Mitsubishi's will use 3-cylinder MIVEC engine new 660cc
http://image.made-in-china.com/4f0j0...Car-BD500-.jpg
http://www.chinese-parts-canada.com/...er_EFI_ECU.jpg
http://www.motornature.com/wp-conten...cylindre-2.jpg
http://upload.ecvv.com/upload/Produc...1267942495.jpg
http://img.directindustry.com/images...46-6646851.jpg
Mitsubishi's will use 3-cylinder MIVEC engine new 660cc.
http://3.bp.blogspot.com/_jiLsBLaOvz...art+Car++2.jpg
In addition to the control valve timing and a block of aluminum (which gives 10% weight reduction), the new engine also uses the following to reduce the weight, size and cost, and to provide more power and fuel economy better:
4-valve direct-drive valvetrain
Timing chain
Resin components (including the intake manifold, headgear)
Rear exhaust engine mounting layout
New 3-cylinder, 660cc turbocharged engine provides 47kW (63 hp) of power. With variable valve timing, fuel is expected to increase by 15% eceonomy the mini-car unit today, and to obtain a 3-star LEV rating for emission levels 50% cleaner than Japanese 2005 Low-Emission Vehicle requirements.
With the midship location and 45 degrees tilted back, the new engine allows a greater flexibility in developing the front end and also a longer wheelbase.
http://www.columbia.edu/~fdc/germany/isetta.jpg
http://drive4corners.com/wp-content/...tag/m-cutb.jpg
http://www.saundersclassics.com/wp-c...etta-frame.jpg
https://i.ytimg.com/vi/uBkcZlPcXm4/maxresdefault.jpg
http://www.osomo.nl/wp-content/uploa...rs-150x150.jpg
http://www.jumpingfrog.com/images/ep...8/hpm7217b.jpg
http://insideevs.com/wp-content/uplo...e-extender.jpg
BMW Has A Nice Little Spot Set Aside For A 2 Cylinder Engine In The i3
https://upload.wikimedia.org/wikiped...833758103).jpg
Mahle three-cylinder, 1.2-liter engine develops 193 horsepower
http://images.hgmsites.net/med/mahle...00225918_m.jpg
http://www.enginetechnologyinternati...recast/one.jpg
http://www.sae.org/images/enewslette...ain/05_455.jpg
https://encrypted-tbn1.gstatic.com/i...YmGjBjuFnrxwH7
:bravo::bravo::bravo::bravo::bravo::bravo::bravo:: bravo::bravo::bravo:
