Ferrari F355 Berlinetta, GTS and Spider
Ferrari F355 GTS - Front Production period
1994-1999
Number built
3938 (Berlinetta)
2048 (GTS)
2663 (Spider)
Engine
V-8 90°
Bore (mm)
85
Stroke (mm)
77
Stroke volume
3495
Compression ratio
11:1
Maximum power (HP)
380
At speed of rotation (rpm)
8250
Gear
6 Speed man.
or
F1 sequential
(From '97)
Top speed (kph)
295
0-100 kph
4.7
Ferrari F355 GTS - Side
Ferrari F355 GTS F1 - Rear Original tires, front
225/40 ZR 18
On rim
Original tires, rear
265/40 ZR 18
On rim
Length (mm)
4250
Width (mm)
1900
Height (mm)
1170
Wheel base (mm)
2450
Front track (mm)
1514
Rear track (mm)
1615
Weight (kg)
1350
Fuel tank (litre)
82
:shock:
