home theater kenwood مسرح منزلى
kenwood amp
Experience the "entry-level" receiver in Kenwood's Sovereign line, and you'll wonder what they could possibly be holding out for the step-up models!
The VR-5080 packs a limitless supply of 6.1-channel thrills, thanks to built-in decoding for THX Surround EX, DTS-ES Discrete 6.1, and DTS-ES Matrix 6.1 encoded DVDs, as well as DTS Neo:6 modes for turning all your stereo music and Dolby-encoded sources into 6.1-channel sound. Just add an external amp and pair of speakers to the VR-5080's back surround preamp outs to complete a seamless 360° soundfield in your home theater. THX Select certification ensures maximum cinematic realism.
If you're not ready to upgrade your current system to include a second amp and back surround speakers, you'll still be able to enjoy plenty of 5.1-channel home theater thrills, thanks to built-in Dolby Digital and DTS decoding. Dolby Pro Logic II processing even transforms stereo and Pro Logic sources into exciting 5.1 sound. And with 80 watts x 5 channels of amplification, you'll have plenty of power to fill a large room with dynamic multichannel sound. For DVD-Audio, SACD, and other cutting-edge formats, "Ultrasonic Response" amplification (flat all the way out to 100,000 Hz!) delivers superb clarity and impact.
The remote is a 2-way LCD design that can download and display information from the receiver. This brainy remote even emits RF (radio frequency) signals, for easy system control from another room. And thanks to the VR-5080's dual-source/dual-room capability, you and a housemate can enjoy two different A/V sources simultaneously; just connect the Zone B outputs (stereo audio plus composite video) to an amp, speakers, and TV in another room.
Details:
- 180 watts x 2 (stereo) into 6 ohms (20-20k Hz) at 0.03% THD — or 80 x 5 in surround mode All Channels-Driven™)
- THX Surround EX, Dolby Digital, DTS-ES, Pro Logic II
- THX Select
- DTS Neo:6 modes
- 2-way RF/IR learning/multibrand LCD remote with 3 macros
- dual-room/dual-source A/V (preamp outputs for second room)
- digital inputs: 2 optical, 3 coaxial
- optical digital out
- component video switching: 2 in, 1 out (40MHz bandwidth)
- 5 audio and 5 A/V (including 5 S-video, 1 front-panel, and one 5.1-channel) inputs
- 7.1-channel preamp output
- RS-232C port
- 32-bit SHARC DSP
- 32-bit DRIVE™ III distortion reduction
- 24-bit/96kHz A/D and D/A converters
- built-in HDCD decoding
- 17-5/16"W x 7-7/16"H x 18-7/8"D
- السغر الاصلى 6000 جنية مصرى وكان من رضوان العجيل ببيعة لانى مبستعملوش و مركون فممكن يفيد حداكتر منى
- البيع لاعلى سعر
- التليفون:0101521626
- الصور http://www.crutchfield.com/App/Product/Item/Photos/Default.aspx?i=113VR5080&tp=179
http://www.crutchfield.com/App/Produ...3VR5080&tp=179
