honestly both are crap
the Lanos brakes have not changed.....some people who bought the lanos have went back to Mansour or to any service center to change the temp gauge because it doesnt work
the logan is takfeel Moroccan....and the parts for it is expensive
the Lanos is better if you can test out the car you will buy to make sure the brakes are good and that everything is working in it....after all, the parts for the lanos are way cheaper than the Reanult
