نزل البرنامج ده
http://www.b-phreaks.co.uk/files/NSS/NSS103814.zip
فك الضفط وسطبه
وبعد كده دي الخطوات
1 Connect your phone and wait for Windows to detecting it.
2. Open Nemesis Service Suite and click “Scan for new device” on the right-upper part of the window
3. Click on the icon “Phone info”
4. Click on “Scan”
5. Change the product code to "select from the list below" and mark the case “Enable”.
6. Press “Write”, and your phone’s product code will be changed (you might think that nothing happened, because the phone is still in normal mode, and the changing of the product code only takes a couple of seconds, but don’t worry, the product code changed !).
7. Close Nemesis Service Suite and run the Nokia Software Update.
8. Make sure not to touch the cable or the phone while your phone is updating or else you will break it!
وده الكود اللي هتكتبه
0520999 Ae-united Arab Emirates
الموضوع باختصار انك بتغيير البرودكت كود بتاع الجهاز بكود دولة عربية عشان لما تيجي تعمل ابديت برنامج النوكيا يشوف ان الجهاز ده متباع في دولة عربية ود بيبقي عن طريق البرودكت كود
لو حاجة وقفت معاك قولي وان شاء الله يرجع العربي
