1 مرفق
للبيع جهاز كشف الأعطال Delphi DS150
ملف مرفق 17029Delphi Truck Diagnostics
Delphi’s DS heavy duty software allows users to perform high level diagnostics on trucks, buses, LCVs and trailers. A highly efficient diagnostic tool, it includes functionalities such as intelligent system identification (ISI), intelligent system scan (ISS) and intelligent system updates (ISU), as well as features like setting of parameters, configurations, adjustments and calibrations, for quick and accurate diagnostics. Just as importantly it supports an extensive database with 47 heavy duty manufacturers on more than 57,000 vehicle systems.
Key Functionality
- Full system coverage
- Service light reset
- Read and erase fault codes
- Read and graph live data parameters
- Intelligent system scan (ISS) - full vehicle ECU scans
- Programming
- Component activation and adjustment
- ECU coding
- Print and save diagnostic reports
- Full OBD flight recorder
- VIN recognition
- Battery voltage monitoring
- Intelligent system updates (ISU)
- Intelligent system identification (ISI)
Benefits to the Technician
Extensive vehicle database: 47 truck, bus, LCV and trailer brands and over 57,000 system applications (correct as of R1 2014).
Key VMs Covered
للبيع جهاز كشف الاعطال DELPHI DS150 المستخدم في كشف اعطال السيارات و الشاحنات (سيارات النقل)الجهاز جديد و لم يتم استعماله ومعه كابل الكمبيوتر و يمكن استخدامه عن طريق البلوتوث
