505 specifications
Wheelbase: 2740 mm
Track front: 1460 mm
Track rear: 1430 mm
Length: 4580 mm
Width: 1720 mm
Kerb weight: 1210 kg
Weight distribution F/R: 53 %
Aerodynamics Drag coefficient: 0.42
Engine
Type: 4-S
OHV
2 valves per cylinder
Bore x stroke: 88.00 mm. × 81.00 mm.
Bore / stroke ratio: 1.08
Displacement: 1971 cc 120.27 cu in
Compression: 8.8
Fuel system: 1 Ze carb
Aspiration: Normal
Catalytic Converter: N
Max. output: 101.3 PS (100 bph) (74.5 kW) @ 5000 rpm
Max. torque: 161 Nm (118.7 lbft) (16.4 kgm) @ 3000 rpm
Coolant: Water
Performance
Quarter mile: 18.5 s
Top speed: 167
الف شكر للمعلومات الجديده ديه
وفى انتظار المزيد
Content Relevant URLs by
vBSEO 3.6.0 PL2
