سؤال لمالكى جين 2 عن DVD
حد يعرف سعر DVD ده فى مصر بكام لانه بره داخل فى حوالى 2600 جنيه
Buy PROTON GEN2/ PERSONA DLAA 7" Full HD 800 x 480px Double Din DVD DIVX VCD MP3 CD USB SD BLUETOOTH TV Player
http://i275.photobucket.com/albums/j...ntitled-31.jpg
ودى مواصفاتها
[PROTON GEN2/ PERSONA] DLAA 7" Full HD 800 x 480px Double Din DVD DIVX VCD MP3 CD USB SD BLUETOOTH TV Player
In-Built Steering Control that Support Persona/ Gen2
7" (16:9) 65K WVGA Amoled display Digital TFT Monitor (HD Quality Similar to KENWOOD, PIONEER, JVC PANASONIC & SONY Monitor)
Screen Resolution: Full HD 800 x 480px
Touch screen can operate menu through touching display.
Large-capacity SD.MMC card / USB MP4, MP3 format.
Compatible with DVD/ VCD/CD/MP3 format; MP4(AVI/DVI/3.X/5.X); SVCD/WMA/JPEG/WMV/JPEG/WMV/AVI/MPG.
DVD/VCD/CD Multi-discs is controllable
FM/AM radio play back, automatic storing 30 stations
Adjust the screen any angle
Automatic slip down panel
USB 2.0 port & SDHC slot
FM/AM wave band (DTS system)
High Quality TV system: PAL/ NTSC/ SECAM (Can Watch All Channel from TV1 to TV9)
Sensitization setup
Screen turn off mode
Special display mode on night
Audio frequency: 4*40W
Connect with radar and rearview camera
Built-in Bluetooth A2DP-compatible
Aux Input x 1
Video Input x 1
Video output x 2
1 Year Warranty (Under DLAA Malaysia Sole Distributor)
Weight: 4Kg
A Japan Production
Assemble in Taiwan
HINET TV Antenna with Booster Rated As the Best TV Antenna in the Market
Frequency (MHz): 40-890mhz
Booster Gain (dB): FM/VHF:24-18; UHF:17-11
Supply Voltage: DC 12V (8.5-18V) Mini Earthing
Power Supply Fuse: 1A
Connection Outler, Antenna Plug: 3.5mm (75)
Length of the cord: 6M
Product Weight: 0.35Kg
1 Year Warranty
Made In Germany
170º IR Color CCD Rearview Reverse Camera w/ Distant Meter
Vehicle rear view camera
Color CCD / cmos camera system
Safety / wide view angle
Safety you can see rear view
Compact size & easy installation
Offering multi-choices to match each vehicles needs
Made In Taiwan
1 Year Warranty
منتظر ردكم ضرورى
