المشاركة الأصلية كتبت بواسطة bishoy02010
يا جماعة اللى خلانى أحط الموضوع عايز أوصلكوا ان العربية دية عربية فعلا جبارة و موتورها 4500 سىسى والمحرك V8 و 325 حصان و العربية اللى انتوا شايفنها دية واخدة 5 نجوم من 5 فى أختبارات الأمان وفيها كل عوامل الأمان زى
Anti-lock brakes
ABS brakes automatically sense when a tire has stopped rotating under extreme braking, and will modulate the brake pressure to allow the tire to rotate. This increases the vehicles ability to turn while braking.
Stability control
Stability control automatically senses when the vehicles handling limits have been exceeded and reduces engine power and/or applies select brakes to help prevent the driver from losing control of the vehicle.
Front-impact airbags
Front-impact airbags for the driver and passenger have been designed to protect the head during a frontal crash.
Side impact airbags
Side impact airbags for the front seats have been designed to protect the torso during a side impact collision.
Overhead airbags
Overhead airbags are used to protect the occupant's heads in the event of a side collision or rollover.
Pretensioners
Seatbelt pretensioners automatically tighten seatbelts to place the occupant in the optimal seating position during a collision.
Anti-whiplash
Anti-whiplash head restraints actively react to rear collision forces and craddle the occupants head in an effort to reduce the likelihood of a whiplash injury.
Security system
The vehicle is equipped with a means of anticipating and/or detecting unwanted vehicle intrusion. The vehicle is equipped with an ignition disable device that will prevent the engine from starting if the correct original manufacturer key is not used.
NHTSA Frontal Crash Test
NHTSA rates crash-tested vehicles by assigning them one to five stars, with five stars indicating the most injury protection and one star indicating the least protection.
We're sorry, we do not have the specific safety data that you requested. Please check back as we are continuously updating our safety data selections.
تخيلوا بقى عربية بالمواصفات دية وحصلها كدة فخدوا بالكوا فى التأنى السلامة :) وربنا يسترها
