انا عايز برنامج بتاع اعاده المحذوفات بس يكون حد مجربه عشان بلاقى كتير ومش بيعمل حاجه
من فضلكم انا عايز البرنامج ده ضرورى جدا جدا جدا
هو الموضوع معقد كده !!!
اقتباس:
جري ايه يا باشا ده انت قديم.
الموضوع ده مش مكانه العام... في الاجتماعي ممكن الافادة أكثر...
وعمومآ. أفضل برنامج مستخدم في المجال ده هو
Getdata back
وفي منه نسختين نسخه لل NTFS ونسخه ل FAT32
حاول تبحث عنه هو موجود allready علي النت. ولما تجيبه حارفع لك الكراك بتاعه ان شاء الله
ان شاء الله يرجع ماتقلقش...اقتباس:
شكرا درافت بس انا اول مره اطلب برنامج او حاجه مشابهه بس يارب يرجعلى اللى راح فعلا انا اتخنقت جبت برامج كتير وولا عملوا حاجه
بس أهم حاجه حاول ماتنقلش داتا علي ال Partition ده لحد ما ترجع المفقود...
وده رابك للبرنامج كامل.
http://english.p30world.com/archives/001380.php
http://www.runtime.org/images/x_gdbsmall.gifGetDataBack for FAT is a data recovery software for FAT file systems, which will help you to get your data back, even if your drive's partition table, boot record, FAT, root directory is corrupt or lost or when a virus has hit the drive, files were deleted, the drive was formatted, fdisked or struck by a power failure etc. GetDataBack can even recover your data when the drive is no longer recognized by the operating system or all directory information is lost. It uses advanced algorithms to make sure that all directories and sub directories are put together as they were, and that long file names are reconstructed correctly. GetDataBack is safe to use, because it is read-only, which means the program will never attempt to write to the drive you are about to recover. Instead, it allows you to first create an image of the drive, and then recover the data from the image. The program can also recover data over a network or a serial cable. Easy to use and very effective product.
http://www.p30world.com/images/down.gif Download GetDataBack 2.31 (For FAT)
http://www.p30world.com/images/down.gif Download GetDataBack 2.31 (For NTFS)
