US Patent # 4,177,779
Fuel Economy System for an Internal Combustion Engine
Tom Ogle (December 11, 1979)
Abstract ~
A fuel economy system for an internal combustion engine which, when installed in a motor vehicle, obviates the need for a conventional carburetor, fuel pump and gasoline tank. The system operates by using the engine vacuum to draw fuel vapors from a vapor tank through a vapor conduit to a vapor equalizer which is positioned directly over the intake manifold of the engine. The vapor tank is constructed of heavy duty steel or the like to withstand the large vacuum pressure and includes an air inlet valve coupled for control to the accelerator pedal. The vapor equalizer ensures distribution of the correct mixture of air and vapor to the cylinders of the engine for combustion, and also includes its own air inlet valve coupled for control to the accelerator pedal. The system utilizes vapor-retarding filters in the vapor conduit, vapor tank and vapor equalizer to deliver the correct vapor/air mixture for proper operation. The vapor tank and fuel contained therein are heated by running the engine coolant through a conduit within the tank. Due to the extremely lean fuel mixtures used by the present invention, gas mileage in excess of one hundred miles per gallon may be achieved.
Inventors: Ogle; Thomas H. W. W. P. (9028 Mt. Delano, El Paso, TX 79924)
Current U.S. Class: 123/522; 261/DIG83 ~ Intern'l Class: F02M 031/00
Field of Search: 123/133,34 A,122 E,134,136 48/180 R 261/144,145
https://www.nilemotors.net/Nile/imag...mavUvoq9Qf/9k=
http://www.editinternational.com/ima...ck-box_low.jpg
http://tesla3.com/free_websites/anderson_plug_02.gif
http://files.tested.com/photos/2015/...1421899360.jpg
http://www.editinternational.com/ima...t-ogle_low.jpg
http://www.sain.rs/images/BabicBranko05.jpg
https://s32.postimg.org/7for2e14l/vapor_car.jpg
University, holder of a doctorate in mechanical engineering with a background in gas dynamics and aerospace study. He is shown with Ogle and another amazed scientist
https://encrypted-tbn0.gstatic.com/i...WbmZWYB8HC3u-g
Thousands of free energy patents & designs spread recently on the net. I have seen at least 4 of them that really work. I have seen in more that 4 third world countries people who run cars on water..just water. Sadly 3rd world governments lazy or corrupt, do not patron talents. But when you try to spread the word, people simply lazy to tap on it. Yes, Oil tycoons still fight free energy makers. So the only way out is that each person builds one unit for himself and maybe a few for his relatives...until one day it becomes so widely spread that Oil assassins cannot kill all people.
This was invented by Tom Ogle in the 80s. He sold the patent and became rich...but when he made another enhancement on it and wanted to publish the new patent, they finished him...lost his life because of it. I have seen several people doing it and works great with far less emisions. Saves 500% of fuel and you can totally turn off the injectors. or even sell them. but sadly you need to remove it if you sell the car because car test authority is mandated to prevent it, claiming it is dangerous. Although it was made perfectly safe after adding the spark arrestor.
