المشاركة الأصلية كتبت بواسطة egyptianmafia
dodino...you can make the service at Mansour...I cannot talk on behalf of Maggar or Yassin or any of those places....
Mansour is the best place to fix it because they know the car 100% and know how to fix it.....
the only thing is...that the car is out of warranty in everything...so you will pay for everything that will be done.....
Dont worry....I have seen cars in Pyramids that are bought from the gulf being serviced at Mansour and the owners paid for everything.....
BUT BUT BUT BUT BUT BUT BUT (keep in mind all the BUTS i wrote....lol)
if you get the Lacetti and say they (Daewoo) had a recall on x part or whatever.....you are out of luck....you will need to buy this x part and pay Mansour to install it for you.....
you wont get it replaced by Mansour or Daewoo for FREE....
1) Mansour wont warranty the Daewoo
2) The Daewoo is ONLY sold in Korea......if you ship it outside Korea...the warranty from Daewoo is also gone
so any recalls you will be stuck with it...and need to find that part that is being recalled and fix it on your expenses...
First of all thank you for the info about Mansour, and I understand that I should pay for any parts + installation, that's acceptable as my most concern is about the professional or the specialist who will install the parts, specially I'll have the option to buy imported parts without the risk of losing the warranty (The buyers from Mansour probably would not have this option ).
also, about the possibility of any future recalls , I got your point and I know it's a risk but still acceptable,and BTW, I did some research and I've knew that's in the Feb 09, Daewoo had recalled the Lacetti produced before Jan. 13th to fix a software bug which cause a RPM problem (I've heard about a similar recall in Egypt), and since then there were no record about any issue or complaint about the car. and since there is no major change in the Equipment in between 2009 and 2010 models, so I don't expect a serious recall at least in the near future...
