معقوله !! المساحه الداخليه للياريس أكبر من الكورولا!!
http://en.wikipedia.org/wiki/Toyota_Belta
اقرأ نهايه الفقره التانيه
The Vitz and the Belta share underpinnings with each other. However, while the Vitz was designed at Toyota's European design studios, the Belta was designed at Toyota's Japanese design studios – two completely different design projects for similar cars marketed toward different demographics. While the outgoing Vitz and Platz models look and feel virtually alike (the only things the cars don't share is the front clip, lights, rear doors and bodies from behind the B-pillar), the new Vitz and Belta are much more subtly related. Sharing a similar but different dashboard, they do not employ the same components. The cars only share a frame and the drivetrain options. Sheetmetal is completely different. The Belta has increased in size over the previous generation, its interior volume larger than the current generation Toyota Corolla
Belta = Yaris
Vitz = Yaris Hatchback
اللي انا شايفه ان صحيح الياريس واسعه بس الكورولا طبعا اوسع
