تصحيح :
السعر من : 185000 إلى 205000 جنية مصري,,,
رقم العضوية : 149075
السيارة: Toyota
السيارة[2]: Toyota
اللهم صل على محمد وعلى آله وصحبه أجمعين
4-Door 1.6i Sport
DIMENSIONS: L x W x H: 4,585 x 1,740 x 1,465 mm
ENGINE: 1.6-litre DOHC 4-cylinder engine
CAPACITY: 1,599 cc
MAX OUTPUT: 84 kW (114 PS) / 5,600 rpm
MAX TORQUE: 150 Nm (15.3 kgfm) / 4,000 rpm
TRANSMISSION: Lineartronic , AWD
Fabric Black
SEAT MATERIALS
Fabric Black
Fabric Ivory
EQUIPMENT
- Fog Lamps
Multireflector fog lamps also serve as daytime running lights, and emit a wide, flat beam that reflects less glare in fog, for added safety.- 4-way Adjustable Steering Column
To help set your optimum driving position, the adjustable steering wheel tilts up or down and telescopes in and out.- Stainless Steel Exhaust Tips
- Illuminated Meter
An illumination on the meters helps improve visibility. Plus the LCD meter centre display is linked to the meter and shares helpful info like digital speed meter and even a driving time.- Voice Recognition (*1) and Siri Eyes Free (*2) (*3)
Your Impreza has more hands-free options than ever before, thanks to intuitive Voice Recognition (*1) and Siri Eyes Free (*2) (*3) integration. Use Siri to link your compatible Apple (*3) product to your Impreza, allowing you to make hands-free calls, play music, check emails and search the web. Even without Siri, you can still have hands-free interaction with navigation, telephone and audio systems for added ease in every drive.- Multi-function Display
Positioned to be clearly visible with minimal distraction as you drive, this display shows you a variety of information that puts you in touch with your vehicle.- SUBARU STARLINK (*4)
Like a built-in smartphone for your car, having the SUBARU STARLINK (*4) infotainment system lets you access internet radio, entertaining apps, and much more. Control it with the tabletlike 7-inch centre touchscreen, multifunction steering wheel controls, or one-shot voice recognition (*1). If you can’t find your favourite music, connect your iPhone (*3), smartphone or other mobile music device via the USB or standard AUX jack.- Touchscreen Control
Using the touchscreen is an easy way to select your music, just as you would on your smartphone. Simply connect your smartphone through Bluetooth® (*5) or the USB port, and you can choose your music right on the touchscreen.- Heated Front Seats
Available heated front seats offer two settings, for rapid heating or soothing warmth.
*1 Voice Recognition is compatible with select languages only and cannot accept all languages.
*2 Siri-compatible Apple product (iPhone®, iPad®, iPod touch®, etc.) required.
*3 Apple®, iPod®, Siri® and iTunes® are registered trademarks of Apple Inc. App Store® is a service mark of Apple Inc.
*4 Driver is always responsible for safe and attentive driving. Please refrain from operating the touchscreen whilst driving.
Package communications fee may be charged depending on your area.
*5 Bluetooth® is a registered trademark of Bluetooth SIG, Inc. America.
DIMENSIONS
SPECIFICATIONS
Item Symmetrical All-Wheel Drive 1.6i Sport Lineartronic ENGINE Type Horizontally-opposed, 4-cylinder, 4-stroke, petrol engine DOHC 16-valve Bore/Stroke (mm) 78.8 / 82 Capacity (cc) 1,599 Compression ratio 10.5 Fuel system Multi-Point Sequential Injection Fuel tank capacity (lit.) 55 PERFORMANCE Max. output (DIN)(kW(PS)/rpm) 184 (114) / 5,600 Max. torque (DIN)(Nm(kgfm)/rpm) 150 (15.3) / 4,000 Max. speed (km/h) 181 Acceleration (0-100 km/h)(sec.) 12.6 Fuel consumption*6 Urban (lit./100 km) 7.6 Extra-urban (lit./100 km) 5.2 Combined (lit./100 km) 6.1 CO2 emissions*6 Urban (g/km) 176 Extra-urban (g/km) 120 Combined (g/km) 140 DRIVETRAIN All-Wheel Drive type Active Torque Split AWD system DIMENSIONS & WEIGHT Overall length (mm) 4,585 Overall width (mm) 1,740 Overall height (mm) 1,465 Wheelbase (mm) 2,645 Track Front (mm) 1,510 Rear (mm) 1,515 Minimum road clearance (at kerb weight)(mm) 145 Cargo volume*7 (lit.) 460 Seating capacity (persons) 5 Kerb weight (kg) 1,375 Towing capacity (kg) 1,200 TRANSMISSION Gear ratio D range 3.581 - 0.570 1st - 2nd - 3rd - 4th - 5th - 6th - Reverse 3.667 Final drive axle ratio 3.900 CHASSIS Steering Rack and pinion, electric power steering system Suspension
(4-wheel independent) Front MacPherson strut type Rear Double wishbone type Minimum turning circle at tyre (radius) (m) 5.3 Brakes Front Ventilated disc brakes Rear Solid disc brakes Tyre/wheel size 205/55R16, 16x6.5"J
*6 Fuel consumption and CO2 emissions: according to ECE R101-01.
*7 Measured by VDA.
Vehicle kerb weight varies according to the types of optional equipment included. Specification data and model lineup may vary according to market.
SAFETY
- Seats, seatbelts and SRS* airbags
The Impreza features whiplash-reducing front seats and energy-absorbing head restraints, along with seatbelts with pretensioners, that can help better protect front occupants during a rear collision. Front, front-side, curtain and knee SRS* airbags are standard on all models to maximise protection in frontal and side impacts.- Ring-shaped reinforcement frames
The ring-shaped reinforcement frames feature high-tensile steel designs that are strong and rigid, yet light in weight. The passenger cabin is strengthened from the roof to the doors, pillars and floor. This design helps, in a collision, to divert and dissipate impact energy away from the occupants.- Braking System
The 4-wheel disc brakes feature lightweight aluminium rear calipers and a design that helps provide a strong, progressive feel. The Antilock Braking System includes Electronic Brake-force Distribution, to reapportion front/rear braking pressure when the vehicle is loaded. To help ensure maximum braking during an emergency, the Impreza features both Brake Assist and Brake Override.- Cabin-protecting layout
In the event of a head-on collision, the SUBARU BOXER engine and gearbox are designed, for your protection, to avoid crashing into the cabin.- Vehicle Dynamics Control System
The Vehicle Dynamics Control System monitors and analyses via an array of sensors whether the vehicle is following the driver’s intended path. If the vehicle approaches the limits of stability, the AWD torque distribution, engine output and brakes at each wheel are adjusted to assist in keeping the vehicle on course.
- SUBARU BOXER Engine
Few other cars drive with the fun and eagerness of Impreza, so you won’t be surprised by how uniquely this is accomplished. The horizontally opposed configuration of the SUBARU BOXER engine places the pistons 180 degrees apart, for a lower, flatter profile than that of other engine types. This gives the engine, and overall vehicle, a lower centre of gravity and a more balanced distribution of weight. Furthermore, the pistons’ opposing movements inherently counteract each other, naturally helping to reduce vibration.- 2.0-litre DOHC SUBARU BOXER
MAX OUTPUT: 110 kW (150 PS) / 6,200 rpm
MAX TORQUE: 196 Nm (20.0 kgfm) / 4,200 rpm
FUEL CONSUMPTION:
5-Door 2.0i Sport (*1): 6.5 lit./100 km (Lineartronic), 6.9 lit./100 km (6MT)
4-Door 2.0i Sport (*2): 7.0 lit./100 km (Lineartronic)
CO₂ EMISSIONS:
5-Door 2.0i Sport (*1): 149 g/km (Lineartronic), 159 g/km (6MT)
4-Door 2.0i Sport (*2): 160 g/km (Lineartronic)- 1.6-litre DOHC SUBARU BOXER
FUEL CONSUMPTION:
5-Door 1.6i Sport (*1): 6.1 lit./100 km (Lineartronic), 6.4 lit./100 km (5MT)
4-Door 1.6i Sport (*2): 6.1 lit./100 km (Lineartronic)
CO₂ EMISSIONS:
5-Door 1.6i Sport (*1): 140 g/km (Lineartronic), 147 g/km (5MT)
4-Door 1.6i Sport (*2): 140 g/km (Lineartronic)- Increased Stability
Because the engine block has a flatter profile and sits lower in the chassis, the overall vehicle is more stably balanced and resistant to side-to-side motion than other designs.- Long-lasting Performance
The engine’s flat design is inherently rigid and self-balancing, generating less vibration than V-type or in-line engines in the same class for more durability and more reliable performance.- فيديو : النسخة الخليجية ( مواصفات مختلفة ) 2015 Turbo
- https://www.youtube.com/watch?v=8w9eNNHHmiI
المصدر :-
SUBARU | Impreza | Lineup | 4-Door 1.6i Sport
السعر :-
من 195000 جنية مصري
إلى 210000 ( الفئة الأعلى )
اللهم أغفر وارحم وثبت من إشتاقت عيني لرؤيتها،ويدي لمصافحتها،واذني لسماع صوتها اللهم اجعل الجنة دار ومستقر لها.
اللهم إرحم أمي رحمة واسعة وأسكنها فسيح جناتك
السيارة: Toyota
السيارة[2]: Toyota
تصحيح :
رقم العضوية : 182225
الاقامة : Riyadh
السيارة: Avalon
السيارة[2]: Cressida
جهد مميز .. شكراً
رقم العضوية : 83900
الاقامة : saudi arabia ,jeddah
السيارة: cerato koup
السيارة[2]: optra
عربيه مميزه لكن مظلومه
السيارة: Toyota
السيارة[2]: Toyota
السيارة: Toyota
السيارة[2]: Toyota
السيارة: Toyota
السيارة[2]: Toyota
هو أنا مش عارف أعدل الموضوع فهضيف الكلام العاوزة في رد
تحديث : الحجز شغال في التوكيل بالسعر الرسمي 184900 أو فئة 205 حالياُ والتسليم أخر فبراير تقريباً
السيارة: Toyota
السيارة[2]: Toyota
بس للأمانة بردة
ذكر العيوب :
وأهم حاجة إن قطع الغيار وتوفرها والتصليح في التوكيل بس الفروعة في العبور (القاهرة) أو إسكندرية فقط !!!!
رقم العضوية : 184755
السيارة: نيسان سنترا
السيارة[2]: نيسان سنترا
شكرا على المعلومات المفيدة..
هل للعربية جروب ملاك على الفيس بوك؟
محتاجه ضروري عشان أعرف آراء الناس عنها اي؟
السيارة: Toyota
السيارة[2]: Toyota
