** ريــــنو كوليــوس ... أول سيارة من رينو دفع ربــاعى **
Renault is proud to present Koleos, its first ever 4x4 crossover. Ideal for escaping the everyday routine, Renault Koleos is comfortable, easy to drive and boasts genuine off-road ability. It has been designed to be versatile too, offering the same reassuring drive when motoring in and about town, on open roads and on motorways as it does when it is taken off the beaten track. Meanwhile, Koleos delivers the same standard of comfort as that expected of a hatchback, as well as cabin space worthy of a compact MPV.
Renault Koleos will be available with two types of Alliance engines in the UK. The latest-generation 2.0 dCi Euro 4 diesel engine (M9R) is available in a choice of two power outputs, 150hp or 175hp. The engine has already been seen on Renault's Mégane, Laguna and Espace, Nissan's Qashqai and New X-Trail and Renault Samsung Motors' QM5. It features the very latest diesel engine technologies, including piezoelectric injectors, common-rail 1,600-bar fuel injection, a water-cooled variable-geometry turbo and a periodic regeneration particulate filter. The 2.0 dCi engine is available with a broad, useful rev band, with peak torque of either 320 or 360Nm (depending on version) available from low engine speeds. The dCi 150 can be ordered for either the 4x2 or 4x4 versions and mated with either a six-speed manual gearbox or six-speed automatic transmission. The 175hp version of the 2.0 dCi engine is mated to a six-speed manual gearbox and all-wheel drive. http://www3.0zz0.com/2009/03/11/13/240333339.jpg http://www3.0zz0.com/2009/03/11/13/420354769.jpg http://www3.0zz0.com/2009/03/11/13/244312554.jpg http://www3.0zz0.com/2009/03/11/13/483788626.jpg http://www3.0zz0.com/2009/03/11/13/137431109.jpg http://www3.0zz0.com/2009/03/11/13/323158739.jpg
