انا كنت عايز اعرف هو الصب الجاك همر موجود هنا فى مصر ولا لاء وى لو موجود الاقية فين وبكام واركب معاه اية عشان يكون الصوت نقى
انت قصدك على ال mtx !!!!!!!!!!
انسسسسسسسسسسسسى انك تلاقيه فى مصر
تشتريه من النت لو عاوز
The JackHammer SuperWoofer represents extreme in every way and this enormous subwoofer lives for high SPL and window shattering bass. But, the T9922 is designed for sonic quality, and high SPL, what we call SQL. JackHammers are shipped in either the SPL mode, with dual 2Ω voice coils, or as the SQL model with dual 4Ω voice coils. A replaceable cone assembly is also available, for switching between "every day" listening (SQL), and competition (SPL).
- 6,000 RMS
- 12,000 peak music power
- 23" tall
- 369 lbs.
- 900ounce strontium ferrite magnet with extended magnetic field gap technology
- Carbon fiber and glass fiber dust cap with aluminum honeycomb center
- Expanded polypropylene cone with mica filler for reduced mass and increased stiffness
- FEA designed progressive roll spider with 10 AWG integrated tinsel leads woven in to allow for 2.5” of linear cone movement one way
- Aluminum shorting ring
- 6.5” voice coil with 17 AWG high temperature aluminum wire in a flat wound, long-excursion design incorporating 2.5” of Xmax
- Aluminum heatsink to maintain the optimum voice-coil temperature
- Replaceable cone kits available to switch between SQL & SPL models without removing the JackHammer SuperWoofer from its enclosure
دا محتاج SPL amp. plus Huge Space in the car to install
دا غير التمن الخزعبلي !!!
ممكن تجيبه اسبيشيال اوردر من محلات الاكسسوارات الكبيره مع ال SPL المناسب
وبالتوفيق
