بسم الله ما شاء الله
موضوع فعلا حصرى
شكرا يا معلم
رقم العضوية : 7360
الاقامة : EGYPT - TANTA
السيارة: LOGAN 2011
السيارة[2]: nothing now
:: حصرياَ فقط لنايل موتورز ::
حصريا لنايل موتورز أفضل منتدى سيارات في مصر أحدث برامج AEM لإدارة و تعديل ال EMS ( Engine Management System ) Remaping و هو تعديل شامل و كامل لوحدة التحكم بالمحرك , حيث يعرض البرنامج ضبط ال default للوحدة و يمكن من التعديل على هذه القيم و إعادة تحميلها على وحدة التحكم لتحسين أداء السيارة .
البرنامج الاول :
نبذة عن البرنامج :
The AEM EMS (Engine Management System) is a total Engine Management
solution. The AEM EMS is a tool that allows the user to custom tune an engine by
specific requirements. This is extremely useful and usually necessary when upgrading your engine for maximum performance, especially if installing a
turbocharger, supercharger or building up a normally aspirated engine. The EMS is a
stand alone system, which completely replaces the factory ECU and features unique
plug and play technology, which means that each system is configured especially for
your make and model of car. There is no need to modify your factory wiring harness
and in most cases your car may be returned to stock in a matter of minutes. The
AEMPro software is configured to work with the factory sensors and equipment, so
that there is no need for expensive or hard to find sensors, making replacement and
repairs as simple as with an unmodified car.
البرنامج الثاني :
نبذة عن البرنامج :
Welcome to the AEMTuner Program Guide. You are reading this because you have purchased, or plan on purchasing, an AEM Engine Management System (EMS) and need to know how to get it to run your vehicle. AEMTuner is the PC based software program that is used to tune your AEM EMS. This software has the ability to connect to an EMS and communicate with it. AEMTuner can send the EMS new firmware (which is the "software" that the EMS uses to run your engine), download internal log files that the EMS has recorded while running the engine, and most importantly update the calibration that the EMS's firmware references to run the engine. This calibration contains all the tables and variables that are specific to your car that tell the ECU how much fuel and ignition timing to give the engine, as well as a slew of other functions it can control.
This Guide will outline how the AEMTuner software itself works. This does NOT have information on how the EMS controls your engine, or how to setup the tables and options to make your car run. That information is contained within the Explantion page of the Support Pane and is specific to the function of the EMS you are tuning. This Guide will tell you how to use the interface of AEMTuner to make the changes you need to your EMS, not what changes to make.
تحذير هام :
هذه البرامج للإستخدام المحترف من قبل المتخصصين و المحترفين في مجال التعديل مثل أخونا محمد ممدوح , لذلك لزم التنويه بعدم إستخدام هذه البرامج من قبل شخص مبتدئ .
رقم العضوية : 20036
السيارة: no
السيارة[2]: no
موضوع فعلا حصرى
شكرا يا معلم
رقم العضوية : 2264
السيارة: N/A
السيارة[2]: BMW
دراجة بخارية: NA
رقم العضوية : 7360
السيارة: LOGAN 2011
رقم العضوية : 31534
السيارة: nissan sunny
السيارة[2]: fiat 132 2000
هنجرب وربنا يستر
..:10D5C8~1107:sheeko00
رقم العضوية : 9652
الاقامة : helwan
السيارة: 128
السيارة[2]: lanous 97
dانا ولا فاهم اى حاجه من اللى انتو بتقولو خاااااااااااالص
رقم العضوية : 7360
السيارة: LOGAN 2011
رقم العضوية : 30094
الاقامة : EgYpTo
السيارة: Only One
السيارة[2]: Private
دراجة بخارية: RR
طب طرق عمليه ؟؟ فيديو ؟؟ او أمثله؟؟
[glow1=#7a3131]Dr.Ahmed AlSherif[/glow1]
رقم العضوية : 21269
الاقامة : betna - isma3lia
السيارة: lesa
السيارة[2]: bey2olo gen2 2008
فعلا يا ريت شرح اكتر واه الي ممكن نستفيده
DA ANA BA3D EL TA3DEL
[aldl]http://khirn.weebly.com/uploads/2/1/9/5/2195681/9709014_orig.jpg[/aldl]
رقم العضوية : 21269
السيارة: lesa
يعني مثلا هل ممكن اشيل العوائق الي حطاها الشركة زي
1.ممكن اخلي العربية تطلع بالهورس باور الكامل بتاعها ودا الشركة بتكون مقللاه في الاول علشان تحافظ على العمر الافتراضي للكاوتش
2.ممكن الغي بعض من مواصفات الامان
3.ممكن الغي ال ..... بتاع حاجة معينه
4.ولو اعلى سرعة متحدده ينفع الغيها و كده
