Has the car been lowered?l
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
this topic is for discussing the concept of proportional valves and what modifications can be done to change their characteristics... the ultimate goal of this post is to know what changes should be done to OEM P valves whenever a brake upgrade is done either on the front or rear brakes.
i will put it in four main points to help me understand the concept and requirements involved and also avoid confusing you guys during the process... the main three points are:
1- my understanding to what P valves do
2- my understanding to how P valves do what they are supposed to do
3- my findings regarding OEM p valves on our daewoos
4- the required modifications to OEM P valves given the rear disk conversion and what parts of the P valves are involved
First part:
This is what i understand as far as P valves go... in the simplest definition, they are used to decrease the brake pressure going to the rear wheels from the one going to the front... this is done simply because the rear tires are more vulnerable to lockup under braking due to weight shift and locking the rear can cause a car to spin out of control thus we must have the appropriate rear brake pressure that will allow the front to lock before the rear.
from the research i have done on the internet i found many topics but this one is the most informative:
http://www.stoptech.com/tech_info/wp...g_valves.shtml
now this article shows that their are two characteristics for a P valve... and that is the knee point and the slope, knee point is the point where proportioning starts, the slope is the ratio of proportioning between front and rear... so simply it is "when" and "how much".
By all means feel free to correct me if i go something wrong.
Second part:
this is my understanding to how P valves actually works... after dismantling the OEM P valve of a lanos i found out it consists of a ported valve, spring and a spring loaded plastic part... i suppose the big spring is the one responsible for the location of the knee point on the graph since a spring is sensitive to pressure and as far as i understand it will compress at some point changing the brake fluid passage and thus start restricting the pressure so spring power is related to the knee point.
the size of the port in the valve itself is deciding the slope of the curve after the knee point... since port sizes and all affects pressure in a circuit so i suppose the bigger the port the less slope angle you will get (if the valve was totally blocked you would get zero pressure to rear after knee point)
Third part:
i have found out that Dewoos have two different P valves... i was at the mechanic's shop during the rear brakes conversion and found out the following:
1.5 Lanos P valves are marked 3/40 while 1.6 Lanos and Nubira P valves are marked 3/30... no idea what does them numbers refer two, i have dismantled both valves and found out that both internal valves have the same port ( i didn't have a measurement tool to do so and i relied on my eyes... if their was a difference then it will be very very minimalistic) so as far as i understand both valves got the same slope after the knee point.
the major difference i saw was the spring... they both got the same thickness but the 3/30 valve got a longer spring than the 3/40 one so as far as i understand i suppose it is applying more pressure on the valve thus creating a different knee point and the 3/30 valve that has the longer spring have a higher knee point than the 3/40 valve
Fourth part:
the rear brake upgrade for my car involved dual piston rear calipers with needs more work from the brake master to move the bigger pistons... i suppose this translates to "higher knee point" thus i should be using the 3/30 valve springs or even stronger springs to elevate the knee point to compensate for the bigger volume of fluid required at the rear
as for the slope... i have no idea what i should have... :roll: :roll: :roll:
should i have more sloping as the rear disk setup is supposed to be stronger and more vulnerable to lockup?
Should i have less sloping as i still suffer from the big volume requirement after the knee point as well?
Should i keep it as it is as the knee point adjustment is enough to handle the big volume requirement yet the rear setup is not that powerful to lock the rear anyways?
i know this is rather confusing and will require some testing for various setups but at least i want to know which rout i should go with first to avoid testing a thousand possible combination so I'd like some theoretical analysis and advice from you guys to have a plan for testing
and again this is my current understanding to fluid pressure and P valves so i might be wrong in one or more areas here so please correct me whenever i am wrong
رقم العضوية : 3971
الاقامة : Giza-Egypt
السيارة: 4G93T
السيارة[2]: Mitsubishi Lancer GSR CK1A
دراجة بخارية: n/a
VTEC: All of the lag...none of the BOOST l
رقم العضوية : 102
دراجة بخارية: N/A
nope... it is still sitting at OEM level... but you know it has now rear disks rather than drums
it is worth mentioning that the disk setup has two pistons per caliper and both are much bigger than the old setup so they require much more fluid to operate efficiently... or so i was told
if a change in the P valves is required then i have to understand how does those things work and what characteristics can be changed through changing the spring power and port size
رقم العضوية : 3971
السيارة: 4G93T
دراجة بخارية: n/a
Well from what I understand the harder the suspension pulls on the spring, the higher the cutoff pressure for the rear brakes. The idea is if you put a bunch of stuff in the trunk area, it cranks up the rear brakes because the extra weight will allow the rear brakes to work harder
رقم العضوية : 102
دراجة بخارية: N/A
i got that part but that is not what i am seeking
you see... i have upgraded my front brakes thus i have more front bias than an OEM lanos... adding to that the rear upgrade requires more fluid to operate as expected
now i have two things to identify:
1- do i need any bias adjustment?
2- how to change current bias if i do need to change it?
as you can see the P valve is basically a ported valve loaded with a spring... what does the spring control and what does the port size affect??
adding to that the fact that i have found that their are two types of valves on our daewoos... 3/30 and 3/40 and the only difference i found was in the spring length so what should that affect ?
their are too many questions that i can't find answers to them
رقم العضوية : 3971
السيارة: 4G93T
دراجة بخارية: n/a
Let us brainstorm....I think the two different valves affects the tension of the spring, and you need to adjust the pin on the regulator spring.
If you can do some tests on a deserted area, you can pull it a little tighter to increase the rear brake pressure. You want it where the front wheels lock up just before the rear wheels in a hard/emergency stop. If the rear wheels lock up first, it's very dangerous. If the rear wheels don't lock up very soon after the fronts, you aren't getting optimum braking from the rear brakes. If you don't get it exactly right, having the spring too loose is probably safer than having it too tight
رقم العضوية : 102
دراجة بخارية: N/A
so we have established that the spring power affects the overall performance of rear brakes... but what exactly does it affect?
i mean if you look at the diagram showing front to rear bias you will see that we have:
1- knee point: where the proportional effect starts to take place
2- slope: where the bias effect changes the inclination degree of the line showing the relation between front -to- rear braking pressure
i have found out that the valve assembly contains a ported valve loaded with a spring... and i am not sure what will happen if i ported the valve to a bigger bore compared to using a stronger spring... in other words which component will affect knee point/slope?
i am more inclined towards the idea that the spring affects the position of the knee point... since the spring is either stretched or compressed then it is kinda like an on/off switch
in a normal braking situation the spring will be stretched and no bias takes effect and once pressure reaches a certain level where it is sufficient enough to compress the spring... bias starts to take effect... and that will mean if you use stronger springs you will get higher knee point
on the other hand port size of the valve affects the slope of the bias line after the knee point... since it represents fluid passage to the rear then its affect is continuous along the range of braking pressure... i also thought if you - assumingly - used a valve with no port then rear brake pressure after knee point is zero since the passage is totally blocked and vice versa
do you think these findings are logical?? i really need a second opinion as i am lacking technical support in this area and their isn't much info on this issue on the internet so we have to do some research and rational on our own... tell me what you think
رقم العضوية : 2882
الاقامة : Heliopolis
السيارة: -
السيارة[2]: Fiat Tipo 1.6 i.e
that`s challenging
from what i already know and what i understood from your description and the website , you`ve already altered you bias by upgrading your front setup, larger diameter with larger pistons means more bias at the front
again you did alter your bias by fitting rear discs
the only thing i can think of is that you should improvise, trial and error, you`ve already tested the setup with the original valve, if the lanos1.6/nupira valve fit your lanos, why not give it a try ?
also try to drill one as you told me before
one last thing, i think and it`s only a thought that you`ll need the larger master cylinder to compensate for the amount of fluid going to the rear pistons
i`m just brainstorming with you as the good mr.slvrlan said
I Got Petrol In My VEINS
رقم العضوية : 102
دراجة بخارية: N/A
every time i tackle this issue i end up with trial and error... only thing is the "error" could be fatal (in case you didn't hear from me for a long time then you should know that i hit the error bit of the test)
now the thing is... i found out that my car got the 3/30 P valves found on a nubira already... no idea why or how did this happen... anyways this rules out the "spring modification" idea since i already got the stiffer spring
i am going to go with the valve drilling option and give it a try... i hope i don't crash in the process or so... if i am going to do the testing in rehab or so i will give you a call to join in
BTW i already have the bigger master cylinder on my car... already upgraded with the front brakes upgrade
رقم العضوية : 2882
السيارة: -
god forbid
of course you know i meant " trial and error " in a deserted place, i`m not talking about 140km/h in sala7 salem to test the new brakes
another thought, what about the valve from the 2.0L nupira, it has the uprated front setup plus stock rear discs, the valve specs should provide a clearer view of the entire process
another test method could be used as preliminary testing, raise one side of the car so the two wheels are in the air, with the help of someone start applying pressure to the pedal and in the same time rotate each wheel, should give a vague idea about which locks first, front or rear
of course i`ll be more than glad to join in any project of yours, just gimme a call
