جهاز دريم بوكس للبيع فى مصر dm 7020 hd v2
بكافه مشتملاته
الجهاز ليس جديد ولكنه بحاله ممتازه ولم اكن استخدمه كثيرا
ومازالت لصقه الورق الشفاف موجوده على الشاشه حتى الان
حيث انه لدى اكثر من جهاز
مطلوب 3800 جنيها سعر البيع
Main features are a 400 MHz processor the dreambox DM7020 HD supports the Linux TV API
- MPEG-2 / H.264 decoding
- 10/100MBit compatible Ethernet Interface
- DVB-S2 tuner
- DVB-C / DVB-T hybrid tuner
- mixable, plug & play
- 2 x Common Interface
- big size white OLED display
Technical data
- 400 MHz MIPS Processor
- Enigma 2, Linux Operating System
- brilliant white OLED - Display
- MPEG-2 /H.264 Hardware decoding
- DVB-S2 and DVB-C / DVB-T tuner modul
- 2 x DVB Common-Interface Slot
- 2 x Smartcard-Reader (Dreamcrypt CA)
- Mini USB for service update
- 10/100 MBit compatible Ethernet Interface
- 3 x USB 2.0 (1 x front, 2 x back)
- S/PDIF Interface for digital bit stream out (AC-3)
- Scart-interfaces
- analog modem
- HDMI
- Audio/Video cinch out
- 1 GByte Flash, 512 MByte RAM
- SATA - Plug&Play frame for internal HDD 3,5" in any capacity
- eSATA)
- unlimited channel lists for TV/Radio
- channel-change time < 1 second
- automatic service scan
- directly bouquet-lists
- EPG (electronic program guide)
- Videotext Decoder
- multiple LNB-Switching control (DiSEqC)
- OSD in many languages and skin-support
DreamBox DM7020 HD technical data
DVB-S2 Tuner:
Frequency Range 950...2150 MHz
QPSK Demodulation EN 302 307
Signal Level - 65 dBm...- 25 dBm
Signal-to-Noise Level 12 dB max.
DBS-Tuner Input Connector F-Type female
Input Impedance 75 Ohm
AFC +/- 3 MHz
Demodulation Shaped QPSK and 8PSK
FEC Viterbi and Reed-Solomon
Viterbirate 1/4, 1/3, 2/5, 1/2, 3/5, 2/3, 3/4, 4/5, 5/6, 8/9
Roll-off Factor 35 %
Hybrid - DVB-C/T-Tuner:
VHF-Kanäle: 2-12 (49...230 MHz)
UHF-Kanäle: 21-69 (470...861 MHz)
DVB-C HDTV kompatibel
Eingangsfrequenzbereich: 51...858 MHz
Symbolrate: 1 ... 7 Mbaud/s
Eingangsimpedanz: 75 Ohm
Tuner Ein/Ausgang: IEC-Stecker
DVB-C / DVB-T über Software umschaltbar
Common-Interface:
Common-Interface Power Consumption max. 0,3A/5V
Video decoder:
Video Compression MPEG-2 / H.264 and MPEG-1 compatible
Video Standard PAL G/ 25 Hz, NTSC
Video Formats 4:3 / 16:9
Letterbox for 4:3 TV-Device
Audio decoder:
Audiokompression MPEG-1 & MPEG-2 Layer I and II, MP3
Audio Mode Dual (main/sub), Stereo
Frequency: 32 kHz, 44.1 kHz, 48 kHz, 16 kHz, 22.05 kHz, 24 kHz
Output analog:
Output Level L/R 0,5 Vss on 600 Ohm
THD > 60 dB (1 kHz)
Crosstalk < -65 dB
Output digital:
Output Level 0,5 Vss on 75 Ohm
Sampled Data Filtering 32 kHz, 44.1 kHz, 48 kHz
S/PDIF-Output optical, coaxial (AC3)
Video parameter:
Input Level FBAS 1 Vss +/- 0.3 dB on 75 Ohm
Teletext filter in conformity with ETS 300 472 Standard
TV-Scart:
Output: FBAS, RGB, S-Video
Mini USB service Interface:
Function: Update of Firmware
Ethernet:
10/100 MBit compatible interface
USB:
USB 2.0 connector (3x)
SATA Interface:
for internal HDD
eSATA
LNB power and polarisation per tuner:
LNB Current 500mA max.; short-circuit-protected
LNB Voltage vertical < 14V no load, > 11,5V at 400mA
LNB Voltage horizontal < 20V no load, > 17,3V at 400mA
LNB power off in Standy mode
Count of active satellite position:
DiSEqC 1.0/1.1/1.2 and USALS (Rotor Control)
Power consumption:
15W (in operation, with LNB)
13W (in operation, no LNB)
1W (Deep-Standby-Mode)
Input voltage:
230V / 50 Hz alternating current +/- 15%
110V / 60 Hz alternating current +/- 15%
switchable
Physical specification:
Ambient Temperature +15°C...+35°C
Humidity < 80%
Size (W x D x H): 372 mm x 232 mm x 75 mm
Weight: 2,5 kg without HDD
