رقم العضوية : 15875
الاقامة : cairo - helipoiles
السيارة: noune
السيارة[2]: اسبرانزا 516
I have a car stereo purchased from the US and I can’t pick up all radio stations in Europe/UK, what can I do?
If you have purchased a car stereo from the US you will find that it will not pick up many European radio stations. This is due to the fact that US radio frequency steps are different to here in Europe.
You may be able to set the tuner to European stations by following this procedure.
Press and hold down the SRC button to power down the unit completely.
While the unit is off press button 1 & 5 together, while momentarily pressing the SRC button.
If this does not work try the following proceedure;
Press and hold buttons 1 and 5 together, while momentarily pressing the reset button.
If this does not work then the unit is not designed to pick up European frequency steps
جرب وقولى ياريت
رقم العضوية : 41554
الاقامة : Ontario - Canada
السيارة: لا يوجد
السيارة[2]: 2006 Dodge Charger R/T
رقم العضوية : 15875
السيارة: noune
مبروك يابرنس
رقم العضوية : 41554
السيارة: لا يوجد
رقم العضوية : 41554
السيارة: لا يوجد
أنا كنت سألت Kenwood USA على الموضوع ده:
I have found one procedure while searching the internet for a solution:
To switch the FM tuner between European mode and USA mode, switch off the head unit by holding the SRC button, then hold down the preset buttons 1 and 5, press the SRC button while holding the preset buttons to switch on the unit.
I tried this procedure with my current Kenwood CD player DPX-MP5070 and it worked fine, I bought this head unit 3 years ago from your distributor in Egypt.
Please tell me if such a procedure can work with the DDX814, I hope it works
وردهم كان:The procedure you’ve mention is only for select CD receivers, not for video units. Video units do not have the capability to switch tuning like the CD units
الKenwood DDX8034BT دلوقتي نزل في توكيل Kenwood اللي في الإمارات سعره 4000 درهم
والDDX814 في USA سعره 1100$ مش 700$ زي ما كنت فاكر وده من غيرمصاريف الشحن داخل USA. يعني تقريبا نفس السعر.
هو لسه الDDX8034BT مش موجود عند توكيل Kenwood في مصر أظن إنه هيبقى بنفس السعر مع إن الموديل اللي قبله DDX8032BT كان في مصر أرخص من الإمارات.
رقم العضوية : 15875
السيارة: noune
استنى شويه ولما نيزل مصر هنستفيد بحجاتين السعر
والضمان
وده رائ
رقم العضوية : 41554
السيارة: لا يوجد
رقم العضوية : 16116
الاقامة : New Cairo
السيارة: Opel Astra 2005 1.6
السيارة[2]: BMW 320i 2017
دراجة بخارية: Suzuki Boulevard m109r
أحسن والله. أغلب المذيعين اللى فى المحطة دي ياإما دمهم تقيل يا إما بيتظرفوا وهم دمهم سم.
تحياتي.
خير الكلام ماقل ودل.
رقم العضوية : 26178
الاقامة : mansoura
السيارة: ان شاء الله E36 M3 ياامسهل
السيارة[2]: BMW E21 2500CC
طيب وانا الحل بتااعي اية
[media]http://www6.0zz0.com/thumbs/2011/09/14/04/347541799.jpg[/media]
MY BMW 2500CC
رقم العضوية : 15875
السيارة: noune
