http://en.wikipedia.org/wiki/Air-fuel_ratio
Lean mixtures produce hotter combustion gases than does a stoichiometric mixture, so much so that pistons can melt as a result. Rich mixtures produces cooler combustion gases than does a stoichiometric mixture, primarily due to the excessive amount of carbon which oxidises to form carbon monoxide, rather than carbon dioxide. The chemical reaction oxidizing carbon to form carbon monoxide releases significantly less heat than the similar reaction to form carbon dioxide. (Carbon monoxide retains significant potential chemical energy. It is itself a fuel whereas carbon dioxide is not.) Lean mixtures, when consumed in an internal combustion engine, produce less power than does the stoichiometric mixture. Similarly, rich mixtures return poorer fuel efficiency than the stoichiometric mixture. (The mixture for the best fuel efficiency is slightly different from the stoichiometric mixture.)
