معلش يا جماعة انا قصدي في العنوان سيفيك2007 & 2008 لأن 2009 نازلة باAUXIN
رقم العضوية : 7026
الاقامة : Maadi
السيارة: اسبرانزا تيجو 2009
السيارة[2]: هوندا سيفيك 2008
دراجة بخارية: honda
1. Get the cable as shown in the fig. or any cable you can find. The cable I used is the one that came with the optical drive for PC. The cable is just fit the connector of the head unit. So it is really easy, no soldering needed.
2. Here is the pins assignment from Honda taken from Civic-EU model (this would be the same for all Civic as it exactly the same for my Civic-Thailand model)
B3 = AUX SGND (ground for the signal)
B4 = AUX SH GND (shielding ground for preventing the signal interference from other devices)
B5 = AUX GND (AUX detection wire for switched type female jack)
B13= AUX L (Left signal)
B14 =AUX R (Right signal)
B15 = AUX DET (AUX detection wire for switched type female jack)
I'm really sure about the pins assignment but I'm not sure about the function of those pins.
3. This step you need one CD-Rom cable with a socket taken from another cable. Route the wires as shown in the fig.
4. This step will finish the AUX cable but you would think about where to place this thing in your car. So you should skip this step and go to step#5-6 then get back to complete this step.
Connect the other end to the mini-jack cable by inserting three pieces of hard wire between those female socket. Now you are done with the AUX cable.
5. I would suggest you to hide this cable in the transmission pocket. Remove the pocket and route the wire as shown in fig.
6. Route the wire as shown in fig. Then go to step#4
Congratulation! you now have the AUX.
رقم العضوية : 7026
الاقامة : Maadi
دراجة بخارية: honda
رقم العضوية : 25210
الاقامة : Egypt
السيارة: Honda Civic 2009
السيارة[2]: Toyota Corolla 1997
اولا: مشكور بجد على الموضوع اللي اكيد حيفيدنا و الشرح الوافي و الصور اللي موضحة كل حاجة .
تاني حاجة انا عندي سؤال في الموضوع ده و يا ريت لو حضرتك تفيدني فيه ...
انا معايا موديل 2009 ومش لاقي المدخل بتاع الـ Aux و دخت عليه لدرجة اني اقتنعت انها مفيهاش
رقم العضوية : 26697
الاقامة : aaaa
السيارة: bmw
السيارة[2]: bmw
يعنى الطريقه دى بتفيد فى ايه ؟
رقم العضوية : 2264
السيارة: N/A
السيارة[2]: BMW
دراجة بخارية: NA
رقم العضوية : 25003
الاقامة : اول فيـصل-اسكندرية 21 العجمى
السيارة: هوندا سيفيك 2008
السيارة[2]: فيات 131
رقم العضوية : 7026
الاقامة : Maadi
دراجة بخارية: honda
رقم العضوية : 2264
السيارة: N/A
السيارة[2]: BMW
دراجة بخارية: NA
يا باشا مفيش خلاف طبعاً و احنا مصدقين حضرتك من غير حلفان :)
المشكلة إن العربيات المصري إلي فيها كاست شريط غالباً واخدين الدخل دة في ال-CD عشان يشغلوا عليه الكاست ، فهمت قصدي حضرتك ؟
يعني المدخل دة محجوز بالفعل ، لكن لو مفيش وحدة الشريط يبقى ممكن تعمل كدة بسهولة
تحياتي
رقم العضوية : 7026
الاقامة : Maadi
دراجة بخارية: honda
أولا اسف جدا على تأخيرى فى الرد أنا دلوقتى بعمل الموضوع ده في عربيتى...المكان مش محجوز لكاسيت ولا حاجة...مكان الوصلة بيبقى فاضى ..عشان لو عايز تجيب الوصلة الأصلية من التوكيل لمل ينزلها بعد 100 سنة كدة....الوصلة دي بتتباع بره ب 54 دولار عند موزعين قطع غيار هوندا الأصلية...
My BeAuTifuLL RidE
رقم العضوية : 2264
السيارة: N/A
السيارة[2]: BMW
دراجة بخارية: NA
