MINI Cooper
2009 MINI Cooper Base Hatchback Performance & Efficiency Standard Features
1,598 cc 1.6 liters in-line 4 front engine with 77.0 mm bore, 85.8 mm stroke, 11.0 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
Premium unleaded fuel 91
Multi-point injection fuel system
13.2 gallon main premium unleaded fuel tank 11.0
Power: 88 kW , 118 HP SAE @ 6,000 rpm; 114 ft lb , 155 Nm @ 4,250 rpm
2009 MINI Cooper Base Hatchback Handling, Ride & Braking Standard Features
Four-wheel ABS
Brake assist system
Cornering brake control
Four disc brakes including two ventilated discs
Electronic brake distribution
Electronic traction control via ABS & engine management
Immobilizer
Spacesaver steel rim under body spare wheel
Stability control
Strut front suspension independent with stabilizer bar and coil springs, multi-link rear suspension independent with stabilizer bar and coil springs
2009 MINI Cooper Base Hatchback Exterior & Aerodynamics Standard Features
Part-painted front and rear bumpers
Chrome/bright trim around side windows
Day time running lights
Driver and passenger power body color door mirrors
External dimensions: overall length (inches): 145.6, overall width (inches): 66.3, overall height (inches): 55.4, wheelbase (inches): 97.1, front track (inches): 57.4, rear track (inches): 57.8 and curb to curb turning circle (feet): 35.1
Complex surface lens halogen bulb headlights
Luxury trim alloy on gearknob, alloy look on doors and alloy look on dashboard
Gloss paint
Fixed rear window with defogger and intermittent
Roof spoiler
Tinted glass on cabin, rear and side
Weights: curb weight (lbs) 2,568
Windshield wipers with automatic intermittent wipe
2009 MINI Cooper Base Hatchback Interior Standard Features
12v power outlet: cargo and 1
Air conditioning
Diversity antenna
Front ashtray
RDS audio system with AM/FM and CD player CD player reads MP3
Cargo area cover/rear parcel shelf
Cargo area light
Cargo capacity: rear seat down (cu ft): 24.0 and all seats in place (cu ft): 5.6
Front seats cigar lighter
Clock
Computer with average speed, average fuel consumption, instantaneous fuel consumption and range for remaining fuel
Full dashboard console, partial floor console with open storage box
Delayed/fade courtesy lights
Front seats and rear seats cup holders fixed
Door pockets/bins for driver seat, passenger seat and rear seats
External temperature
Floor mats
Driver front airbag with multi-stage deployment, passenger front airbag with occupant sensors and multi-stage deployment
Bucket driver and passenger seat with height adjustment
3-point reel front seat belts on driver seat and passenger seat with pre-tensioners
Two height adjustable head restraints on front seats and rear seats
Headlight control with time delay switch-off and auto off with ignition
Illuminated entry system
Internal dimensions: front headroom (inches): 38.8, rear headroom (inches): 37.6, front leg room (inches): 41.4, rear leg room (inches): 29.9, front shoulder room (inches): 50.3 and rear shoulder room (inches): 44.7
Low tire pressure indicator
Remote power locks includes trunk/hatch, includes power windows and speed sensing
Vehicle speed proportional power steering
Front power windows with two one-touch
Front reading lights
3-point reel rear seat belts on driver side and passenger side
Two symmetrical bench front facing rear seats with zero adjustments
Rear view mirror
Remote control remote trunk/hatch release
Front and rear side curtain airbag
Front seat back storage
Vinyl seat upholstery with additional vinyl
Seating: four seats
Service interval indicator
Front side airbag with occupant sensors
Six speaker(s)
Leather covered steering wheel with tilt adjustment and telescopic adjustment
Tachometer
Illuminated driver and passenger vanity mirror
Ventilation system with micro filter
