المشاركة الأصلية كتبت بواسطة mohelsherief
This engine they listed in the 318 brochure on the bavarian website is false. BMW does not have a 136hp engine at all. If you search online for any engine with these specifications you will not find any. If you look at the torque and rpm figures you will see that this is actually a 127hp engine that is available also in the 118i.
Also if you check the 320 brochure on the bavarian website you'll see that it has 156hp, which is another lie. This engine doesn't exist...it is only 150hp...they only write 156hp so it seems identical to the 156hp in the c180k engine
