توكيل IFG بمحافظة السويس
وصول أول شبل من عائله الاسوود CDW 717 أصغر قلاب الان فى مصر
شنري 750LI
العنوان
42 ش المدينه الرياضيه - الملاحه الجديده, السويس
الوصف القصير
IFG Group Egypt – اى اف جى جروب | Ibrahim Farag Group
الهاتف
0623318463
اى اف جى للتجارة. سيارات - تجار - سيارات جديدة. العنوان : 6 ش حافظ رمضان, مدينة نصر, القاهرة خلف الجامعة العمالية. IFG Group Egypt – اى اف جى جروب | Ibrahim Farag Group
القاهرة , الاسماعيلية , السويس أرقام الاتصال
+20222746804
+20222746809
الموقع الالكتروني IFG Group Egypt – اى اف جى جروب | Ibrahim Farag Group صفحة الفيسبوك https://www.facebook.com/ifgfortrading/
As for its features, Brilliance BMW stylist leads and designs MPV Shineray 750Li according to its official source. Its design borrows the elements from BMW. Taking eagle-eye front headlamp as an example, it adopts the elements of BMW 5 Series and X1. Meanwhile, this front headlampavailable with the lens canbe adjustable upward and downwards.
The air-intake grille links with the front headlamps, and is decorated by shining strip chrome, which makes its front face as a whole more attractive.
The front frog headlamp also adopts chromed frame,echoing with the lower strip air-intake, while the black decoration frame of the front frog lamp different from the vehicle color produces the contrasting effect.
The Outside Rear-View Mirror is equipped with side indicator, while only its flagship and honorable model have the Power Mirror. On August 2015, the upcoming new sporty model will have electrically-heating Mirror.
All the three models have the roof rack.
The rear end of MPV Shineray 750 does not havetoo many fancy lines, giving the steadfast impression and also borrows some elements from BMW design.
The same element with BMW X1 in the rear headlamp is easily found.
The LX and DLX model equipped with four Parking sensors.
The DLX model is equipped with Visual Parking Screen.
The DLX model has an eight-inch color touch screen.On its each side of the touch screen, there are electric touch buttons and its response speed is good. The interface design of the system is quite simple, like Apple’s IOS system, and has sliding function, video playing & blue tooth.
Cigarette lighter and USBinterface are applied under the central console.
Although the central console applies rigid plastic material, the assembly technique is excellent and the joint gap is extraordinary even. Besides, the door panel adopts rigid plastic material as well except for the handrail part uses leather covers.
The second-row air-conditioning has its own switch to control airflow. There is no space for the air-conditioning outlet and the sun-roof version has no such A/C.
The layout of the seats applies 2+2+3, letting the third-row passengers to go easily through pass-by space between second-row seats.
The DLX model adopts beige leather seats, which feels soft and comfortable.
As for the second-roll seats, inner side handrail is available and manual-rotatable according to the angle of seatback, greatly improving the space flexibility. Meanwhile, all models are equipped with ISOFIX child-seats connectors.
Its third-row seat is integrated design, all available with adjustable headrests.
A 176cm high driver sits inside, there is still around 18cm left space in his head, proving its large room.
The 176mm-height passenger sits in the second-row seat and its room space is good.
The Third-row seat and its room space is good.
The quarter window glass beside the third-row seat can be opened for ventilation.
As the third-row seat unfolded, its trunk length is 280mm.As the third-row seat folded, the truck length can be 710mm. More space is available if the third-row seats are dismounted by tools and the second-row seats folded.
As second-row and third-row seats folded, the lengthof the trunk can be extended to 1850mm.
1.5 L Natural-Aspiration Engine
Max Power: 112 HP (82KW)/5800RPM
Max Torque: 147 NM/4000-4500RPM
Shineray 750Li is designed based on the platform of Brilliance passenger vehicle, using front-mounted engine and front drive type. And the suspension tends to be comfort tuning.
Front Suspension: Macpherson Independent Suspension
Rear Suspension: Five Connecting-Rod Spiral Spring Dependent Suspension
