اقتباس:
المشاركة الأصلية كتبت بواسطة egyptianmafia
The ESP in the Vectra as I have been told is electronic....and it is only available in the top line with the S/R and Xenon....
Usually most of showroom salesman confused and mix up TC with ESP most of time on purpose and some time out of misunderstanding as they do with WV JETTA and SKODA Octavia:mahf(5):
Yes the ESP is engaged by default (electronically) but there is must be a button to disengage it for some situation
If you have the below button you do have ESP or “ESP Plus” as they call it in Opel
And if you don’t have it! You don’t have ESP, you only have TC
If you had been told it’s already installed in the high line model, be sure that they are bluffing :36_1_2[1]:
http://www.forum.vectra-c.com/upload...v2007/dash.jpg
