https://en.wikipedia.org/wiki/Mitsubishi_Orion_engine
The SOHC 4G18 displaces 1.6 L (1,584 cc) with a bore and stroke of 76.0 mm x 87.3 mm. It is a 4-valve per cylinder engine, fuel injected. Output is 105 PS net at 6,000 rpm (Middle East specifications), 122 PS gross at 6,000 rpm (Gulf Countries specification),[1] 98 PS net with 150 Nm (European specifications). It uses a COP (Coil-On-Plug, also known as Plug-top coil) ignition rely on one coil to fire two cylinders, one of which was by spark plug wire.
فيه منه ثلاث نسخ
نسخة شرق اوسطي قدرته 103 حصان
نسخة خليجي قدرته 120 حصان
نسخة اوروبي قدرته 96 حصان و لكن بعزم اعلى يصل الى 150 nm
