ممكن الاسورة اللى اسمها سابونا لندن بتعمل نفس التأثير , اخويا جربها و جابت معاه نتيجه هايله
شكرا ليك يا وائل وهجرب الحل بتاعك
بتحصلي و الله بس الفانوس الشمال مش منور فقولت يمكن الكهرباء ملمسه ولا حاجه
العربيه هيونداي فيرنا
Vehicle Car Anti Static Strap Earth Belt Ground Wirehttp://www.postimage.org/aVdnHR0.jpg
Description:
Static electricity is generated by friction and other causes when a car is traveling. This Anti Static Car Strap prevent the unpleasant shock caused by the potential difference of static electricity when touching the car body or others areas. It also reduced static accumulation of dust.
Auto Anti Static Strap is also helpful to eliminate a noise of wireless phone and to improve radio, sound and monitor of TV.
The body is made of high quality, heat resistant plastic material.
It is very easy to install onto your autos, it's also came with a clear installation instruction on the back of the package.
This Car Anti Static Belt will fit most of the autos, if you want to make sure, please measure the length apart between the bottoms of your back bumper to the ground.
This Auto Anti Static Belt will make a good gift to all your family's member, friends and for yourself.
Size: ~31(L) x 3.9(W)cm (not included the metal ring)
Weight: 123g
Usage:
Check the length between the muffler and ground (this product is 31cm in length).
Spread the band to highest degree by using the regular screw.
Fix up the band to the muffler where you want.
Tighten the regular screw again.
ممكن كمان تحصل لو أنت ماشى بالعربية على سرعة عالية فى أجواء جافة "زى الصحراوى " إحتكاك العربية بالهواء الجاف بيولد شحنات إستاتيكية فى جسم العربية يعنى مش أنت بس الى حيبقى عليك شحنة لوحدك
الشحنة ممكن توصل لكام كيلو فولت
