رابط موبيل 1 extended
https://mobiloil.com/en/faq/product-...View=20&Page=1
لاحظ تأثير تصميم الموتور فى الجمله دى .. بمعنى ان مده الزيت قد تتأثر ( بالزياده ) بالموتور المستخدم فيه الزيت .. لكن لا حديث عن امكانيه التأثر السلبى بالنقصان
يعنى بيقول ان لو الصانع حدد مسافه اكبر من 15 الف ميل لتغيير الزيت و كان مستوى الخدمه اللى طالبه الصانع مماثل لمستوى خدمه موبيل 1 extended .. يمكن استعمال زيت موبيل للمسافه الاطول التى حددها الصانع
و لاحظ كمان انه اتكلم على ( و لكن بغموض ) عن الزياده فى صوره مسافه distance .. موش oil change interval يعنى مسافه و مده
f Mobil 1™ Extended Performance is recommended for 15,000-mile intervals, what’s the maximum limit to which it can be pushed? In other words, if a driver goes an extra 1,000 miles or so, is he going to damage his engine?
Mobil 1 Extended Performance synthetic oil is recommended for oil change intervals up to 15,000 miles or one year, whichever occurs first. However, if your vehicle manufacturer recommends an oil change interval beyond 15,000 miles and Mobil 1 Extended Performance meets the performance level specified, you can be assured that Mobil 1 Extended Performance will go the distance.
و هنا لما اتكلم عن الاستخدام الشاق .. طلب اتباع تعليمات الكتالوج
Upon what driving conditions are these performance claims based? Normal or severe driving conditions?
These claims relate to all typical consumer driving conditions, excluding those mentioned below. In other words, if you drive under normal conditions and use
Mobil 1™ Extended Performance synthetic oil in your vehicle, the oil is guaranteed to protect your engine for 15,000 miles.
We also recommend that drivers consult their owner’s manual while their vehicle is under warranty, and follow the guidelines set forth there. Additionally,
we recommend that if consumers drive routinely in severe conditions that they follow the oil change interval recommended in their owner's manual for severe conditions
- و لاحظ حاجه تانيه فى موبيل 1 extended
الزيتين لزوجه ال 30 .. مواصفتهم الاوروبيه A1\B1 .. يعنى مواتير لزوجه منخفضه و احتكاك منخفض ( يعنى اشتراط خاص )
https://mobiloil.com/en/motor-oils/m...d-performance#
- و ده رابط اضافى فيه لزوجاات اضافيه لزيوت موبيل عاليه الجوده .. ما عدا 15W-50
https://mobiloil.com/en/motor-oils/mobil-1/mobil-1
