Pressure plate and friction disk seen from other side. Both are worn down.
http://i752.photobucket.com/albums/x...axomat12_1.jpg http://i752.photobucket.com/albums/x.../Hycomat_1.jpg http://i752.photobucket.com/albums/x...dSA/Hydrak.jpg http://i752.photobucket.com/albums/x.../Saxomat13.jpg http://i752.photobucket.com/albums/x...Saxomat8_1.jpg
The Saxomat was an evolution of the F & S-roller centrifugal clutch as a lower-cost alternative to models with automatic transmission. Pricing of the Saxomat was therefore between automatic transmissions of the day, and a conventional “manual” change.
On Auto Union/DKW cars the Saxomat was only originally available on Coupe and four door versions of the 3=6 series (the F93 3=6 Coupe and the F94). By 1960, this was extended to the two door “standard saloon” version of the Auto Union 1000 (it was available on the 1000S Coupe and Four door also).
Also, in post-war Germany, there was a market for vehicles that could be adapted for use by persons that had lost one or both legs during the war. As automatic transmissions were a rarity there, at that time, the automatic clutch option fulfilled that requirement nicely.
Cars with a Saxomat clutch do not have a clutch pedal. The Saxomat consists of two independent systems, the centrifugal clutch, and the servo clutch. The centrifugal clutch is engaged above certain engine rpms by centrifugal force (RPM as adjusted), acting on spinning weights inside the clutch, similar to a centrifugal governor.
http://i752.photobucket.com/albums/x...A/Saxomat2.jpg http://i752.photobucket.com/albums/x...A/Saxomat3.jpg
As stated above, essentially, the Saxomat works with two parallel clutches and a freewheel:
http://i752.photobucket.com/albums/x...A/Saxomat4.jpg
The Saxomat clutch is a combination of two single dry plate clutches: one is operated by centrifugal force and utilises a bronze friction material and another is a normal type with asbestos material and is operated by a release bearing, a clutch lever and a vacuum actuator. The illustration to the left shows a high-rpm situation where the centrifugal clutch is engaged. The illustration to the right shows a low-rpm situation where the centrifugal clutch is released.
http://i752.photobucket.com/albums/x...A/Saxomat5.jpg
The purpose of the clutch control system is to release the clutch whenever the gear lever (1) is operated and re-engage the clutch, when a new gear has been selected, and the accelerator pedal is depressed. Vacuum is supplied from the intake manifold and stored in a reservoir. When the gear lever is touched electric current is supplied to the solenoid in the control valve (2). Vacuum is transferred to the vacuum diaphragm actuator (3) which pulls the clutch lever and releases the clutch. The diaphragm-valve-system at the right end of the control valve (2) ensures a controlled vacuum release and thereby a “soft” re-engagement of the clutch. The thin hose connection to the carburettor signals a hard depressed accelerator which hastens the clutch take-up.
http://i752.photobucket.com/albums/x...A/Saxomat6.jpg
The servo clutch used an electric switch that supplied manifold vacuum via an actuator valve to a reservoir that disengaged the clutch. The clutch is disengaged automatically whenever the gear shift lever was touched.
http://i752.photobucket.com/albums/x...A/Saxomat7.jpg Here, above, the gear lever switch is visible in this shot of a DKW “Fissore” Saxomat, just above the rubber boot on the gear lever. http://i752.photobucket.com/albums/x.../Saxomat11.jpg
تداول رواد مواقع التواصل الإجتماعي، مقطع فيديو لمهندس مصري إبتكر طريقة جديدة لتحويل سيارة مصممة لتعمل بنظام ناقل الحركة اليدوي إلى سيارة تشبه طريقة قيادة السيارات الأوتوماتيكي.
ويظهر
في الفيديو المتداول، مهندس يقوم باختبار قيادة سيارة "بيجو 305" مانيوال وتحريك عصا الفتيس اليدوي بدون دواسة فصل تروس ناقل الحركة، ولم يكشف عن تفاصيل تحويل السيارة التي تعمل بناقل حركة يدوي إلى سيارة تسير بناقل حركة أوتوماتيكي. https://www.youtube.com/watch?v=rlDJ0xlY564
