أول مرة اسمع عنها الصراحة هو الراجل صاحبها في مصر ولا برة ؟
رقم العضوية : 93
السيارة: Logan 2013 auto
السيارة[2]: speranza
يا جماعه انا النهارده كنت بتكلم مع حد و قالي ان هو ركب العربيه ديIt's a pure electric car
How It Works
When you build a car that's electric, you start with one built-in advantage: Electric cars just don't have to be as complex mechanically as the car you're probably driving now. Sophisticated electronics and software take the place of the pounds and pounds of machinery required to introduce a spark and ignite the fuel that powers an internal combustion engine.
For example, the typical four-cylinder engine of a conventional car comprises over a hundred moving parts. By comparison, the motor of the Tesla Roadster has just one: the rotor. So there's less weight to drive around and fewer parts that could break or wear down over time.
The Tesla Roadster's elegantly designed powertrain consists of just the four main components discussed below. Mind you, these aren't "off-the-shelf" components, and each includes innovations, both small and large. But when you build a car from the ground up, you have the luxury of questioning every assumption — and to distill as you reinvent.
The Battery
When we set out to build a high-performance electric car, the biggest challenge was obvious from the start: the battery. Its complexities are clear: it's heavy, expensive, and offers limited power and range. Yet it has one quality that eclipses these disadvantages and motivated us to keep working tirelessly: it's clean.
The Tesla Roadster's battery pack — the car's "fuel tank" — represents the biggest innovation in the Tesla Roadster and is one of the largest and most advanced battery packs in the world. We've combined available and proven lithium ion battery technology with our own unique battery pack design to provide multiple layers of safety. It's light, durable, recyclable, and it is capable of delivering enough power to accelerate the Tesla Roadster from 0 to 60 mph in under 4 seconds. Meanwhile, the battery stores enough energy for the vehicle to travel about 220 miles without recharging, something no other production electric vehicle in history can claim.
Motor
Some people find it hard to imagine our car's supercar-level acceleration comes from a motor about the size of a watermelon. And while most car engines have to be moved with winches or forklifts, ours weighs about 115 pounds — a strong person could carry it around in a backpack (although we don't recommend it). Compare that to the mass of machinery under the hood of $300,000 supercars that still can't accelerate as quickly as the Tesla Roadster.
But more important than the motor's size or weight is its efficency. Without proper efficiency, a motor will convert electrical energy into heat instead of rotational energy. So we designed our motor to have efficiencies of 85 to 95 percent; this way the precious stored energy of the battery pack ends up propelling you down the road instead of just heating up the trunk.
Transmission
Our single-speed gearbox couples the low drag and fuel efficiency of a manual transmission with the driving ease of an automatic. The Tesla Roadster has only one forward speed. That speed is quick. How fast quick arrives is up to the driver. Perfectly modulated velocity is under total control at all times.
There is no clutch pedal. Just move the shift lever and the Power Electronics Module takes care of everything. You can launch from full stop to highway speed without taking your focus off the road, your foot off the accelerator, your hands off the wheel, or your mind off an entirely new kind of driving experience.
Power Electronics Module (PEM)
Most of the subsystems in the Tesla Roadster are completely electronic and under direct software control. Unlike lesser cars, these systems are not merely a hodge-podge of independent systems arranged pell mell. Instead, each component is designed to be part of a whole that is based on the modern architecture of complex network and computer systems.
You'll see the hub of this network every time you pop the trunk — the Power Electronics Module (PEM). When you shift gears or accelerate in the Tesla Roadster, the PEM translates your commands into precisely timed voltages, telling the motor to respond with the proper speed and direction of rotation. The PEM also controls motor torque, charging, and regenerative braking, and it monitors things like the voltage delivered by the Battery, the speed of rotation of the motor, and the temperatures of the motor and power electronics.
The PEM controls over 200 kW of electrical power during peak acceleration — enough power to illuminate 2,000 incandescent light bulbs
Technical Specifications*
Motor 375 volt AC induction air-cooled electric motor with variable frequency drive.
Max Net Power 248 HP (185 kW) @ 5000-8000 rpm
Max rpm 14,000
Efficiency 92% average, 85% at peak power
Torque 276 ft/lb (375 Nm) @ 0-4500 rpm
Transmission
Single speed fixed gear with electrically-actuated parking lock mechanism and mechanical lubrication pump
Overall Final Drive 8.28:1
Reverse Reverse direction of motor, limited to 15 mph
Final Drive Ratio 3.12:1
Front Suspension Independent. Upper and lower unequal length wishbones. Co-axial coil spring/telescopic damper. Sway bar.
Rear Suspension Independent. Upper and lower unequal length wishbones. Co-axial coil spring/telescopic damper. Sway bar.
Brakes
Hydraulically operated. Tandem master cylinder with vacuum servo and anti-lock braking system. Front and rear ventilated disc. Cable operated self adjusting hand brake on rear calipers.
Wheels
Type Forged Light alloy
Size - front 6J x 16
Size - rear 7.5J x 17
Tires
Type Yokohama Neova AD07 LTS
Size - front 175/55 R16
Size - rear 225/45 R17
Dimensions
Overall length (in. / mm) 155.4 / 3946
Overall width - incl. mirrors (in. / mm) 72.9 / 1851
Overall height (mid-laden weight) (in. / mm) 44.35 / 1126.5
Wheelbase (in. / mm) 92.6 / 2351
Track - front (in. / mm) 57.7 / 1455.6
Track - rear (in. / mm) 59.0 / 1484.5
Curb weight (lbs/kgs) 2723/1238
Leg Room (in./mm) 42.0 / 1067
Front Head Room (in./mm) 36.7 / 932
Front Shoulder Room (in./mm) 26.0 / 660
Standard Interior features
1. Heated sport seats with inflatable lumbar support
2. Three-spoke leather-wrapped MOMO sport steering wheel
3. Leather seats and trim in black, dark gray, light gray, or beige
4. Stereo sound system with single-disc CD player, iPod interface, and MP3 playback
5. Cruise Control
6. Homelink universal transmitter to operate compatible garage, gate, and home lighting/home security systems
7. Power windows and locks
8. Air conditioning
9. Retractable cup holder
Standard Exterior Features
1. Double-insulated black soft top
2. Halogen low and high-beam headlamp assemblies
3. LED tail lights
4. Forged uni-directional seven-spoke wheels in silver finish: 16" front, 17" rear
5. Locking wheel lugs
6. Battery heater for cold weather charging to -20 degrees Celsius
7. High Power Connector with integral safety features for 3.5 hour charge
Standard Safety and Security Features
1. Four-sensor, four-channel anti-lock braking system (ABS)
2. Traction control
3. Tire pressure monitoring system
4. Front and rear crumple zones
5. Driver and passenger front airbags
6. Rigid occupant safety cell
7. Side impact door beams
8. Seatbelt pretensioners
9. Integrated headrests
10. Emergency tire Inflator/sealant
11. Vehicle theft-deterrent and motor immobilizer system
12. PIN code prevents unauthorized vehicle operation
13. Valet Mode restricts vehicle speed, acceleration, and distance
Factory-installed options and accessories
1. Premium leather seats available in nine colors or combination of colors with embroidered Tesla Motors logo
2. Premium audio package. Includes satellite radio, navigation and 7 speaker sound system with subwoofer
3. Microfiber cloth seats in black
4. Bluetooth cellular phone integration
5. Matching body-colored carbon fiber hardtop with full headliner
6. Metallic and premium paint
7. Tesla Motors custom floor mats
8. Mobile Connector for travel charging
Performance Specifications*
Style 2-seat, open-top, rear-drive sports car
Drivetrain Single speed fixed gear with electrically actuated parking lock mechanism and mechanical lubrication pump
Motor 375 volt AC induction air-cooled electric motor with variable frequency drive. Output 248 peak horsepower (185kW) and 276 ft/lbs (375 nm) of torque. Redline 14,000 rpm.
Chassis Resin-bonded and riveted extruded aluminum monoquoque. Four-wheel independent suspension featuring upper and lower unequal length wishbones and co-axial coil spring telescopic dampers.
Brakes Hydraulically operated. Tandem master cylinder with vacuum servo and anti-lock braking system.
Acceleration 0 to 60 mph in under 4 seconds
Top Speed 125 mph (electronically limited)
Range About 220 miles
(based on EPA combined city/highway cycle)
Battery Life Five years or 100,000 miles
Battery Custom microprocessor-controlled lithium-ion battery with 6,831 individual cells. Weight 992 lbs.
Full Charge About 3.5 hours using the Tesla Motors High Power Connector.
ها ايه رايكم :))
فادي فهمي
A516
silver
اسبرانزاوي رقم 14
رقم العضوية : 14603
الاقامة : Egypt, Cairo, Heliopolis
السيارة: Honda Civic EL 1992
السيارة[2]: Honda Civic VTi 1996
HONDA THE POWER OF DREAMS
رقم العضوية : 17364
الاقامة : shbien el kome
السيارة: إوعدنا يا رب
السيارة[2]: opel vectra 2.0 2001
حلوة العربيات الكهربا فى عربية كمان من أوبل بتمشى بالكهربا موجودة هنا فى منتدى أوبل
http://www.nilemotors.net/Nile/showthread.php?t=70731
بس يا ترى حنيجى فى يوم فى المنتدى و تلاقى واحد كاتب إستهلاك عربيتى عالى جدا أنا بعمل كذا كيلو فى البطارية إمتى اليوم دا يجى
[sor2]http://badge.facebook.com/badge/118286498828.2713.630313105.png[/sor2]
لما نعيش فى تبات و نبات و نجيب صبيان و بنات إسمى هو الى هيخدوه منى و بس
رقم العضوية : 93
رقم العضوية : 17364
رقم العضوية : 35540
النوع : انثى
الاقامة : Egypt_Alexandria
السيارة: لا يوجد
السيارة[2]: لا يوجد
دراجة بخارية: -
هى العربية دى موجود عندنا ولا حتى فى احتمال تكون موجود
احنا مستوانا اعلى من كده بكتييييييييييييييييييير
دول ناس فقرا معندهومش بترول:k30:
رقم العضوية : 19705
الاقامة : Alexandria
السيارة: ...
السيارة[2]: Hyundai Elantra 2012
دراجة بخارية: ......
أول ما قرأت الأسم فكرت الموضوع عن كمبيوتر Tesla ودة يا جماعة للي حابب يعرف كمبيوتر خارق عملته Nvidia لما حست أن مستقبلها مهدد على المدى البعيد وسمته تسلا سوبر كمبيوتر ودة أسرع من أي جهاز كمبيوتر في العالم ب 250 مرة بالظبط وشارك في تصنيعة شركات عملاقة منها ديل ولينوفو اللي هيا آي بي أم وغيرهم يبدوا أن تسلا أسم يطلق على الأشياء الخارقة ومنها السيارة تسلا .
رقم العضوية : 2602
الاقامة : cairo new
السيارة: volks beetle
السيارة[2]: LANSER -1999.GLX
بصراحه مش فاهم حاجه خالص ياريت ترجمه
ابـــــو هــــــــــاشـــــــــم [sor2]http://nileup.com/up/uploads/nilemotors_13674136111.jpg[/sor2]
رقم العضوية : 4695
الاقامة : مصر
السيارة: None
السيارة[2]: None
دراجة بخارية: مفيش
