النتائج 1 إلى 10 من 11
الموضوع: Ford Patents 11-Speed
    Lightbulb Ford Patents 11-Speed - Facebook Twitter whatsapp انشر الموضوع فى :
    Still, the auto industry is racing to add more gears to its automatic transmissions, as a greater number of gears—and a greater ratio spread—helps keep an engine operating in the most efficient part of its rev band at any given moment. Many manufacturers, of course, are turning to CVTs for this same reason, but i generally prefer a ratio count that stops short of infinity.
    The Numbers All Go to Eleven: Ford Patents 11-Speed Automatic
    In a world where eight-speed automatics are common, nine-speeds are available, and 10-speed transmissions are in the works, Ford’s application for a patent on an 11-speed automatic transmission has an air of inevitability about it.
    Unlike Ford’s 10-speed automatic, which is being jointly developed with General Motors, the 11-speed appears to be a Ford-only effort. The application indicates a design that uses planetary gearsets, which are not used with dual-clutch configurations, so this is likely to be a conventional, torque-converter automatic. We don’t know yet which model the new gearbox will appear in—or whether it will be produced at all. It’s not uncommon for automakers to file patents on auto-trans gearing arrangements without any intention of using them in the immediate future.
    Here’s what the new gearbox design features: the first embodiment has four simple planetary gear sets, four clutches and two brakes. The second has three simple planetary gear sets, two axis transfer gear pairs, four clutches and two brakes. The final embodiment receives four simple planetary gear sets, four brakes and two clutches.
    It may have been easier and cheaper for Ford to have modified that gearbox to improve mileage, but perhaps the engineering limits of the F150’s 10-speed had already been stretched, necessitating an extra ratio.
    الصورة الرمزية رامي مصطفى
    رقم العضوية : 148915
    الاقامة : المنصوره-العاشر من رمضان
    السيارة: Terios 2000
    السيارة[2]: lanos2013&tempra 93
    الحالة : رامي مصطفى غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة colin chapman مشاهدة المشاركة
    هيا العربيه دي لو نزلت عندنا ممكن ادفعلها ٦٠ الف مقدم واقسط الباقي على ٥ سنين.
    الف شكر
    قعدت اقول لحضرتك كفايه تعقييد...
    Lightbulb ممكن تدفعلها 600 الف مقدم وتقسط الباقي على ٥ سنين. -
    اقتباس المشاركة الأصلية كتبت بواسطة رامي مصطفى مشاهدة المشاركة
    الف شكر
    والله حضرتك ولا تعقييد ولا اى شىء دى عربية فى بلدها عادية جدا زى السيراتو والشارك هنا كده
    :y_hi_3[1]::y_hi_3[1]::y_hi_3[1]::y_hi_3[1]::y_hi_3[1]::y_hi_3[1]:
    يبأى نعمل الموضوع في بلدها...ههههه
    Thumbs up -
    الصورة الرمزية ahmed_eng2001
    رقم العضوية : 63828
    السيارة: لانسر بومة 2008
    السيارة[2]: بليزر k5 1980
    الحالة : ahmed_eng2001 غير متواجد حالياً
    العربيات دى اخرنا نسمع عنها فى الاخبار و المجلات و بس
    Smile ahmed_eng2001 -
    اقتباس المشاركة الأصلية كتبت بواسطة ahmed_eng2001 مشاهدة المشاركة
    ahmed_eng2001
    الصورة الرمزية S O P H O S
    رقم العضوية : 71514
    الاقامة : EgYpT-ⵍⵎⵖⵔⵉⴱ-
    السيارة: -- -- all FiaT ---
    دراجة بخارية: - - - - - - -
    الحالة : S O P H O S غير متواجد حالياً
    ده هنا 4 ومستكترنهم
  1. Need for Speed: The Run
    بواسطة MOSHAKS في المنتدى المنتــــــدى الاجتمــاعى
    مشاركات: 12
    آخر مشاركة: 03-12-2011, 07:19 PM
  2. Gen 2 top speed
    بواسطة ahmed_elbaz في المنتدى بــروتـــون
    آخر مشاركة: 08-10-2011, 02:24 PM
  3. top speed for cbr 250 r 0:180
    بواسطة KHALED2010 في المنتدى مختــلف أنواع الدراجات النارية
    مشاركات: 44
    آخر مشاركة: 17-03-2011, 01:16 AM
  4. frv top speed
    بواسطة asabry22 في المنتدى بريليانس
    مشاركات: 22
    آخر مشاركة: 27-08-2009, 07:54 PM
  5. speed limit + speed control
    بواسطة elshinawy80 في المنتدى ريــــنو
    آخر مشاركة: 16-02-2009, 10:41 PM
