النتائج 1 إلى 4 من 4
    الصورة الرمزية ahmedmansor17
    رقم العضوية : 45744
    الحالة : ahmedmansor17 غير متواجد حالياً
    افتراضي سؤال عن استبدال اطارات السيارات؟ - Facebook Twitter whatsapp انشر الموضوع فى :
    معلش ياجماعه انا لسه خام في السواقه ياريت لو حد يفيدني بمعلومات عن كيفية تغير اطارات السيارات اصل انا بصراحه خايف أقع في موقف لاقدر الله من اللي انتم عارفينهم بس ياريت واحده واحده لسه سنه اولي معليش
    وجزاكم الله كل خير
    الصورة الرمزية Khalid Shalabi
    رقم العضوية : 6567
    الاقامة : Damietta
    السيارة: UNO 98
    السيارة[2]: Civic Si 93
    دراجة بخارية: Orbea
    الحالة : Khalid Shalabi غير متواجد حالياً
    Step 1.
    Put the car in park on level ground and apply the parking brake. Place manual transmission cars in gear. Make sure you have pulled off the road. Turn the engine off and turn on the hazard lights. You may want to open the hood to indicate to other drivers that you are stopped for repairs.
    Step 2.
    Place a wheel chock or a large rock behind (if facing uphill) or in front (if facing downhill) the diagonally opposing wheel to prevent the car from rolling. Do this even on a slight incline. Get out the spare, a lug nut wrench (tire iron) and the car jack.
    Step 3.
    Remove the hubcap, if necessary.
    Step 4.
    Loosen the lug nuts, which hold the wheel in place, before jacking up the car: Place one end of the lug nut wrench over a lug nut. Use a hollow pipe (about 2 feet in length) for leverage by slipping it over the end of the lug nut wrench. Turn the wrench counterclockwise to loosen the lug nut. Loosen the lug nuts in a star pattern, first loosen one a few turns, then loosen the one opposite. Work across the tire until all the lug nuts are loose and unscrewed slightly.
    Step 5.
    Carefully jack up the car (see 'Jack Up a Car Safely'). Check your owner's manual for the correct and safe place to put the jack. Jack the car up a little higher than is necessary to remove the old tire so there is room to put the new, full tire on.
    Step 6.
    Remove the lug nuts all the way and set them aside in a place where you won't lose them and they won't roll away. The flat tire should be hanging from the threaded studs now.
    Step 7.
    Remove the flat tire and set it aside.
    Step 8.
    Lift the new tire onto the wheel studs. If you're confused about which is the right way to put the new tire on, check for the valve where you add air, it always faces out.
    Step 9.
    Replace the lug nuts. Tighten them the same way you loosened them: Give each nut a few turns, first one, then the one opposite, working around the wheel in a star pattern. Try not to tighten adjacent nuts consecutively.
    Step 10.
    Slowly lower the jack and remove it.
    Step 11.
    Tighten the lug nuts again as much as you can.
    Step 12.
    Put the hubcap back on.
    ودا رابط الفيديو اللي بيشرح الكلام دا كله
    We can't solve problems by using the same kind of thinking we used when we created them. Einstein
    الصورة الرمزية A.Saad
    رقم العضوية : 25216
    الاقامة : Haram & My mobile phone
    السيارة: New Accent 08
    السيارة[2]: Picanto 09
    الحالة : A.Saad غير متواجد حالياً
    الاول تفك الصواميل والعربية لسه على الارض
    ترفع بالكوريك ويا ريت تحط الطار التانى تحت العربية نايم علشان لو الكوريك وقع مثلا العربية تنزل على الفردة اللى محطوطه تحتها
    تكمل فك الصواميل
    تخرج الكاوتش
    تحط الجديد
    تربط
    تنزل الكوريك
    تاكد ربط
    النقاط الواجب مراعتها
    فك الصواميل ليه ترتيب
    لو 4 بتفك اللى قصاد بعض الاول يعنى اللى فى اليمين ثم الشمال ثم فوق ثم تحت ولو 5 بيتفكوا زى ما تكون على شكل نجمة
    والترتيب ده للتهوية اللى فى الول او الفك النهائى وبرده الربط
    مكان الكوريك لازم تعرفه فى عربيتك
    لو عندك كتالوج العربية ارجع له
    او بتلاقى شفة فى العربية والكوريك بيكون فيه شفة مشقوقة بيتحط فى شفة العربية او بتلاقى قرب العجل فى اسفل العربية اماكن زى ما تكون دايرة بارزة لبرة
    دى بتكون مقواة علاشن الكوريك
    لان وضعه فى اى مكان ممكن يخرم الصاج
    A.Saad
    الصورة الرمزية Marwanelbendary
    رقم العضوية : 32666
    الاقامة : Cairo - Egypt
    السيارة: Nissan
    السيارة[2]: Kia
    الحالة : Marwanelbendary غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة khalid shalabi مشاهدة المشاركة
    step 1.
    Step 2.
    Step 3.
    Step 4.
    Step 5.
    Carefully jack up the car (see 'jack up a car safely'). Check your owner's manual for the correct and safe place to put the jack. Jack the car up a little higher than is necessary to remove the old tire so there is room to put the new, full tire on.
    Step 6.
    Step 7.
    Step 8.
    Step 9.
    Step 10.
    Step 11.
    Step 12.
    11111111111+++++++++
    Pure Engineering, Pure Satisfaction
  1. هل التوكيل يقبل استبدال السيارات القديمة؟
    بواسطة m_z80 في المنتدى هيــونــداى
    آخر مشاركة: 11-08-2011, 04:39 AM
  2. استبدال السيارات الملاكي
    بواسطة osamafarouk في المنتدى بيـــع و شــــراء
    مشاركات: 46
    آخر مشاركة: 24-05-2010, 07:58 PM
  3. فن اطارات السيارات
    بواسطة mada121977 في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 24-05-2010, 04:01 AM
  4. قريبا جدا قانون استبدال السيارات الملاكي التي مر عليها 20 عام فقط
    بواسطة dr_timo في المنتدى المنتــــــدى العـــــــــــام للسيــارات
    مشاركات: 181
    آخر مشاركة: 20-01-2010, 08:53 PM
  5. ياترى ايه قواعد استبدال اطارات السيارات ؟
    بواسطة hamtle97 في المنتدى مشاكل آلات الجــــر
    آخر مشاركة: 31-05-2007, 03:30 PM
