Paintwork, light alloy wheels Blistering
51913354 Paintwork, light alloy wheels Scratches, score marks
51913368 Paintwork, light alloy wheels Peels off / detaches itself
51913375 Paintwork, light alloy wheels corroded
51913390 Paintwork, light alloy wheels dirt inclusions
51913391 Paintwork, light alloy wheels colour differences
51913392 Paintwork, light alloy wheels paint run
51913393 Paintwork, light alloy wheels too thin
51913395 Paintwork, light alloy wheels cloudy paint surface
519133XX Paintwork, light alloy wheels
51913401 Paintwork, soft-top cover flap Cracked / broken / torn off
51913430 Paintwork, soft-top cover flap Blistering
51913454 Paintwork, soft-top cover flap Scratches, score marks
51913468 Paintwork, soft-top cover flap Peels off / detaches itself
51913490 Paintwork, soft-top cover flap dirt inclusions
51913491 Paintwork, soft-top cover flap colour differences
51913492 Paintwork, soft-top cover flap paint run
51913493 Paintwork, soft-top cover flap too thin
51913495 Paintwork, soft-top cover flap cloudy paint surface
519134XX Paintwork, soft-top cover flap
51913501 Paintwork, outside mirror housing Cracked / broken / torn off
51913530 Paintwork, outside mirror housing Blistering
51913554 Paintwork, outside mirror housing Scratches, score marks
51913568 Paintwork, outside mirror housing Peels off / detaches itself
51913590 Paintwork, outside mirror housing dirt inclusions
51913591 Paintwork, outside mirror housing colour differences
51913592 Paintwork, outside mirror housing paint run
51913593 Paintwork, outside mirror housing too thin
51913595 Paintwork, outside mirror housing cloudy paint surface
519135XX Paintwork, outside mirror housing
51913601 Paintwork, hardtop Cracked / broken / torn off
51913630 Paintwork, hardtop Blistering
51913654 Paintwork, hardtop Scratches, score marks
51913668 Paintwork, hardtop Peels off / detaches itself
51913690 Paintwork, hardtop dirt inclusions
51913691 Paintwork, hardtop colour differences
51913692 Paintwork, hardtop paint run
51913693 Paintwork, hardtop too thin
51913695 Paintwork, hardtop cloudy paint surface
519136XX Paintwork, hardtop
51913701 Paintwork, upper section of pop-up headlight Cracked / broken / torn off
51913730 Paintwork, upper section of pop-up headlight Blistering
51913754 Paintwork, upper section of pop-up headlight Scratches, score marks
51913768 Paintwork, upper section of pop-up headlight Peels off / detaches itself
51913790 Paintwork, upper section of pop-up headlight dirt inclusions
51913791 Paintwork, upper section of pop-up headlight colour differences
51913792 Paintwork, upper section of pop-up headlight paint run
51913793 Paintwork, upper section of pop-up headlight too thin
51913795 Paintwork, upper section of pop-up headlight cloudy paint surface
519137XX Paintwork, upper section of pop-up headlight
51913801 Paintwork, bottom section of tailgate (X5) Cracked / broken / torn off
51913830 Paintwork, bottom section of tailgate (X5) Blistering
51913854 Paintwork, bottom section of tailgate (X5) Scratches, score marks
51913868 Paintwork, bottom section of tailgate (X5) Peels off / detaches itself
51913890 Paintwork, bottom section of tailgate (X5) dirt inclusions
51913891 Paintwork, bottom section of tailgate (X5) colour differences
51913892 Paintwork, bottom section of tailgate (X5) paint run
51913893 Paintwork, bottom section of tailgate (X5) too thin
51913895 Paintwork, bottom section of tailgate (X5) cloudy paint surface
519138XX Paintwork, bottom section of tailgate (X5)
51913901 Paintwork, tail light cover Cracked / broken / torn off
51913930 Paintwork, tail light cover Blistering
51913954 Paintwork, tail light cover Scratches, score marks
51913968 Paintwork, tail light cover Peels off / detaches itself
51913990 Paintwork, tail light cover dirt inclusions
51913991 Paintwork, tail light cover colour differences
51913992 Paintwork, tail light cover paint run
51913993 Paintwork, tail light cover too thin
51913995 Paintwork, tail light cover cloudy paint surface
519139XX Paintwork, tail light cover
51914001 Paintwork, cover for rear window frame (Z4) Cracked / broken / torn off
51914030 Paintwork, cover for rear window frame (Z4) Blistering
51914054 Paintwork, cover for rear window frame (Z4) Scratches, score marks
51914068 Paintwork, cover for rear window frame (Z4) Peels off / detaches itself
51914090 Paintwork, cover for rear window frame (Z4) dirt inclusions
51914091 Paintwork, cover for rear window frame (Z4) colour differences
51914092 Paintwork, cover for rear window frame (Z4) paint run
51914093 Paintwork, cover for rear window frame (Z4) too thin
51914095 Paintwork, cover for rear window frame (Z4) cloudy paint surface
519140XX Paintwork, cover for rear window frame (Z4)
51915201 Body paintwork, side panels/body mouldings Cracked / broken / torn off
51915230 Body paintwork, side panels/body mouldings Blistering
51915254 Body paintwork, side panels/body mouldings Scratches, score marks
51915268 Body paintwork, side panels/body mouldings Peels off / detaches itself
51915290 Body paintwork, side panels/body mouldings dirt inclusions
51915291 Body paintwork, side panels/body mouldings colour differences
51915292 Body paintwork, side panels/body mouldings paint run
51915293 Body paintwork, side panels/body mouldings too thin
51915295 Body paintwork, side panels/body mouldings cloudy paint surface
519152XX Body paintwork, side panels/body mouldings
51915301 Paintwork, front body parts Cracked / broken / torn off
51915330 Paintwork, front body parts Blistering
51915354 Paintwork, front body parts Scratches, score marks
51915368 Paintwork, front body parts Peels off / detaches itself
51915390 Paintwork, front body parts dirt inclusions
51915391 Paintwork, front body parts colour differences
51915392 Paintwork, front body parts paint run
51915393 Paintwork, front body parts too thin
51915395 Paintwork, front body parts cloudy paint surface
519153XX Paintwork, front body parts
51915401 Paintwork, rear body parts Cracked / broken / torn off
51915430 Paintwork, rear body parts Blistering
51915454 Paintwork, rear body parts Scratches, score marks
51915468 Paintwork, rear body parts Peels off / detaches itself
51915490 Paintwork, rear body parts dirt inclusions
51915491 Paintwork, rear body parts colour differences
51915492 Paintwork, rear body parts paint run
51915493 Paintwork, rear body parts too thin
51915495 Paintwork, rear body parts cloudy paint surface
519154XX Paintwork, rear body parts
5191XXXX Colours, paint and basic material
51970168 Corrosion protection Peels off / detaches itself
51970193 Corrosion protection too thin
519701XX Corrosion protection
51970249 Hollow cavity protection Overflowing / sloshing over
519702XX Hollow cavity protection
5197XXXX Corrosion protection
51XXXXXX Body equipment
52100113 Seat rail cover (seat control cover) Broken
52100137 Seat rail cover (seat control cover) Loose
521001XX Seat rail cover (seat control cover)
52100213 Front/back seat adjustment (seat rail) Broken
52100229 Front/back seat adjustment (seat rail) Sticking/jammed
52100231 Front/back seat adjustment (seat rail) Excessive play
52100265 Front/back seat adjustment (seat rail) Does not lock into position
521002XX Front/back seat adjustment (seat rail)
52100313 Seat backrest adjustment Broken
52100329 Seat backrest adjustment Sticking/jammed
52100331 Seat backrest adjustment Excessive play
52100365 Seat backrest adjustment Does not lock into position
521003XX Seat backrest adjustment
52100513 Backrest folding function (rear entry) Broken
52100529 Backrest folding function (rear entry) Sticking/jammed
52100531 Backrest folding function (rear entry) Excessive play
52100565 Backrest folding function (rear entry) Does not lock into position
521005XX Backrest folding function (rear entry)
52100613 Seat height adjustment Broken
52100629 Seat height adjustment Sticking/jammed
52100631 Seat height adjustment Excessive play
52100665 Seat height adjustment Does not lock into position
521006XX Seat height adjustment
52100813 Thigh support Broken
52100829 Thigh support Sticking/jammed
52100831 Thigh support Excessive play
521008XX Thigh support
52100913 Seat angle adjustment Broken
52100929 Seat angle adjustment Sticking/jammed
52100931 Seat angle adjustment Excessive play
52100965 Seat angle adjustment Does not lock into position
521009XX Seat angle adjustment
52101013 Seat pan Broken
52101039 Seat pan Unpleasant noises
52101078 Seat pan poor surface finish
521010XX Seat pan
52101113 Front seat frame Broken
52101139 Front seat frame Unpleasant noises
521011XX Front seat frame
52101201 Seat cushion (foam part), front Cracked / broken / torn off
52101261 Seat cushion (foam part), front Too rough
52101262 Seat cushion (foam part), front Too soft
521012XX Seat cushion (foam part), front
52101413 Front seat backrest frame, complete Broken
