(اهداء) الجزء التاسع- الدليل الشامل لرموز أخطاء جميع فئات bmw ومعانيها
الجزء التاسع :
52101432 Front seat backrest frame, complete Deformed / distorted / bent
52101439 Front seat backrest frame, complete Unpleasant noises
521014XX Front seat backrest frame, complete
52101513 Front seat backrest panel with net pocket/backrest pocket Broken
52101537 Front seat backrest panel with net pocket/backrest pocket Loose
52101539 Front seat backrest panel with net pocket/backrest pocket Unpleasant noises
521015XX Front seat backrest panel with net pocket/backrest pocket
52101729 Front head restraints Sticking/jammed
52101731 Front head restraints Excessive play
52101765 Front head restraints Does not lock into position
521017XX Front head restraints
52102114 Lumbar support, front Occasional malfunction
52102115 Lumbar support, front Permanent malfunction
52102139 Lumbar support, front Unpleasant noises
52102148 Lumbar support, front Leaking
521021XX Lumbar support, front
52103013 Seat adjustment, actuating unit Broken
52103029 Seat adjustment, actuating unit Sticking/jammed
52103031 Seat adjustment, actuating unit Excessive play
52103037 Seat adjustment, actuating unit Loose
521030XX Seat adjustment, actuating unit
52103101 Seat adjustment, Bowden cable Cracked / broken / torn off
52103140 Seat adjustment, Bowden cable Poorly adjusted / outside tolerance
521031XX Seat adjustment, Bowden cable
52103201 Backrest support (foam part), front Cracked / broken / torn off
52103261 Backrest support (foam part), front Too rough
52103262 Backrest support (foam part), front Too soft
521032XX Backrest support (foam part), front
52103313 Seatbelt buckle/belt guide, seat backrest (Z3/Z4) Broken
52103378 Seatbelt buckle/belt guide, seat backrest (Z3/Z4) poor surface finish
521033XX Seatbelt buckle/belt guide, seat backrest (Z3/Z4)
52103411 Seat width adjustment Occasional failure
52103412 Seat width adjustment Permanent failure
521034XX Seat width adjustment
52103701 Folding table in seat backrest trim Cracked / broken / torn off
52103732 Folding table in seat backrest trim Deformed / distorted / bent
52103737 Folding table in seat backrest trim Loose
521037XX Folding table in seat backrest trim
52103934 Surround trim for seat belt and front head restraint Stiff to move
52103978 Surround trim for seat belt and front head restraint poor surface finish
521039XX Surround trim for seat belt and front head restraint
52104014 Adjustment for upper section of backrest Occasional malfunction
52104015 Adjustment for upper section of backrest Permanent malfunction
52104029 Adjustment for upper section of backrest Sticking/jammed
52104031 Adjustment for upper section of backrest Excessive play
521040XX Adjustment for upper section of backrest
52104129 Adjustable side section (cheeks), front head restraint Sticking/jammed
52104165 Adjustable side section (cheeks), front head restraint Does not lock into position
521041XX Adjustable side section (cheeks), front head restraint
52104214 Active seat drive Occasional malfunction
52104215 Active seat drive Permanent malfunction
52104239 Active seat drive Unpleasant noises
521042XX Active seat drive
52104329 Easy entry to rear Sticking/jammed
52104334 Easy entry to rear Stiff to move
521043XX Easy entry to rear
52104437 Cover for backrest adjustment, front seat Loose
52104478 Cover for backrest adjustment, front seat poor surface finish
521044XX Cover for backrest adjustment, front seat
52109139 E46 Noise from sports seat
52109339 R50 R53 Vertically adjustable front seat squeaking noise
52109401 E65 Backrest width adjustment pushes through
52109511 E52 Seat, electrical malfunction
5210XXXX Front seats
52200313 Rear seat backrest frame Broken
52200332 Rear seat backrest frame Deformed / distorted / bent
52200337 Rear seat backrest frame Loose
52200339 Rear seat backrest frame Unpleasant noises
522003XX Rear seat backrest frame
52200629 Rear centre multifunction armrest Sticking/jammed
52200632 Rear centre multifunction armrest Deformed / distorted / bent
52200637 Rear centre multifunction armrest Loose
52200639 Rear centre multifunction armrest Unpleasant noises
522006XX Rear centre multifunction armrest
52201129 Rear head restraints Sticking/jammed
52201131 Rear head restraints Excessive play
52201165 Rear head restraints Does not lock into position
522011XX Rear head restraints
52201413 Seat cushion detent Broken
52201437 Seat cushion detent Loose
522014XX Seat cushion detent
52201529 Seat backrest lock Sticking/jammed
52201537 Seat backrest lock Loose
52201539 Seat backrest lock Unpleasant noises
52201540 Seat backrest lock Poorly adjusted / outside tolerance
52201565 Seat backrest lock Does not lock into position
522015XX Seat backrest lock
52201713 Lever for rear seat backrest lock Broken
52201734 Lever for rear seat backrest lock Stiff to move
522017XX Lever for rear seat backrest lock
52201861 Seat cushion (foam part), rear Too rough
52201862 Seat cushion (foam part), rear Too soft
522018XX Seat cushion (foam part), rear
52201961 Backrest support (foam part), rear Too rough
52201962 Backrest support (foam part), rear Too soft
522019XX Backrest support (foam part), rear
52202022 Hinged box, multifunction armrest, rear Manufacturing fault
52202029 Hinged box, multifunction armrest, rear Sticking/jammed
52202034 Hinged box, multifunction armrest, rear Stiff to move
52202037 Hinged box, multifunction armrest, rear Loose
52202041 Hinged box, multifunction armrest, rear Poorly adapted/fitted
522020XX Hinged box, multifunction armrest, rear
52202114 Rear lumbar support Occasional malfunction
52202115 Rear lumbar support Permanent malfunction
52202139 Rear lumbar support Unpleasant noises
52202148 Rear lumbar support Leaking
522021XX Rear lumbar support
52202229 Adjustable side section (cheeks), head restraint, rear Sticking/jammed
52202265 Adjustable side section (cheeks), head restraint, rear Does not lock into position
522022XX Adjustable side section (cheeks), head restraint, rear
52202337 Interior strip / finisher for multifunction armrest, rear Loose
52202354 Interior strip / finisher for multifunction armrest, rear Scratches, score marks
52202391 Interior strip / finisher for multifunction armrest, rear colour differences
522023XX Interior strip / finisher for multifunction armrest, rear
5220XXXX Rear seats
52230101 Child seat Cracked / broken / torn off
52230103 Child seat Ripped
52230137 Child seat Loose
52230139 Child seat Unpleasant noises
52230167 Child seat Discoloured
52230169 Child seat Worn / sheared through
522301XX Child seat
52230234 Child seat height adjustment Stiff to move
52230265 Child seat height adjustment Does not lock into position
522302XX Child seat height adjustment
52230334 Child seat foot support Stiff to move
52230337 Child seat foot support Loose
52230339 Child seat foot support Unpleasant noises
522303XX Child seat foot support
52230401 Child seat tension strip Cracked / broken / torn off
52230437 Child seat tension strip Loose
522304XX Child seat tension strip
52230501 Child seat lower side cover with zip fastener Cracked / broken / torn off
52230537 Child seat lower side cover with zip fastener Loose
522305XX Child seat lower side cover with zip fastener
52230601 Child seat backrest / shoulder support Cracked / broken / torn off
52230603 Child seat backrest / shoulder support Ripped
52230637 Child seat backrest / shoulder support Loose
52230639 Child seat backrest / shoulder support Unpleasant noises
52230667 Child seat backrest / shoulder support Discoloured
52230669 Child seat backrest / shoulder support Worn / sheared through
522306XX Child seat backrest / shoulder support
52230701 Child seat impact table Cracked / broken / torn off
52230703 Child seat impact table Ripped
52230737 Child seat impact table Loose
52230739 Child seat impact table Unpleasant noises
52230767 Child seat impact table Discoloured
52230769 Child seat impact table Worn / sheared through
522307XX Child seat impact table
52230801 Child seat safety belts Cracked / broken / torn off
52230843 Child seat safety belts Releases by itself
52230865 Child seat safety belts Does not lock into position
52230869 Child seat safety belts Worn / sheared through
522308XX Child seat safety belts
52230965 Attachment points for child seat (Isofix or Top Tether) Does not lock into position
522309XX Attachment points for child seat (Isofix or Top Tether)
5223XXXX Child seat
52XXXXXX Seats
54110108 Sliding canvas sunroof Jumps out
54110139 Sliding canvas sunroof Unpleasant noises
54110140 Sliding canvas sunroof Poorly adjusted / outside tolerance
54110150 Sliding canvas sunroof Water ingress / condensate
54110152 Sliding canvas sunroof Not opening
54110153 Sliding canvas sunroof Not closing
541101XX Sliding canvas sunroof
54110237 Sliding canvas sunroof, water gutter Loose
54110239 Sliding canvas sunroof, water gutter Unpleasant noises
54110248 Sliding canvas sunroof, water gutter Leaking
541102XX Sliding canvas sunroof, water gutter
54110301 Sliding canvas sunroof, cover Cracked / broken / torn off
54110336 Sliding canvas sunroof, cover Dented/wavy
54110341 Sliding canvas sunroof, cover Poorly adapted/fitted
541103XX Sliding canvas sunroof, cover
54110448 Sliding canvas sunroof, gaskets Leaking
541104XX Sliding canvas sunroof, gaskets
54110548 Sliding canvas sunroof, frame with edges Leaking
541105XX Sliding canvas sunroof, frame with edges
54110636 Sliding canvas sunroof, headliner Dented/wavy
54110641 Sliding canvas sunroof, headliner Poorly adapted/fitted
541106XX Sliding canvas sunroof, headliner
54110736 Sliding canvas sunroof, headliner, edge protection Dented/wavy
541107XX Sliding canvas sunroof, headliner, edge protection
54110813 Sliding canvas sunroof, net-type wind deflector Broken
54110837 Sliding canvas sunroof, net-type wind deflector Loose
541108XX Sliding canvas sunroof, net-type wind deflector
54111001 Sliding canvas sunroof, spoiler gasket, windscreen Cracked / broken / torn off
54111032 Sliding canvas sunroof, spoiler gasket, windscreen Deformed / distorted / bent
54111039 Sliding canvas sunroof, spoiler gasket, windscreen Unpleasant noises
541110XX Sliding canvas sunroof, spoiler gasket, windscreen
5411XXXX Sliding canvas sunroof
54120129 Water drain hoses Sticking/jammed
54120137 Water drain hoses Loose
54120139 Water drain hoses Unpleasant noises
54120148 Water drain hoses Leaking
541201XX Water drain hoses
54120501 Floating headliner / roller blind Cracked / broken / torn off
54120537 Floating headliner / roller blind Loose
54120552 Floating headliner / roller blind Not opening
54120569 Floating headliner / roller blind Worn / sheared through
54120591 Floating headliner / roller blind colour differences
541205XX Floating headliner / roller blind
54120713 Wind deflector Broken
54120729 Wind deflector Sticking/jammed
54120737 Wind deflector Loose
541207XX Wind deflector
54120840 Guide carriage Poorly adjusted / outside tolerance
541208XX Guide carriage
54120932 Sunroof visor (SHD, panorama roof) Deformed / distorted / bent
54120937 Sunroof visor (SHD, panorama roof) Loose
54120939 Sunroof visor (SHD, panorama roof) Unpleasant noises
54120941 Sunroof visor (SHD, panorama roof) Poorly adapted/fitted
54120975 Sunroof visor (SHD, panorama roof) corroded
541209XX Sunroof visor (SHD, panorama roof)
54121037 Roof gasket Loose
54121048 Roof gasket Leaking
541210XX Roof gasket
54121201 Gear unit drive cable (SHD, panorama roof) Cracked / broken / torn off
541212XX Gear unit drive cable (SHD, panorama roof)
54121313 Drive element for movable roof-lining section Broken
541213XX Drive element for movable roof-lining section
54121413 Drive unit, components for guide carriage Broken
541214XX Drive unit, components for guide carriage
54121539 Slide/tilt sunroof (SHD, panorama roof) open Unpleasant noises
541215XX Slide/tilt sunroof (SHD, panorama roof) open
54121639 Slide/tilt sunroof (SHD, panorama roof) closed Unpleasant noises
54121650 Slide/tilt sunroof (SHD, panorama roof) closed Water ingress / condensate
541216XX Slide/tilt sunroof (SHD, panorama roof) closed
54121714 Open/close slide/tilt sunroof (SHD, panorama roof) Occasional malfunction
54121715 Open/close slide/tilt sunroof (SHD, panorama roof) Permanent malfunction
54121739 Open/close slide/tilt sunroof (SHD, panorama roof) Unpleasant noises
541217XX Open/close slide/tilt sunroof (SHD, panorama roof)
54121814 Tilt/close slide/tilt sunroof (SHD, panorama roof) Occasional malfunction
54121815 Tilt/close slide/tilt sunroof (SHD, panorama roof) Permanent malfunction
54121839 Tilt/close slide/tilt sunroof (SHD, panorama roof) Unpleasant noises
541218XX Tilt/close slide/tilt sunroof (SHD, panorama roof)
54121941 Fixed glass roof (Mini) Poorly adapted/fitted
54121948 Fixed glass roof (Mini) Leaking
541219XX Fixed glass roof (Mini)
54129053 E46 (with SA 403) Slide/tilt sunroof anti-trap protection takes effect
54129139 E53 Slide/tilt sunroof wind noises (gap dimension)
5412XXXX Slide/tilt sunroof, panorama roof, glass roof
54210032 Hardtop roof section Deformed / distorted / bent
54210039 Hardtop roof section Unpleasant noises
54210048 Hardtop roof section Leaking
542100XX Hardtop roof section
54210113 Hardtop catch with finisher panel Broken
54210134 Hardtop catch with finisher panel Stiff to move
54210137 Hardtop catch with finisher panel Loose
54210140 Hardtop catch with finisher panel Poorly adjusted / outside tolerance
542101XX Hardtop catch with finisher panel
54210407 Rear window in hardtop Cracked
54210430 Rear window in hardtop Blistering
54210433 Rear window in hardtop Optical distortion
54210448 Rear window in hardtop Leaking
54210454 Rear window in hardtop Scratches, score marks
54210480 Rear window in hardtop short circuit
542104XX Rear window in hardtop
54210701 Hardtop inner headliner Cracked / broken / torn off
54210732 Hardtop inner headliner Deformed / distorted / bent
542107XX Hardtop inner headliner
54219023 E52 Hardtop superstructure
5421XXXX Hardtop
54310001 Soft-top frame / brackets Cracked / broken / torn off
54310032 Soft-top frame / brackets Deformed / distorted / bent
54310041 Soft-top frame / brackets Poorly adapted/fitted
543100XX Soft-top frame / brackets
54310140 Soft-top catch Poorly adjusted / outside tolerance
543101XX Soft-top catch
54310203 Soft-top covering Ripped
54310237 Soft-top covering Loose
54310240 Soft-top covering Poorly adjusted / outside tolerance
54310241 Soft-top covering Poorly adapted/fitted
54310248 Soft-top covering Leaking
54310267 Soft-top covering Discoloured
54310269 Soft-top covering Worn / sheared through
543102XX Soft-top covering
54310301 Rear window in soft-top Cracked / broken / torn off
54310336 Rear window in soft-top Dented/wavy
54310348 Rear window in soft-top Leaking
54310354 Rear window in soft-top Scratches, score marks
54310367 Rear window in soft-top Discoloured
543103XX Rear window in soft-top
54310541 Edge protection (windscreen panel, roof frame) Poorly adapted/fitted
543105XX Edge protection (windscreen panel, roof frame)
54310739 Soft-top frame seal Unpleasant noises
54310741 Soft-top frame seal Poorly adapted/fitted
54310748 Soft-top frame seal Leaking
54310769 Soft-top frame seal Worn / sheared through
543107XX Soft-top frame seal
54310813 Soft-top frame handle recess Broken
543108XX Soft-top frame handle recess
54310934 Convertible top gas pressure prop (roadster, manual convertible top) Stiff to move
54310937 Convertible top gas pressure prop (roadster, manual convertible top) Loose
54310939 Convertible top gas pressure prop (roadster, manual convertible top) Unpleasant noises
54310966 Convertible top gas pressure prop (roadster, manual convertible top) No effect
543109XX Convertible top gas pressure prop (roadster, manual convertible top)
54311141 Cable, soft-top covering Poorly adapted/fitted
543111XX Cable, soft-top covering
54311229 Cover, headliner Sticking/jammed
54311237 Cover, headliner Loose
543112XX Cover, headliner
54311301 Cover, headliner clamping cables Cracked / broken / torn off
543113XX Cover, headliner clamping cables
54311429 Cover for linkage aperture for convertible top Sticking/jammed
543114XX Cover for linkage aperture for convertible top
54311529 Hinged convertible top compartment floor Sticking/jammed
54311534 Hinged convertible top compartment floor Stiff to move
54311541 Hinged convertible top compartment floor Poorly adapted/fitted
543115XX Hinged convertible top compartment floor
54313001 Tonneau cover Cracked / broken / torn off
54313041 Tonneau cover Poorly adapted/fitted
54313065 Tonneau cover Does not lock into position
54313067 Tonneau cover Discoloured
543130XX Tonneau cover
54313101 Tonneau cover fastening elements (press studs) Cracked / broken / torn off
54313165 Tonneau cover fastening elements (press studs) Does not lock into position
543131XX Tonneau cover fastening elements (press studs)
54313232 Tonneau cover fastening elements (studs) Deformed / distorted / bent
543132XX Tonneau cover fastening elements (studs)
54313368 Tonneau cover inner lining Peels off / detaches itself
543133XX Tonneau cover inner lining
54313448 Sealing frame in convertible top compartment Leaking
543134XX Sealing frame in convertible top compartment
5431XXXX Convertible soft-top, manual
54340052 Convertible soft-top, motorized Not opening
54340053 Convertible soft-top, motorized Not closing
543400XX Convertible soft-top, motorized
54340112 Convertible top hydraulic unit Permanent failure
54340139 Convertible top hydraulic unit Unpleasant noises
54340148 Convertible top hydraulic unit Leaking
543401XX Convertible top hydraulic unit
54340237 Control valves, convertible top Loose
54340248 Control valves, convertible top Leaking
543402XX Control valves, convertible top
54340337 Hydraulic lines, convertible top Loose
54340348 Hydraulic lines, convertible top Leaking
543403XX Hydraulic lines, convertible top
54340529 Convertible top compartment lid damper Sticking/jammed
54340537 Convertible top compartment lid damper Loose
54340548 Convertible top compartment lid damper Leaking
543405XX Convertible top compartment lid damper
54340629 Hydraulic cylinder for convertible top Sticking/jammed
54340637 Hydraulic cylinder for convertible top Loose
54340648 Hydraulic cylinder for convertible top Leaking
543406XX Hydraulic cylinder for convertible top
54341032 Locking bar Deformed / distorted / bent
54341037 Locking bar Loose
54341040 Locking bar Poorly adjusted / outside tolerance
543410XX Locking bar
54342114 Emergency release for electric soft-top Occasional malfunction
54342129 Emergency release for electric soft-top Sticking/jammed
543421XX Emergency release for electric soft-top
54342513 Electric soft-top linkage Broken
54342532 Electric soft-top linkage Deformed / distorted / bent
54342540 Electric soft-top linkage Poorly adjusted / outside tolerance
543425XX Electric soft-top linkage
54349152 E36/C Convertible top knocks against convertible top compartment
54349223 E52 Rear window cover
54349337 E52 Wind deflector detached
5434XXXX Convertible soft-top, motorized
54620113 Rollover protection cassette Broken
54620129 Rollover protection cassette Sticking/jammed
54620139 Rollover protection cassette Unpleasant noises
54620143 Rollover protection cassette Releases by itself
54620165 Rollover protection cassette Does not lock into position
54620175 Rollover protection cassette corroded
546201XX Rollover protection cassette
54620201 Rollover protection trim sections Cracked / broken / torn off
54620213 Rollover protection trim sections Broken
54620237 Rollover protection trim sections Loose
54620239 Rollover protection trim sections Unpleasant noises
54620254 Rollover protection trim sections Scratches, score marks
54620278 Rollover protection trim sections poor surface finish
54620291 Rollover protection trim sections colour differences
546202XX Rollover protection trim sections
54620339 Rollover bar Unpleasant noises
54620375 Rollover bar corroded
546203XX Rollover bar
54620413 Rollover protection cover for soft-top operation Broken
54620432 Rollover protection cover for soft-top operation Deformed / distorted / bent
54620439 Rollover protection cover for soft-top operation Unpleasant noises
54620454 Rollover protection cover for soft-top operation Scratches, score marks
54620478 Rollover protection cover for soft-top operation poor surface finish
54620491 Rollover protection cover for soft-top operation colour differences
546204XX Rollover protection cover for soft-top operation
54620501 Rollover protection cover for hardtop operation Cracked / broken / torn off
54620568 Rollover protection cover for hardtop operation Peels off / detaches itself
54620569 Rollover protection cover for hardtop operation Worn / sheared through
54620578 Rollover protection cover for hardtop operation poor surface finish
54620591 Rollover protection cover for hardtop operation colour differences
546205XX Rollover protection cover for hardtop operation
5462XXXX Rollover protection/rollover bar
54XXXXXX Sliding sunroof and convertible cover
61110079 Front wiring harness incorrect connection /contact
611100XX Front wiring harness
61110179 Rear wiring harness incorrect connection /contact
611101XX Rear wiring harness
61110279 Wiring harness tailgate/boot lid incorrect connection /contact
611102XX Wiring harness tailgate/boot lid
61110779 Wiring harness, ABS incorrect connection /contact
611107XX Wiring harness, ABS
61110979 Wire for electric seat adjustment incorrect connection /contact
611109XX Wire for electric seat adjustment
61111179 Wire for anti-theft alarm system incorrect connection /contact
611111XX Wire for anti-theft alarm system
61111579 Main wiring harness incorrect connection /contact
611115XX Main wiring harness
61111679 Wiring harness, air conditioning incorrect connection /contact
611116XX Wiring harness, air conditioning
61111779 Wiring harness, heater incorrect connection /contact
611117XX Wiring harness, heater
61119381 E38 Wiring harness damaged at wheel well - various warning lights active
6111XXXX Wiring harness
61120137 Battery lead B- (in vehicle interior) Loose
61120179 Battery lead B- (in vehicle interior) incorrect connection /contact
611201XX Battery lead B- (in vehicle interior)
61120237 Battery lead B+ (in vehicle interior) Loose
61120279 Battery lead B+ (in vehicle interior) incorrect connection /contact
611202XX Battery lead B+ (in vehicle interior)
61121379 Wire for front and rear fog lights incorrect connection /contact
611213XX Wire for front and rear fog lights
61121579 Wire for trailer tow hitch and trailer module incorrect connection /contact
611215XX Wire for trailer tow hitch and trailer module
61122279 Connecting wire for outside mirror/central locking/electric window incorrect connection /contact
611222XX Connecting wire for outside mirror/central locking/electric window
61123079 Wire for cruise control incorrect connection /contact
611230XX Wire for cruise control
61123479 Wire for seat heating incorrect connection /contact
611234XX Wire for seat heating
61123579 Wire for independent park heating/ventilation control incorrect connection /contact
611235XX Wire for independent park heating/ventilation control
61123679 Wire for seat adjustment with memory incorrect connection /contact
611236XX Wire for seat adjustment with memory
61123779 Connecting lead to seats incorrect connection /contact
611237XX Connecting lead to seats
61124079 Wire for air conditioning incorrect connection /contact
611240XX Wire for air conditioning
61124179 Line, slide/tilt sunroof (SHD, panorama roof) incorrect connection /contact
611241XX Line, slide/tilt sunroof (SHD, panorama roof)
61124239 Wire for front doors Unpleasant noises
61124279 Wire for front doors incorrect connection /contact
611242XX Wire for front doors
61124379 Wire for rear doors incorrect connection /contact
611243XX Wire for rear doors
61124479 Wire for radio/speakers incorrect connection /contact
611244XX Wire for radio/speakers
61124579 Wire for brake pad wear detectors incorrect connection /contact
611245XX Wire for brake pad wear detectors
61124679 Wire for speedometer sensor/immersed fuel level sensor/fuel pump incorrect connection /contact
611246XX Wire for speedometer sensor/immersed fuel level sensor/fuel pump
61124779 Connecting wire for anti-theft alarm system/on-board computer (DWA/BC) incorrect connection /contact
611247XX Connecting wire for anti-theft alarm system/on-board computer (DWA/BC)
61124879 Wire for car telephone preparation incorrect connection /contact
611248XX Wire for car telephone preparation
61124979 Wire for electrohydraulic/electromechanical soft-top incorrect connection /contact
611249XX Wire for electrohydraulic/electromechanical soft-top
61125079 Wire for electronic damper control (EDC) incorrect connection /contact
611250XX Wire for electronic damper control (EDC)
61125179 Wire for interior light incorrect connection /contact
611251XX Wire for interior light
61125279 Wire for park distance control (PDC) incorrect connection /contact
611252XX Wire for park distance control (PDC)
61125479 Wire for CD changer incorrect connection /contact
611254XX Wire for CD changer
61125537 Bracket steering column switch (coil spring cartridge/ctrl unit steering column switch cluster SZL)
61125539 Bracket steering column switch (coil spring cartridge/ctrl unit steering column switch cluster SZL)
61125579 Bracket steering column switch (coil spring cartridge/ctrl unit steering column switch cluster SZL)
611255XX Bracket steering column switch (coil spring cartridge/ctrl unit steering column switch cluster SZL)
61125679 Line, interior rear view mirror incorrect connection /contact
611256XX Line, interior rear view mirror
61125779 Line, level control system incorrect connection /contact
611257XX Line, level control system
61129060 E85 Contact resistance too high (replace door wiring harness)
61129179 E36 E38 E39 E46 E53 Airbag repair manual, belt pre-tensioner ignition circuit
61129223 E53 Connecting line, CD changer - radio
61129379 R50 R53 Airbag repair instructions triggering circuit for seat belt pretensioner
6112XXXX Auxiliary cable
61130007 Fuse box / distributors Cracked
61130023 Fuse box / distributors Incorrect / not fitted
61130037 Fuse box / distributors Loose
61130050 Fuse box / distributors Water ingress / condensate
61130075 Fuse box / distributors corroded
61130079 Fuse box / distributors incorrect connection /contact
611300XX Fuse box / distributors
61130601 Relay box for air conditioning Cracked / broken / torn off
61130623 Relay box for air conditioning Incorrect / not fitted
61130679 Relay box for air conditioning incorrect connection /contact
611306XX Relay box for air conditioning
61130701 Relay box for on-board computer Cracked / broken / torn off
61130723 Relay box for on-board computer Incorrect / not fitted
61130779 Relay box for on-board computer incorrect connection /contact
611307XX Relay box for on-board computer
61130813 Fuse Broken
61130880 Fuse short circuit
611308XX Fuse
61130979 OBD diagnosis socket incorrect connection /contact
611309XX OBD diagnosis socket
6113XXXX Plug connection, terminal, fuse socket
61210001 Vehicle battery Cracked / broken / torn off
61210012 Vehicle battery Permanent failure
61210049 Vehicle battery Overflowing / sloshing over
612100XX Vehicle battery
61210101 Bracket for vehicle battery Cracked / broken / torn off
61210137 Bracket for vehicle battery Loose
612101XX Bracket for vehicle battery
61210213 Battery cover/top/box Broken
61210237 Battery cover/top/box Loose
612102XX Battery cover/top/box
61210659 Vehicle battery acid level Too low / deep / slight
612106XX Vehicle battery acid level
61210759 Vehicle battery charge status Too low / deep / slight
612107XX Vehicle battery charge status
61219459 E65 Battery replacement for presentation vehicles
6121XXXX Battery with holder
61300114 Multiple lock contact (central locking) Occasional malfunction
61300115 Multiple lock contact (central locking) Permanent malfunction
613001XX Multiple lock contact (central locking)
61300214 Electronic damper control (EDC) switch Occasional malfunction
61300215 Electronic damper control (EDC) switch Permanent malfunction
61300229 Electronic damper control (EDC) switch Sticking/jammed
61300237 Electronic damper control (EDC) switch Loose
61300286 Electronic damper control (EDC) switch does not light up
613002XX Electronic damper control (EDC) switch
61300314 Anti slip control switch (ASC+T/DSC) Occasional malfunction
61300315 Anti slip control switch (ASC+T/DSC) Permanent malfunction
61300329 Anti slip control switch (ASC+T/DSC) Sticking/jammed
61300337 Anti slip control switch (ASC+T/DSC) Loose
61300386 Anti slip control switch (ASC+T/DSC) does not light up
613003XX Anti slip control switch (ASC+T/DSC)
61300414 Microswitch for tensioning hoop, electrohydraulic soft-top (convertible) Occasional malfunction
61300415 Microswitch for tensioning hoop, electrohydraulic soft-top (convertible) Permanent malfunction
613004XX Microswitch for tensioning hoop, electrohydraulic soft-top (convertible)
61300514 Switch, slide/tilt sunroof (SHD) / panorama roof / sliding canvas sunroof Occasional malfunction
61300515 Switch, slide/tilt sunroof (SHD) / panorama roof / sliding canvas sunroof Permanent malfunction
61300529 Switch, slide/tilt sunroof (SHD) / panorama roof / sliding canvas sunroof Sticking/jammed
61300537 Switch, slide/tilt sunroof (SHD) / panorama roof / sliding canvas sunroof Loose
61300586 Switch, slide/tilt sunroof (SHD) / panorama roof / sliding canvas sunroof does not light up
613005XX Switch, slide/tilt sunroof (SHD) / panorama roof / sliding canvas sunroof
61300614 Microswitch for front seat backrest Occasional malfunction
61300615 Microswitch for front seat backrest Permanent malfunction
613006XX Microswitch for front seat backrest
61300714 Headlight beam throw switch Occasional malfunction
61300715 Headlight beam throw switch Permanent malfunction
61300737 Headlight beam throw switch Loose
61300786 Headlight beam throw switch does not light up
613007XX Headlight beam throw switch
61300814 Steering wheel adjustment switch Occasional malfunction
61300815 Steering wheel adjustment switch Permanent malfunction
61300837 Steering wheel adjustment switch Loose
613008XX Steering wheel adjustment switch
61300914 Microswitch for electric window regulator Occasional malfunction
61300915 Microswitch for electric window regulator Permanent malfunction
613009XX Microswitch for electric window regulator
61301114 Switch for unlocking rear lid (in interior) Occasional malfunction
61301115 Switch for unlocking rear lid (in interior) Permanent malfunction
61301129 Switch for unlocking rear lid (in interior) Sticking/jammed
61301137 Switch for unlocking rear lid (in interior) Loose
61301186 Switch for unlocking rear lid (in interior) does not light up
613011XX Switch for unlocking rear lid (in interior)
61301214 Microswitch for electromechanical/electrohydraulic soft-top Occasional malfunction
61301215 Microswitch for electromechanical/electrohydraulic soft-top Permanent malfunction
613012XX Microswitch for electromechanical/electrohydraulic soft-top
61301314 Switch for electromechanical/electrohydraulic cover Occasional malfunction
61301315 Switch for electromechanical/electrohydraulic cover Permanent malfunction
61301329 Switch for electromechanical/electrohydraulic cover Sticking/jammed
61301337 Switch for electromechanical/electrohydraulic cover Loose
61301386 Switch for electromechanical/electrohydraulic cover does not light up
613013XX Switch for electromechanical/electrohydraulic cover
61301614 Switch, rear window roller sun blind Occasional malfunction
61301615 Switch, rear window roller sun blind Permanent malfunction
61301629 Switch, rear window roller sun blind Sticking/jammed
61301637 Switch, rear window roller sun blind Loose
61301686 Switch, rear window roller sun blind does not light up
613016XX Switch, rear window roller sun blind
61301814 Microswitch for rear lid lock Occasional malfunction
61301815 Microswitch for rear lid lock Permanent malfunction
613018XX Microswitch for rear lid lock
61302014 Park distance control (PDC) switch Occasional malfunction
61302015 Park distance control (PDC) switch Permanent malfunction
61302029 Park distance control (PDC) switch Sticking/jammed
61302037 Park distance control (PDC) switch Loose
61302086 Park distance control (PDC) switch does not light up
613020XX Park distance control (PDC) switch
61302114 Rear seat adjustment/head restraint switch Occasional malfunction
61302115 Rear seat adjustment/head restraint switch Permanent malfunction
61302129 Rear seat adjustment/head restraint switch Sticking/jammed
61302137 Rear seat adjustment/head restraint switch Loose
613021XX Rear seat adjustment/head restraint switch
61302214 Thigh support switch Occasional malfunction
61302215 Thigh support switch Permanent malfunction
61302229 Thigh support switch Sticking/jammed
61302237 Thigh support switch Loose
613022XX Thigh support switch
61302314 Lumbar support switch Occasional malfunction
61302315 Lumbar support switch Permanent malfunction
61302329 Lumbar support switch Sticking/jammed
61302337 Lumbar support switch Loose
613023XX Lumbar support switch
61302414 Multifunction steering wheel switch (MFL) Occasional malfunction
61302415 Multifunction steering wheel switch (MFL) Permanent malfunction
61302429 Multifunction steering wheel switch (MFL) Sticking/jammed
61302437 Multifunction steering wheel switch (MFL) Loose
61302486 Multifunction steering wheel switch (MFL) does not light up
613024XX Multifunction steering wheel switch (MFL)
61302514 Microswitch for rear lid Occasional malfunction
61302515 Microswitch for rear lid Permanent malfunction
613025XX Microswitch for rear lid
61302614 Main switch for cruise control Occasional malfunction
61302615 Main switch for cruise control Permanent malfunction
61302629 Main switch for cruise control Sticking/jammed
61302637 Main switch for cruise control Loose
61302686 Main switch for cruise control does not light up
613026XX Main switch for cruise control
61302814 Central locking switch Occasional malfunction
61302815 Central locking switch Permanent malfunction
61302829 Central locking switch Sticking/jammed
61302837 Central locking switch Loose
61302886 Central locking switch does not light up
613028XX Central locking switch
61302914 Shoulder support switch Occasional malfunction
61302915 Shoulder support switch Permanent malfunction
61302929 Shoulder support switch Sticking/jammed
61302937 Shoulder support switch Loose
613029XX Shoulder support switch
61303014 Anti-trapping strip, doors Occasional malfunction
61303015 Anti-trapping strip, doors Permanent malfunction
61303037 Anti-trapping strip, doors Loose
613030XX Anti-trapping strip, doors
61303214 Switch/push-button, boot lid release (on outside of boot lid) Occasional malfunction
61303215 Switch/push-button, boot lid release (on outside of boot lid) Permanent malfunction
613032XX Switch/push-button, boot lid release (on outside of boot lid)
