Opel Corsa 1.2i (1993–2000)
Opel logo
Manufacturer Adam Opel AG
Model Corsa 1.2i
Issued in 1993–2000
Base platform Corsa B
Body type hatchback
Number of doors 3
Number of seats 5
Body and Exterior Features
Body construction monocoque
Full weight 870 kg
Length 3740 mm
Width 1610 mm
Height 1420 mm
Wheelbase 2445 mm
Front track 1385 mm
Rear track 1390 mm
Ground clearance 140 mm
Engine
Engine location front across
Fuel petrol
Fuel supply system Multipoint Injection
Max power 33 kW (45 HP) at 4600 rpm
Max torque 88 N·m at 2800 rpm
Engine design, number of cyls linear 4
Displacement 1195 cc
Bore 72 mm
Stroke 73.4 mm
Cam design SOHC
Valves per cyl 2
Total number of valves 8
Compression ratio 10 : 1
Aspiration N
Chassis and Suspension
Front brakes disc
Rear brakes drum
Standard wheels 5J x 13
Standard tyres 165/70 R13
