1 مرفق
Wagner 0518080 – Leading Brand for Paint Sprayers
Wagner 0518080 Control Spray Max
- Compact lightweight spray gun is ideal for hard to reach areas
- Professional Grade metal cup for smaller fine finish applications
- Variable flow trigger dials in spray pattern width from 1 inch to 10 inch
- Powerful Two Stage Turbine sprays latex, as well as thinner materials such as lacquers and stains
- Variable Air Pressure Control means less overspray with thin materials
- 20 Foot High Flex Air Hose extends your reach
- 3 spray patterns - select the best pattern for your job
- Variable flow control covers large spray surface down to detail work
Wagner 0518080 Control Spray Max HVLP Sprayer - Power Sprayers - Amazon.com
https://www.youtube.com/watch?v=Wrczf4yf8X0
Wagner 0518080 Reviews – Leading Brand for Paint Sprayers
Wagner 0518080 Reviews - Leading Brand for Paint Sprayers
هذا الجهاز انا اشتريته ولم استخدمه - مازال جديد بعلبته
ويعتبر افضل جهاز دهان موجود فى الاسواق
ويستحدم لدهان جميع الاغراض
المطلوب 1800 جنيها
